刚接触MTK, 请帮忙看下编译情况,不知道是不是是哪儿出了问题
make custom=LOKYEE61M_11C GPRS new job=4
copy /y make\LOKYEE61M_11C_gprs.mak make\
ReMOVe WIFI source codes.
Skip 3rd party feature license check for custom release projects!!!
perl tools\chk_verno.pl MAUI.11C.W13.52.MP.V2.F5
perl tools\chk_env.pl make LOKYEE61M_11C_gprs.mak -customer LOKYEE61M_11C
Start checking MTK build environment......
OS is Windows 2000 or XP. => [OK]
Compiler in makefile is rvct!
RVCT VERSION in makefile is correct!
ARMCC version is RVCT3.1 [OK] , Build number is 569 [OK] .
TCC version is RVCT3.1 [OK] , Build number is 569 [OK] .
ARMLINK version is RVCT3.1 [OK] , Build number is 569 [OK] .
FROMELF version is RVCT3.1 [OK] , Build number is 569 [OK] .
ARMAR version is RVCT3.1 [OK] , Build number is 1021 [OK] .
C:\Program Files\ARM\ADSv1_2\licenses\license.dat is not existed!
Perl version is 5.008006 . => [OK]
Shell is cmd.exe. => [OK]
Excel version is 2000 or above. => [OK]
MTK build environment is ready!
makefile check is done
Processing makefile_list.log
Cleaning directories under .\build\LOKYEE61M_11C\gprs ...
D:\1-platform\MTK\MTK6261_SW\MT61M_GEMINI\MT61M_GEMINI\build\LOKYEE61M_11C\log\c
kSysDrv.log
拒绝访问。
--------------Copying Base file form PLUTO_MMI-----------------
------------------------------DONE------------------------------
-------------Copying Project file form Project folder-------------
-----------------generate Resgen include path----------------
系统找不到指定的路径。
另一个程序正在使用此文件,进程无法访问。
-----------------make and run resgen_xml.exe----------------
-----------------make resgen_xml.exe----------------
Warning: Q3910W: Old syntax, please use '--bin'.
Warning: Q3910W: Old syntax, please use '--output'.
make: *** [mmi_service.lib] Error 1
