作者:韩宇 时间:2005-6-30
文档内容: -》如何编译 -》开发目录结构解析 -》开发工具的了解 -》程序入口,程序导读 -》MMI的制作
MTK为 MediaTek公司提供的GSM软件方案。它包含5个部分:
-》L1协议 -》设备驱动 -》协议栈 -》MMI -》WAP应用 MediaTek为用户提供3个工具: -》Catcher -》META -》MCT MTK软件架构图: file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps6AE5.tmp.jpg 下面3个部分组成该软件方案: 1. MS Executable Software, which is the software running on the MS, includes the following modules - OS: Nucleus OS. - L1 Protocol Stack: GSM physical layer. - Drivers: device driver, like SIM, UART, GPIO, etc. - L2/L3 protocol stack: GSM protocol stack layer. - MMI: man-machine interface. - WAP: Wireless application protocol. - JAVA: J2ME Software 2. The Mobile Engineering Testing Architecture, also known as META 3. Catcher -》OS MediaTek采用Nucleus OS实时操作系统。KAL OS层为MediaTek’s软件和Nucleus操作系统的接口。它为任务提供许多系统服务函数,比如计时器,队列,内存管理,事件等等。 -》L1 Protocol Stack The physical layer or Layer 1 supports the transfer of bit streams on the radio medium according to the Technical Specifications of the 05-series. It provides service to upper layers and control the mapping and scheduling between the logical and physical channels. The TDMA framing and radio control parts are also implemented. file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps6AF6.tmp.jpg � Layer 1 Asynchronous: handles the message request from upper layers and forward the result generated by layer 1 to upper layer. � Surrounding Cell Engine: handles the neighbor cell power measurement and neighbor cell synchronization information acquisition. � Layer 1 Control: handles the TDMA scheduling on the radio environment, including timing advance and power control command from serving base station. � Layer 1 Driver: handles the DSP and Radio control
-》Drivers MCU外围设备的驱动,如下: � SIM: Subscriber Identity Module � UART: Universal Asynchronous Receiver/Transmitter � SPI: Serial Port Interface � LCD: Liquid Crystal Display � GPIO: General Purpose Input/Output � gpt: General Purpose Timer � RTC: Real Time Clock � WDT: Watch Dog Timer � PWM: Pulse Width Modulation � Alerter � PMIC: Power Management IC � AUX task: Auxiliary task � ADC Sched.: Analog to Digital Converter Scheduler � USB task: The USB 1.1 protocol and driver � IrDA task: The IrDA and driver � Camera: Camera driver for integrating with 3rd party camera module � MSDC: Memory card driver, supporting SD, MMC cards and Memory Stick � JPEG Decoder: Software for controlling hardware JPEG decoder
file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps6B07.tmp.jpg -》L2/L3/L4 Protocol Stack 这部分包含大量的GSM/ GPRS需求以及提供一个优秀的GSM/GPRS平台给应用程序。本地MMI和远程PC通过AT命令可以方便的使用该软件平台。详细的结构如下: � RMI: 远程MMI,比如PC端,可以使用AT命令通过串口与协议栈进行通讯。 � FMI: Feature rich MMI, described in the above section. This is the production co-worked with Pixtel.
� L4: Layer 4. L4 is a task through which FMI and/or RMI communicate with PS. L4 task includes several sub-modules. � ATCI: AT command interpreter. Interprets the AT commands from PC side and commands the L4C to do the relative actions. � L4A: L4 adaptation layer for FMI. The SAP between FMI and L4A is primitive base. � L4C: L4 control entity. Handles all applications request and response. � UEM: User equipments adaptation. Adaptation for drivers, like Keypad, LED, GPIO, Audio…etc. � PHB: Phone book management. Handles the phone books related processing, like: sorting…etc. � SMU: SIM management unit. Handle the security management, and STK. � CSM: Circuit switching protocol stack management. � RAC: Registration access control. � SMSAL: Short message service application layer. � TCM: Terminal context management. � NVRAM: Non-volatile RAM. This is adaptation layer to flash memory. � SIM: Subscriber identity module. Handle SIM behavior as ETSI 11.11 description.
� DATA: Circuit switched data service. Data task includes several sub-modules. � FAX: Group 3 Facsimile. � TDT: Transparent circuit switching data. � L2R: Layer 2 relay protocol for non-transparent circuit switching data. � RLP: Radio link protocol for non-transparent circuit switching data. � CC: Circuit-switched call control. � SS: Supplementary service.
� SMS: Short message service.
� SM: Session management.
� MM/GMM: Mobility management/GPRS mobility management.
� SNDCP: Subnetwork dependent convergence protocol.
� LLC: Logical link control.
� RR: Radio resource management. RR task includes several sub-modules. � RRM: Handles cell selection and PLMN selection. � RMPC: Handles the procedures in Idle/Dedicated state including the surrounding cell scheme and measurement reporting. � LAPDM: Handles the procedure defined in GSM layer 2. � RLC: Radio link control protocol. � MAC: Medium access control protocol. � MPAL: Adaptation layer for RR and L1A.
� PPP: Point to Point protocol layer. This is client PPP layer.
file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps6B18.tmp.jpg -》MMI 这部分包括用户的接口架构,应用以及和协议栈的通讯。
file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps6B19.tmp.jpg � OSL: OS adaptation layer � Task: communication with L4 task. � File system: communication with storage device. � GUI: This covers that � Theme � UI component � Category screen � Font � T9 or Ezi input method. � Access LCD driver. � Customization tool. � Application � Phonebook � Messages (SMS, EMS 4.0, CB) � Call history � Setting. (Phone setting, network setting, security setup) � 5 kinds of user profiles � Fun and games � Organizers � Shortcuts � In call management. � Interrupt events, like charging , alarm.
-》WAP 2. 如何编译
参考文档:wcr-MTK_MakeBuild_Design_Customer_040930.pdf 操作系统:Windows 2000, Wi NXP. 推荐Windows 2000 with SP2 or later. 编译器:ADS (Arm Developer Suite) v1.2. Perl解析:ActivePerl.推荐使用ActivePerl 5.6.1版本 -》make.bat
It will parse command line to determine project name, platform, and action. Meanwhile, checking \make directory exist or not and checking command line argument is legal or not. After checking, to execute build script GSM2.mak build script to perform action. 使用: Usage: Make [custom=customername] <project> <platform> <action> [module]" custom = Monza project = GPRS (GSM only) action = new (clean, scan, compile, link) (default) = update (scan, compile, link) = remake (compile, link) = clean (clean) module = component module name (nucleus, l1, ...)
Example: To make/build new GPRS project, clean all old objects, libraries, and log files etc., the new action also creates necessary directories and re MOVes all temporary files, and flushes log files automatically. d:>\pvcs\maui\mcu\Make custom=Monza GPRS new To update project dependency, and compile changed modules, link. Notice that, update and remake action won’t remove temporary files, and flush log file. Build results will be append after last log file. d:>\pvcs\maui\mcu\Make custom=Monza GPRS update To recompile changed files, and link d:>\pvcs\maui\mcu\Make custom=Monza GPRS remake To clean all objects, temporary files, libraries, and executable binaries. Meanwhile log file will also be flushed. d:>\pvcs\maui\mcu\Make custom=Monza GPRS clean To clean dedicated init modules’ objects libraries. Meanwhile log file will also be flushed. d:>\pvcs\maui\mcu\Make custom=Monza GPRS clean init
-》how to customize your build environment !!!To add some modules into or remove some modules from the building procedure. To complete this kind of configuration, it is necessary to understand the following variables in the make file Monza_GPRS.mak � COMPLIST: list all source code modules can be built to .lib. In initial custom release, COMPLIST should be the sum of CUS_REL_SRC_COMP and CUS_REL_PAR_SRC_COMP. The following is the initial setting in custom release. ifeq ($(strip $(CUSTOM_RELEASE)),TRUE) COMPLIST = $(strip $(CUS_REL_SRC_COMP)) COMPLIST += $(strip $(CUS_REL_PAR_SRC_COMP)) endif � CUS_REL_MTK_COMP: list all modules provided with .lib only. These .lib are put in \mcu\mtk_l IBS. � If you want to add a source module 1. add the module "xyz" (in lower case) into COMPLIST. ifeq ($(strip $(CUSTOM_RELEASE)),TRUE) COMPLIST = $(strip $(CUS_REL_SRC_COMP)) COMPLIST += $(strip $(CUS_REL_PAR_SRC_COMP)) COMPLIST += xyz endif 2. add a folder “mcu\make\xyz” for xyz.lis, xyz.inc, xyz.pth, xyz.def. -》编译生成的文件以及log 1.编译的log在目录C:\code_100\build\a100中的MT6218B.log。目录C:\code_100\build\a100\log下的log文件为各个模块编译时生成的log。 2.编译生成的bin为C:\code_100\build\a100下的a100_PCB01_gprs_MT6218B_FN.W05_12.bin。 3.编译生成的目标文件在C:\code_100\build\a100\gprs\MT6218Bo目录中。
3. 开发目录结构解析参考文档:wcr-MTK_MakeBuild_Design_Customer_040930.pdf 目录结构: 目录名称 | | | Generated object, libraries, executable binary and log files directory. The directory will be created automatically. For details, see “Generated Objects, Libraries, Executable Binary and Log Files” sections. | | Main build scripts and option file directory.
| | Nucleus Plus RTOS source codes directory include C, Assembly, and included header files.
| | System boot and hardware dependent initialization directory. Meanwhile, exception handling, and interrupt service routine dispatcher are also placed here.
| | System boot, initialization, layer1, and driver modules common included header files directory.
| | Layer 1 source codes directory.
| | Driver modules source codes directory.
| | Custom’s task/modules’ sources and header files
| | | | Miscellaneous tools used in build/make and customer release procedures
| | Component libraries provided my MediaTek.
| | | | Source code for keeping version information
4. 开发工具的了解参考目录《工具》中的文件。 工具: -》Catcher Catcher is a PC-side tool for MTK GSM/GPRS Products. The main purpose of Catcher is for logging primitives and debug information. Engineers can use Catcher to analyze the behavior of mobile phones. -》META META (Mobile Engineering Testing Architecture) is designed to provide the functionality of RF testing, NVRAM access testing, speech related testing of advanced feature – melody and voice memo. -》MCT UI制作工具,包括菜单制作,图片制作,字体制作等等。 file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps6B2A.tmp.jpg
5. 程序入口,程序导读 -》MMI任务入口: C:\code_100\plutommi\mmi\Framework\Tasks\TasksSrc 中文件MMITask.c函数MMI_task。 -》MMI任务的建立: C:\code_100\plutommi\mmi\Framework\Osl\OslSrc 中文件pixtelMMI.c函数WinMain调用InitApplication函数,在该函数中建立MMI任务,建立任务的接口函数为:osl_create_task。 -》MMI任务信息: {"MMI TASK"(任务名称), "MMI Q"(队列名称), 127(优先级), 4096(堆栈大小), MAX_PRT_NODES(队列结点个数), MMI_task(任务入口)}, -》MMI模块入口: 目录C:\code_100\plutommi\mmi中为MMI各个模块的代码。比如闹钟模块,源代码在C:\code_100\plutommi\mmi\Alarm\AlarmSrc中,头文件在C:\code_100\plutommi\mmi\Alarm\AlarmInc中。首先找到初始化闹钟的函数AlmInit,该函数定义在选择闹钟菜单项时调用函数HighlightAlmMenu进入闹钟功能。 6. MMI的制作 参考文档: 文件名 | | API For Writing Applications Using Pixtel MMI Platform.pdf
| | Writing Applications Using Pixtel MMI Platform.pdf | |
MMI 2.0 Design DOC和MMI Design Doc目录中对MMI中的各个模块进行描述,因此在研究某一模块时可以在这两个文件夹中找到该模块的介绍,通过这些文档可以加速对该模块编码的理解。 MMI的模块在路径C:\code_100\plutommi中。 -》设计一个应用程序的流程如下: - 1. Write an Initialization function to register the various event handlers. 2. Write a populate function to register various string and image elements for the application. 3. Write highlight handlers for function registered.菜单项的功能,当用户选择菜单项后执行的函数。 4. Write the Entry functions。入口函数 5. Write the Exit function。出口函数 6. Write the business logic to call between various entry functions. |
