Describe the hardware layout, and how it works.
However, it should not describe which particular hardware configuration you're in.
File path
alps/kernel-4.4/arch/arm64/boot/dts/MediaTek/MT8167.dtsi
alps/kernel-4.4/arch/arm64/boot/dts/mediatek/xxx.dts(xxx is your project name)
DTSI file setting
You can set the msdc base register, interrupt, clock in the dtsi file.mmc0 is emmc, mmc1 is sd card.
