libpng error: Ir[D3][1E]: invalid chunk type Frameworks/base/packages/SystemUI/res/layout/Battery_low.xml:46: error: Error: No resource found that matches the given name (at 'src' with value '@drawable/battery_low_battery').
frameworks/base/packages/SystemUI/res/layout-sw600dp/compat_mode_help.xml:20: error: Error: No resource found that matches the given name (at 'background' with value '@drawable/compat_mode_help_bg').
frameworks/base/packages/SystemUI/res/layout-sw600dp/compat_mode_help.xml:26: error: Error: No resource found that matches the given name (at 'background' with value '@drawable/compat_mode_help_divider_top').
frameworks/base/packages/SystemUI/res/layout-sw600dp/compat_mode_help.xml:40: error: Error: No resource found that matches the given name (at 'src' with value '@drawable/compat_mode_help_diagram').
frameworks/base/packages/SystemUI/res/layout-sw600dp/compat_mode_help.xml:48: error: Error: No resource found that matches the given name (at 'background' with value '@drawable/compat_mode_help_divider_bottom').
frameworks/base/packages/SystemUI/res/layout-sw600dp/compat_mode_help.xml:58: error: Error: No resource found that matches the given name (at 'src' with value '@drawable/compat_mode_help_icon').
frameworks/base/packages/SystemUI/res/layout/global_screenshot.xml:24: error: Error: No resource found that matches the given name (at 'background' with value '@drawable/screenshot_panel').
frameworks/base/packages/SystemUI/res/layout/intruder_alert.xml:30: error: Error: No resource found that matches the given name (at 'background' with value '@drawable/alert_bar_background').
