The NZ5708S is a SP8T (single-pole eight-throw) antenna switch module, designed for
multimode broadband cellular applications, supporting UMTS, TD-SCDMA and LTE
from 100MHz to 3.0GHz. The RF performance is optimized with low insertion loss and
low harmonics to guarantee the stringent requirements of all 3G/LTE standards.
The NZ5708S integrates a SP8T switch and a GPIO controller on a single SOI chip.
Equipped with 8 symmetrical RF ports for UMTS/TD-SCDMA/LTE, the NZ5708S is providing the most versatile combinations of operation in different modes.
Low insertion loss is exhibited in every path in NZ5708S, from the antenna port to any
of the RF port, with high isolation between both OPPOsite and adjacent paths. In addition, the NZ5708S also achieves excellent linearity performance, suitable for 3G and
LTE applications. The internal decoder allows convenient GPIO connections and supports digital control signals. The SOI architecture in NZ5708S reMOVes the external DC
blocking capacitors to save the cost and PCB space for end customers.
The NZ5708S is encapsulated in a compact 2mm x 2mm LGA package, with low profile of 0.55mm. This product is RoHS-compliant and halogen free.
The NZ5708S is rated to Moisture Sensitivity Level 3(MSL3) at 260 °C per JEDEC JSTD-020
• Broadband support 0.1-3.0GHz
• Compatible with UMTS, TDSCDMA, and LTE
• Advanced SOI process
• Low insertion loss
• Excellent linearity
• 8 symmetrical ports
• GPIO control interface
• No external DC blocking capacitor
required
• Ultra small LGA footprint, 2mm x
2mm x 0.55mm, 14-pin
• ESD Class 1C
• Green product
Application
• UMTS/TD-SCDMA/LTE Cellular
handsets and data cards
• Diversity for UMTS/LTE
