[DESCRIPTION]
各类图片资源所占大小 [SOLUTION]
About the ROM size of MMI image resource:
1.JPG or GIF will be the original size+8bytes(resource header)
2.PNG will be converted into internal for mat,and the size will be similar to the original one+8bytes(resource header).
3.BMP or PBM may be converted into internal for mat,and the size will dependent on the content.However,it will beless than or equal to the original size+8bytes(resource header).
By the way,if you want to see the real ROM size for each image after resource generation,please checkmcu\plutommi\Customer\Resgenerator\image_resource_usage.txt.
There is a column,"Size",which will record the real size for each image.
