The HDK default use the 500mAh Battery anddefault charging current is 300mAh.
The battercapacityis define in project folder /inc/cust_battery_meter.h
/* Qmax for battery */
#define Q_MAX_POS_50 488
#define Q_MAX_POS_25 479
#define Q_MAX_POS_0 356
#define Q_MAX_NEG_10 293
#define Q_MAX_POS_50_H_CURRENT 483
#define Q_MAX_POS_25_H_CURRENT 466
#define Q_MAX_POS_0_H_CURRENT 131
#define Q_MAX_NEG_10_H_CURRENT 113
Note: The discharging current depend on battery capacity and loading.
For more charging efficiency and precise fuel gauge calculation, user need to manually
customize the cust_battery_meter_table.haccording to specific battery parameters.
For quick start, user could estimate the battery capacity based on different
temperature and loading.
If change the batterycapacity,also need to modify charging current.
Please refer related itemthe of FAQ.
"The battery specifications of MT2523 HDK"
"How to configure MT2523 HDK charging current"
"How about the charging current define of MT2523 HDK"
