楼主 |
发表于 2015-6-2 09:40:40
显示全部楼层
来自 北京市
我把驱动上传上来,帮忙看看吧,谢谢- #ifdef BUILD_LK
- #else
- #include <linux/string.h>
- #endif
- #include "lcm_drv.h"
- // Local Constants
- #define FRAME_WIDTH (240)
- #define FRAME_HEIGHT (240)
- #define LCM_ID (0x8552)
- // Local Variables
- static LCM_UTIL_FUNCS lcm_util = {0};
- #define SET_RESET_PIN(v) (lcm_util.set_reset_pin((v)))
- #define UDELAY(n) (lcm_util.udelay(n))
- #define MDELAY(n) (lcm_util.mdelay(n))
- // Local Functions
- static __inline void send_ctrl_cmd(unsigned int cmd)
- lcm_util.send_cmd(cmd);
- static __inline void send_data_cmd(unsigned int data)
- lcm_util.send_data(data&0xff);
- static __inline unsigned int read_data_cmd(void)
- return 0xFF&lcm_util.read_data();
- static __inline void set_lcm_register(unsigned int regIndex,
- unsigned int regData)
- send_ctrl_cmd(regIndex);
- send_data_cmd(regData);
- static void sw_clear_panel(unsigned int color)
- unsigned short x0, y0, x1, y1, x, y;
- unsigned short h_X_start,l_X_start,h_X_end,l_X_end,h_Y_start,l_Y_start,h_Y_end,l_Y_end;
- x0 = (unsigned short)0;
- y0 = (unsigned short)0;
- x1 = (unsigned short)FRAME_WIDTH-1;
- y1 = (unsigned short)FRAME_HEIGHT-1;
- h_X_start=((x0&0xFF00)>>8);
- l_X_start=(x0&0x00FF);
- h_X_end=((x1&0xFF00)>>8);
- l_X_end=(x1&0x00FF);
- h_Y_start=((y0&0xFF00)>>8);
- l_Y_start=(y0&0x00FF);
- h_Y_end=((y1&0xFF00)>>8);
- l_Y_end=(y1&0x00FF);
- send_ctrl_cmd(0x2A);
- send_data_cmd(h_X_start);
- send_data_cmd(l_X_start);
- send_data_cmd(h_X_end);
- send_data_cmd(l_X_end);
- send_ctrl_cmd(0x2B);
- send_data_cmd(h_Y_start);
- send_data_cmd(l_Y_start);
- send_data_cmd(h_Y_end);
- send_data_cmd(l_Y_end);
- send_ctrl_cmd(0x29);
- send_ctrl_cmd(0x2C);
- for (y = y0; y <= y1; ++ y) {
- for (x = x0; x <= x1; ++ x) {
- send_data_cmd(color);
- static void init_lcm_registers(void)
- send_ctrl_cmd(0x11);
- MDELAY(120);
- send_ctrl_cmd(0x36);
- send_data_cmd(0x00);//40
- send_ctrl_cmd(0x3a);
- send_data_cmd(0x06);//06
- send_ctrl_cmd(0xb2);
- send_data_cmd(0x28);
- send_data_cmd(0x05);
- send_data_cmd(0x33);
- send_ctrl_cmd(0xb7);
- send_data_cmd(0x35);
- send_ctrl_cmd(0xbb);
- send_data_cmd(0x3c);//23
- send_ctrl_cmd(0xb1);
- send_data_cmd(0x80);
- send_data_cmd(0x10);
- send_ctrl_cmd(0xc0);
- send_data_cmd(0x2c);
- send_ctrl_cmd(0xc2);
- send_data_cmd(0x01);
- send_ctrl_cmd(0xc3);
- send_data_cmd(0x05);//14
- send_ctrl_cmd(0xc4);
- send_data_cmd(0x20);
- send_ctrl_cmd(0xc6);
- send_data_cmd(0x14); // 14
- send_ctrl_cmd(0xd0);
- send_data_cmd(0xa4);
- send_data_cmd(0xa1);
- send_ctrl_cmd(0xe0);
- send_data_cmd(0xd0);
- send_data_cmd(0x02);
- send_data_cmd(0x07);
- send_data_cmd(0x19);
- send_data_cmd(0x2e);
- send_data_cmd(0x54);
- send_data_cmd(0x41);
- send_data_cmd(0x2d);
- send_data_cmd(0x17);
- send_data_cmd(0x18);
- send_ctrl_cmd(0xe1);
- send_data_cmd(0x04);
- send_data_cmd(0x24);
- send_data_cmd(0x44);
- send_data_cmd(0x42);
- send_data_cmd(0x1c);
- send_data_cmd(0x1a);
- send_data_cmd(0x15);
- send_ctrl_cmd(0x35);
- send_ctrl_cmd(0x44);
- sw_clear_panel(0x0);
- // LCM Driver Implementations
- static void lcm_set_util_funcs(const LCM_UTIL_FUNCS *util)
- memcpy(&lcm_util, util, sizeof(LCM_UTIL_FUNCS));
- static void lcm_get_params(LCM_PARAMS *params)
- memset(params, 0, sizeof(LCM_PARAMS));
- params->type = LCM_TYPE_DBI;
- params->ctrl = LCM_CTRL_PARALLEL_DBI;
- params->width = FRAME_WIDTH;
- params->height = FRAME_HEIGHT;
- //params->physical_width = PHYSICAL_WIDTH;
- //params->physical_height = PHYSICAL_HEIGHT;
- params->io_select_mode= 1;
- params->dbi.port = 0;
- params->dbi.clock_freq= LCM_DBI_CLOCK_FREQ_26M;
- params->dbi.data_width = LCM_DBI_DATA_WIDTH_8BITS;
- params->dbi.data_format.color_order = LCM_COLOR_ORDER_RGB;
- params->dbi.data_format.trans_seq = LCM_DBI_TRANS_SEQ_MSB_FIRST;
- params->dbi.data_format.padding = LCM_DBI_PADDING_ON_LSB;
- params->dbi.data_format.format = LCM_DBI_FORMAT_RGB666;
- params->dbi.data_format.width = LCM_DBI_DATA_WIDTH_8BITS;
- params->dbi.cpu_write_bits = LCM_DBI_CPU_WRITE_8_BITS;
- params->dbi.io_driving_current = LCM_DRIVING_CURRENT_8MA;
- params->dbi.parallel.write_setup = 1;
- params->dbi.parallel.write_hold = 10;
- params->dbi.parallel.write_wait = 15;
- params->dbi.parallel.read_setup = 1;
- params->dbi.parallel.read_hold = 10;
- params->dbi.parallel.read_latency = 45;
- params->dbi.parallel.wait_period = 1;
- params->dbi.te_mode = LCM_DBI_TE_MODE_DISABLED;
- //params->dbi.te_edge_polarity = LCM_POLARITY_RISING;
- static void lcm_init(void)
- SET_RESET_PIN(1);
- MDELAY(50);
- SET_RESET_PIN(0);
- MDELAY(100);
- SET_RESET_PIN(1);
- MDELAY(100);
- init_lcm_registers();
- static void lcm_suspend(void)
- send_ctrl_cmd(0x28);
- MDELAY(100);
- send_ctrl_cmd(0x010);
- static void lcm_resume(void)
- MDELAY(150);
- send_ctrl_cmd(0x029);
- static void lcm_update(unsigned int x, unsigned int y,
- unsigned int width, unsigned int height)
- unsigned int h_X_start,l_X_start,h_X_end,l_X_end,h_Y_start,l_Y_start,h_Y_end,l_Y_end;
- unsigned int x0 = x;
- unsigned int y0 = y;
- unsigned int x1 = x0 + width - 1;
- unsigned int y1 = y0 + height - 1;
- static unsigned int lcm_compare_id(void)
- unsigned char id_tmp[4] ;
- int lcd_id;
- send_ctrl_cmd(0x04);
- id_tmp[0] = read_data_cmd();
- id_tmp[1] = read_data_cmd();
- id_tmp[2] = read_data_cmd();
- id_tmp[3] = read_data_cmd();
- lcd_id = ((id_tmp[2]&0xff)<<8)|(id_tmp[3]&0xff);
- #ifdef BUILD_LK
- printf("ST7789S lcm_get_params id_tmp[2] = %d,id_tmp[3]= %d\n",id_tmp[2],id_tmp[3]);
- #endif
- return (LCM_ID == lcd_id)?1:0;
- LCM_DRIVER st7789s_lcm_drv =
- .name = "st7789s",
- .set_util_funcs = lcm_set_util_funcs,
- .get_params = lcm_get_params,
- .init = lcm_init,
- .suspend = lcm_suspend,
- .resume = lcm_resume,
- .update = lcm_update,
- .compare_id = lcm_compare_id
复制代码 |
