分辨率修改涉及两个概念:密度和尺寸
每个项目密度定义路径:
customize/customer_cfg/sp8810ga/res/system.prop
# 1 => add volume control in in-call screen
ro.sprd.volume_control_icon = 1
#LCD_Density for WGVA
ro.sf.lcd_density = 240
dalvik.vm.heapsize=32m
ro.opengles.version=131072
搜索ro.sf.lcd_density关键字,
device/samsung/system.prop,vendor/sprd/hsdroid/system.prop
也有定义!
验证结果:
最终生成的build.prop文件
#LCD_Density for WVGA
来自customize下的修改值!
手机目录system/build.prop通过adb导出来,
修改其中的值,再push进相应目录下的build.prop,重新开机,显示预先效果!
尺寸修改:
Frameworks/base/core/java/Android/content/res/CompatibilityInfo.java
public static final int DEFAULT_PORTRAIT_WIDTH = 320;
public static final int DEFAULT_PORTRAIT_HEIGHT = 480;
四组数据效果比较:
1)、正常效果:
DEFAULT_PORTRAIT_WIDTH = 320;DEFAULT_PORTRAIT_HEIGHT = 480;ro.sf.lcd_density = 240;
2)、正常效果:
DEFAULT_PORTRAIT_WIDTH = 480;DEFAULT_PORTRAIT_HEIGHT = 800;ro.sf.lcd_density = 240;
3)、界面显示正常,系列显示图标变小:
DEFAULT_PORTRAIT_WIDTH = 480;DEFAULT_PORTRAIT_HEIGHT = 800;ro.sf.lcd_density = 160;
4)、部分界面显示不全(如锁),系列显示图标变小:
DEFAULT_PORTRAIT_WIDTH = 320;DEFAULT_PORTRAIT_HEIGHT = 480;ro.sf.lcd_density = 160;
结论:
ro.sf.lcd_density影响分辨率的关键因素,
目前四个等级的屏幕密度等级,
决定每个APK选取res下的不同资源文件。
如主流屏幕drawable-hdpi(密度240)、drawable-mdpi(密度160)等;
相关说明:
frameworks/base/core/java/android/util/DisplayMetrics.java
private static int getDeviceDensity() {
// qemu.sf.lcd_density can be used to override ro.sf.lcd_density
// when running in the emulator, allowing for dynamic configurations.
// The reason for this is that ro.sf.lcd_density is write-once and is
// set by the init process when it parses build.prop before anything else.
return SystemProperties.getInt("qemu.sf.lcd_density",
SystemProperties.getInt("ro.sf.lcd_density", DENSITY_DEFAULT));
frameworks/base/services/surfaceflinger/DisplayHardware/DisplayHardware.cpp
if (property_get("qemu.sf.lcd_density", property, NULL) <= 0) {
if (property_get("ro.sf.lcd_density", property, NULL) <= 0) {
LOGW("ro.sf.lcd_density not defined, using 160 dpi by default.");
strcpy(property, "160");
} else {
mDpiX = mDpiY = atoi(property);
上面表示:
如果没有设置ro.sf.lcd_density的值,那么选择DENSITY_DEFAULT的默认定义;
再看DENSITY_DEFAULT定义处:
public static final int DENSITY_LOW = 120;
public static final int DENSITY_MEDIUM = 160;
public static final int DENSITY_HIGH = 240;
public static final int DENSITY_XHIGH = 320;
public static final int DENSITY_DEFAULT = DENSITY_MEDIUM
