我们目前在调试hi3519,用的sensor是索尼imx302
目前采集中断有,
[VIU] Version: [Hi3519V100_MPP_V1.0.3.0 B030 release], Build Time: [Jun 27 2016, 21:25:32]
VI-VPSS is online.
-----MODULE PARAM--------------------------------------------------------------
detect_err_framedrop_err_framestop_int_level
10 0 0
-----VI DEV ATTR---------------------------------------------------------------
Dev IntfMWkMCommsk0ComMsk1 ScanM AD0 AD1 AD2 AD3 Seq DPath DType DRev CapX CapYCapWCapH
0 LVDS 1Mux fff00000 0 P-1-1-1-1 N/A ISP RGB N 0 019361216
-----VI HIGH DEV ATTR---------------------------------------------------------------
DevInputMWkMComMsk0ComMsk1 ScanM AD0 AD1 AD2 AD3 Seq CombM CompM ClkMFix FldP DPath DType DRev CapX CapYCapWCapH
-----VI PHYCHN ATTR------------------------------------------------------------
PhyChn CapX CapYCapWCapHDstWDstH CapSel Mirror Flip IntEn PixFom SrcRat DstRat Comp
0 0 01936121619361216 both N N YSP420 -1 -1 N
-----VI PHYCHN STATUS 1----------------------------------------------------------
PhyChnDev IntCntVbFailLosIntTopLosBotLos BufCntIntTSendTFieldStride
0 0 5611 0 0 0 0 0 34 0 frm 1936
-----VI PHYCHN STATUS 2---------------------------------------------------------
PhyChn MaxIntT IntGapT MaxGapT LIntCntThrCnt AutoDis CasAutDTmgErr ccErrN IntRat
0 42 31220 31225 0 0 0 0 0 0 33
-----VI OTHER ATTR------------------------------------------------------------
Flash Mode StartTimeDuraTIMEInterVal CapIdx EnableFlashedNum
-- Once 0 0 0 0 N 0
CSC Type HueValContrVal LumaValStatuVal TVMode
-- 709 50 50 50 50 N
DCI En BlackGain ContrGain LightGain
-- Y 32 32 32
-----VI WDR ATTR---------------------------------------------------------------
ModeBufNum DstW DstHPoolId VcNumDesNum StatebCompress
NONE 0 1936 1216 -1 0 0 Init N
-----VI WDR DES STATUS----------------------------------------------------------
Idx IntGap IntCntCcERRCnt
-----VI WDR SRC STATUS----------------------------------------------------------
Idx IntGap IntCntCcErrCnt
-----VI WDR COMBINE STATUS--------------------------------------------------------
0 0 0
VPSS没有数据。
~ # cat /proc/umap/vpss
[VPSS] Version: [Hi3519V100_MPP_V1.0.3.0 B030 Release], Build Time[Jun 27 2016, 21:25:32]
VI-VPSS is online.
-------------------------------MODULE PARAM-----------------------------------------------------------------
rfr_frame_comp bOneBufferforLowDelay
Y N
-------------------------------VPSS GRP ATTR----------------------------------------------------------------
GrpID MaxW MaxHPixFmt DieMode DciEn NrEnHistEn
0 1936 1216 SP420 nodie N Y N
-------------------------------VPSS CHN PARAM---------------------------------------------------------------
GrpID ChnID ChnSp
-------------------------------VPSS CHN ATTR----------------------------------------------------------------
GrpIDPhyChnIDEnable SpEn FrmWkEnMirrorEnFlipEnSrcFRateDstFRate
0 0 Y N N N N -1 -1
-------------------------------VPSS PHY CHN MODE-----------------------------------------------------------
GrpIDPhyChnID WorkMode WidthHeightDoublePixfmtCompreSSMode
0 0 USER 1936 1216 N SP420 1
-------------------------------VPSS EXT-CHN ATTR------------------------------------------------------------
GrpID ExtChnIDEnableSrcChn WidthHeightSrcfrcDstfrcPixfmt
-------------------------------VPSS EXT-CHN CROP ATTR-------------------------------------------------------
GrpID ExtChnIDCropEnCoorType CoorX CoorY WidthHeight
-------------------------------VPSS CHN CROP INFO-----------------------------------------------------------
GrpID ChnIDCropEnCoorType CoorX CoorY WidthHeight TrimX TrimY TrimWid TrimHgt
-------------------------------VPSS CHN WORK STATUS---------------------------------------------------------
GrpID ChnID WorkMode Depth SendOkbConfident bDouble
0 0 USER 0 0 N N
-------------------------------VPSS CHN OUTPUT RESOLUTION---------------------------------------------------
GrpID ChnIDEnable WidthHeightPixfmtCompressMode FrameRate
0 0 Y 1936 1216 SP420 1 0
-------------------------------VPSS NR PARAM----------------------------------------------------------------
GrpID REFCompressCurNRIntCurNRVer
0 RFR Y B V2
-------------------------------VPSS CHN ROTATE INFO---------------------------------------------------------
GrpID ChnIDRotate
-------------------------------VPSS CHN LDC ATTR------------------------------------------------------------
GrpID ChnIDEnableViewType Xoffset Yoffset Ratio
-------------------------------VPSS CHN FISHEYE ATTR--------------------------------------------------------
GrpIDChnID Enable MntMode RgnNum BgEnableBgColor LMF HOffset VOffset TCoef
-------------------------------VPSS CHN FISHEYE REGION ATTR-------------------------------------------------
GrpIDChnID RgnIndex ViewMode InRadius OutRadiusPan Tilt HorZoom VerZoom OutX OutY OutW OutH
-------------------------------VPSS CHN LOWDELAY ATTR-------------------------------------------------------
GrpID ChnIDEnable LineCnt OneBufEnable OneBufAddr
-------------------------------DRV WORK STATUS--------------------------------------------------------------
StartSuc0 StartSuc1 LinkInt NodeInt StartErr0NodeIdErr0 StartErr1NodeIdErr1 BusErr
0 0 0 0 0 0 0 0 0
-------------------------------DRV ONLINE INT STATUS--------------------------------------------------------
FrmCntPerSec FrMstartCnt FrmErrCntFrmFlowCnt Chn0LowDelayCnt Chn1LowDelayCnt Chn2LowDelayCnt
0 6494 0 0 0 0 0
-------------------------------DRV NODE QUEUE---------------------------------------------------------------
FreeNum WaitNumBusy00Busy01 Sel0Busy10Busy11 Sel1
33 0 0 0 0 0 0 0
-------------------------------INT WORK STATUS--------------------------------------------------------------
CntPerSecMaxCntPerSec CostTm MostCostTmCostTmPerSec MCostTmPerSec
33 33 426 455 12727 13661
cat /dev/logmpp 一直在打印如下信息,请问这个错误说明什么,应该怎么查?
3>[vpss] [Func]:VpssOnLineCcIntErr [Line]:1314 [Info]:<3>[vpss] vpss frame error, u32RawIntStatus = 0x600!!!
<3>[vpss] [Func]:VpssOnLineCcIntErr [Line]:1300 [Info]:<3>[vpss] vpss int without eof!!!
<3>[vpss] [Func]:VpssOnLineCcIntErr [Line]:1314 [Info]:<3>[vpss] vpss frame error, u32RawIntStatus = 0x600!!!
你们碰到过类似问题吗?
我知道答案
回答被采纳将会获得 5 RD币 已有0人回答
