格式化下载,开机的时候,在快要进入logo界面的时候就卡住了,电流一直停留在24没有变化,从开机到画面卡住的log如下,请帮忙分析下是什么问题。谢谢!
[PWRAP] pwrap_init [PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=0 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=1 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=2 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=3 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=4 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=5 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=6 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] pass,index=7 rdata=5AA5
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=8,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=9,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=10,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=11,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=12,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=13,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=14,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=15,rdata=B54B
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=16,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=17,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=18,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=19,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=20,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=21,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=22,rdata=6A97
[PWRAP] _pwrap_init_sistrobe [Read Test] fail,index=23,rdata=6A97
[PWRAP] _pwrap_init_reg_clock
[PMIC_WRAP]wrap_init pass,the return value=0.
[platform_vusb_on] PASS
[USBD] USB PRB0 LineState: 0
[PLFM] Keep stay in USB Mode [pmic6323_init] Preloader Start..................
[pmic6323_init] PMIC CHIP Code = 8227
pl pmic powerkey Press [pmic6323_init] powerKey = 1
[pmic6323_init] is USB in = 45060
[pmic6323_init] Done................... ONEKEY_REBOOT_NORMAL_MODE_PL OK
[PLFM] Init PWRAP: OK(0) [PLFM] Init PMIC: OK(0)
[PLFM] chip[CA01]
[BLDR] Build Time: 20150911-174044
==== Dump RGU Reg ========
RGU MODE: 4D
RGU LENGTH: FFE0
RGU STA: 0
RGU INTERVAL: FFF RGU SWSYSRST: 0
==== Dump RGU Reg End ====
RGU: g_rgu_satus:0
MTK_wdt_mode_config mode value=10, tmp:22000010
PL P ON
WDT does not trigger reboot
mtk_wdt_mode_config mode value=51, tmp:22000051
kpd read addr: 0x0502: data:0x4005
Enter mtk_kpd_gpio_set!
kpd debug column : 107, 0, 109, 0, 0, 0, 0, 0
kpd debug row : 110, 111, 112, 0, 0, 0, 0, 0
after set KP enable: KP_SEL = 0x1 !
mt_usb_calibraion: input_reg = 0xE0
mt_usb_calibraion: term_vref = 0x0, clkref = 0x0, vrt_vref = 0x1,
mt_usb_phy_calibraion: case_set 3, input_reg = 0x1
mt_usb_phy_calibraion: temp_test = 0x44
mt_usb_phy_calibraion: temp_added = 0x4
mt_usb_phy_calibraion: temp_added = 0x5
mt_usb_phy_calibraion: final temp_test = 0x54
[RTC] get_frequency_meter: input=0x0, ouput=5
[RTC] get_frequency_meter: input=0x0, ouput=3967
[RTC] get_frequency_meter: input=0x0, ouput=0
[RTC] bbpu = 0x1, con = 0x427
[RTC] RTC_CON=0x427
[RTC] RTC_SPAR0=0x40
[RTC] irqsta = 0x0, pdn1 = 0x0, pdn2 = 0x201, spar0 = 0x40, spar1 = 0x800
[RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1
[RTC] bbpu = 0x1, con = 0x426
power key is pressed
[PLFM] Power key boot!
[RTC] rtc_bbpu_power_on done
[EMI] DDR1
[EMI] eMMC/NAND ID = 98,BC,90,66,0,0,0,0,0
[EMI] MDL number = 0
[EMI] EMI clock = 200
[EMI] [Training] DQSI = 0x40, Window = 39
[EMI] [Training] dq_in_dly_strart = 0x0, byte_setup_start = 0x6,, byte_dly_start = 0x0
[EMI] [Training] DQSI = 0x60, Window = 39
[EMI] [Training] DQSI = 0x80, Window = 39
[EMI] [Training] DQSI = 0xA0, Window = 41
[EMI] DQSI = 0x70, (0x40, 0xA0)
[EMI] Window = 41
[EMI] R0 cal pass
[EMI] [Training] DQSI = 0xA0, Window = 39
[EMI] DQSI = 0x70, (0x40, 0xA0) [EMI] Window = 39
[EMI] R1 cal pass
[EMI] DQSI = 0x00010A00
[EMI] DQSA = 0x006A006A
[EMI] DQSB = 0x006A006A
[EMI] DQSC = 0x006A006A
[EMI] DQSD = 0x006A006A
[EMI] DQSU = 0x006A006A
[EMI] DQSV = 0x006A006A
[EMI] DLLV = 0x8A8A8A8A
[EMI] IDLA = 0x00000000
[EMI] IDLI = 0x10101010
[EMI] IDLJ = 0x0F0F0F0F
[EMI] ODLA = 0x00000000
[EMI] CONI = 0x00334020
[EMI] CONJ = 0x403E2282
[EMI] CONK = 0x110B0020
[EMI] CONL = 0x00025084
[EMI] CONN = 0x00330557
[EMI] GEND = 0x00030000
[EMI] DRCT = 0x00000000
[EMI] DRVA = 0x66666666
[MEM] complex R/W mem test pass
Recognize NAND: ID [98 BC 90 66 ], Device Name [TYBC0A111557KC], Page Size [4096]B Spare Size [128]B Total Size [512]MB
[NAND]: oobsize: 80
Init bmt table, size: 80
bmt count: 80, system count: 1968
[load_bmt_data]: begin to search BMT from block 0x7FF
[load_bmt_data]: bmt_index=0x7FF, start=0x7B0, pool_size=0x50,
[load_bmt_data]: bmt_index=0x7FF-- Skip bad block: 2047
[load_bmt_data]: bmt_index=0x7FE-- Skip bad block: 2046
[load_bmt_data]: bmt_index=0x7FD-- Match bmt signature @ block: 0x7FD
BMT Checksum is: 0x1
Valid BMT, version v1
bmt found at block: 2045, mapped block: 0
Load bmt data success @ block 0x7FD
BMT v1. total 0 mapping:
[PLFM] Init Boot Device: OK(0)?
我知道答案
回答被采纳将会获得 5 RD币 已有1人回答
