目前i2c通信正常,使用gstream测试时,提示MIPI eRRCtrl错误,不清楚什么意思,有没有熟悉的大神指导一下。日志如下:- [root@rockchip:/]# gst-launch-1.0 v4l2src --gst-debug-level=3 device=/dev/video2
- ! videoconvert ! video/x-raw,format=NV12,width=800,height=480 ! queue ! kmssink
- cat: read error: Invalid argument
- [ 13.921079] rk_gmac-dwmac ff290000.ethernet: rk_get_eth_addr: mac address: 62:a9:a3:68:95:da
- [ 13.929531] eth0: device MAC address 62:a9:a3:68:95:da
- Carmachine: Update media resource.
- [ 15.108102] SC4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 15.113947] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- [ 15.120237] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 15.126075] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- [ 15.132343] sc4236.ov_camera_module_enum_frameintervals(991) DEBUG: 0
- [ 15.138781] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x2
- [ 15.144605] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x2
- [ 15.150877] sc4236.ov_camera_module_enum_frameintervals(991) DEBUG: 1
- [ 15.157316] sc4236.ov_camera_module_s_fmt(292) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.164707] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.172623] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.181489] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.189409] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 15.196715] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.205572] sc4236.ov_camera_module_set_active_config(67) DEBUG:
- [ 15.211673] sc4236.ov_camera_module_s_frame_interval(363) DEBUG: 1/30 (30fps)
- [ 15.218809] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 15.226114] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.234970] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.242881] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 15.250186] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.259049] sc4236.ov_camera_module_set_active_config(67) DEBUG:
- [ 15.265145] sc4236.ov_camera_module_g_ctrl(574) DEBUG: id 0x981981
- [ 15.271417] sc4236.ov_camera_module_g_ctrl(594) DEBUG: RK_V4L2_CID_VBLANKING 7251
- [ 15.278978] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 15.284804] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- [ 15.291087] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 15.296920] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- [ 15.303185] sc4236.ov_camera_module_enum_frameintervals(991) DEBUG: 0
- [ 15.309623] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x2
- [ 15.315449] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x2
- [ 15.321720] sc4236.ov_camera_module_enum_frameintervals(991) DEBUG: 1
- [ 15.328162] sc4236.ov_camera_module_s_fmt(292) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.335553] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.343465] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.352334] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.360246] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 15.367557] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.376420] sc4236.ov_camera_module_set_active_config(67) DEBUG:
- [ 15.382510] sc4236.ov_camera_module_s_frame_interval(363) DEBUG: 1/30 (30fps)
- [ 15.389643] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 15.396948] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.405804] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.413715] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 15.421019] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.429883] sc4236.ov_camera_module_set_active_config(67) DEBUG:
- [ 15.435980] sc4236.ov_camera_module_g_ctrl(574) DEBUG: id 0x981981
- [ 15.442243] sc4236.ov_camera_module_g_ctrl(594) DEBUG: RK_V4L2_CID_VBLANKING 7251
- [ 15.449815] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 15.455641] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- [ 15.461924] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 15.467766] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- Setting pipeline to PAUSED ...
- [ 15.497586] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 15.505663] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- [ 15.511971] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 15.518052] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- [ 15.524328] sc4236.ov_camera_module_enum_frameintervals(991) DEBUG: 0
- [ 15.530782] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x2
- [ 15.536741] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x2
- [ 15.543152] sc4236.ov_camera_module_enum_frameintervals(991) DEBUG: 1
- [ 15.549598] sc4236.ov_camera_module_s_fmt(292) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.557003] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.564907] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.573772] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.581684] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 15.589394] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.598651] sc4236.ov_camera_module_set_active_config(67) DEBUG:
- [ 15.604744] sc4236.ov_camera_module_s_frame_interval(363) DEBUG: 1/30 (30fps)
- [ 15.612263] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 15.619950] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.629203] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 15.637458] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 15.644758] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 15.653630] sc4236.ov_camera_module_set_active_config(67) DEBUG:
- [ 15.659729] sc4236.ov_camera_module_g_ctrl(574) DEBUG: id 0x981981
- [ 15.666001] sc4236.ov_camera_module_g_ctrl(594) DEBUG: RK_V4L2_CID_VBLANKING 7251
- Pipeline is live and does not need PREROLL ...
- [ 15.674604] v4l2_enum_fmt_cap(1457) ERR: index 16
- Setting pipeline to PLAYING ...
- 0:00:00.610458041 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- New clock: GstSystemClock
- 0:00:00.629706583 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.654330541 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.676411750 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.698690708 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.720785917 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.743054375 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.765160958 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.787408417 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.809532208 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.831778792 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.853920667 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.876188250 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.898271500 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.920528292 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.942650625 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.964916167 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:00.987021000 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.009278375 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.031398667 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.053664792 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.075765833 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.098027000 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.120138250 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.142403792 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.164513875 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.186770083 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.208889792 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.231138417 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- 0:00:01.253266583 310 0x1570800 ERROR v4l2 gstv4l2object.c:1893:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
- [ 16.349374] sc4236.ov_camera_module_enum_frameintervals(991) DEBUG: 0
- [ 16.360441] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x2
- [ 16.366277] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x2
- [ 16.372544] sc4236.ov_camera_module_enum_frameintervals(991) DEBUG: 1
- [ 16.378986] sc4236.ov_camera_module_s_fmt(292) DEBUG: 2304x1440, fmt code 0x300a
- [ 16.386385] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 16.394289] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 16.403152] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 16.411068] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 16.418383] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 16.427252] sc4236.ov_camera_module_set_active_config(67) DEBUG:
- [ 16.433344] sc4236.ov_camera_module_s_frame_interval(363) DEBUG: 1/30 (30fps)
- [ 16.440477] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 16.447782] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 16.456645] sc4236.ov_camera_module_find_config(122) DEBUG: 2304x1440, fmt code 0x300a
- [ 16.464549] sc4236.ov_camera_module_find_config(128) DEBUG: frame interval 1/30
- [ 16.471856] sc4236.ov_camera_module_find_config(160) DEBUG: found matching config 2304x1440_30fps
- [ 16.480720] sc4236.ov_camera_module_set_active_config(67) DEBUG:
- [ 16.486817] sc4236.ov_camera_module_g_ctrl(574) DEBUG: id 0x981981
- [ 16.493086] sc4236.ov_camera_module_g_ctrl(594) DEBUG: RK_V4L2_CID_VBLANKING 7251
- 0:00:01.430084542 310 0x1570800 WARN v4l2bufferpool gstv4l2bufferpool.c:754:gst_v4l2_buffer_pool_start:<v4l2src0:pool:src> Uncertain or not enough buffers, enabling copy threshold
- [ 16.518597] sc4236.ov_camera_module_s_power(490) DEBUG: 1
- [ 16.528122] sc4236.pltfrm_camera_module_s_power(1544) DEBUG: on
- [ 16.534046] sc4236.pltfrm_camera_module_set_pin_state(1490) DEBUG: set GPIO #11 ('rockchip,pwr-gpio') to HIGH
- [ 16.544275] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 16.550111] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- [ 16.556395] sc4236.pltfrm_camera_module_s_power(1556) DEBUG: set PM state to 1 successful, camera module is on
- [ 16.571392] sc4236.pltfrm_camera_module_set_pin_state(1490) DEBUG: set GPIO #71 ('rockchip,pd-gpio') to HIGH
- [ 16.601218] sc4236.ov_camera_module_write_config(178) DEBUG:
- [ 16.606967] sc4236.ov_camera_module_write_config(194) DEBUG: write config 2304x1440_30fps
- [ 16.615144] sc4236.pltfrm_camera_module_write_reglist(1336) DEBUG: messages transfers 1 0xdf202000 msg 171 bytes 513
- [ 16.702810] sc4236.pltfrm_camera_module_write_reglist(1346) DEBUG: i2c_transfer return 171
- [ 16.711075] sc4236.pltfrm_camera_module_patch_config(1623) DEBUG: pix_fmt 12298, 2304x1440@30/1fps
- [ 16.720034] sc4236.ov_camera_module_s_power(557) DEBUG: camera powered on
- [ 16.726818] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x1
- [ 16.732641] sc4236.pltfrm_camera_module_ioctl(1727) DEBUG: cmd: 0x1
- [ 16.738920] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x805c76c0
- [ 16.745360] mipi_dphy_cfg:274
- [ 16.748340] mipi_dphy_cfg:299
- [ 16.752850] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x805c76c0
- [ 16.759295] sc4236.ov_camera_module_ioctl(894) DEBUG: cmd: 0x805c76c0
- [ 16.765725] sc4236.ov_camera_module_s_stream(403) DEBUG: 1
- [ 16.771211] sc4236.OV8858_start_streaming(1210) DEBUG: active config=2304x1440_30fps
- [ 16.779424] sc4236.pltfrm_camera_module_write_reg(1096) DEBUG: i2c write to offset 0x00000100 success
- [ 16.881202] <font color="#ff0000">cif_isP10_mipi_isr WARN: CIF_MIPI_ERR_DPHY: 0X20000</font>
- [ 17.926117] rk_gmac-dwmac ff290000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
- udhcpc: started, v1.25.0
- udhcpc: sending discover
- udhcpc: sending select for 192.168.0.120
- udhcpc: lease of 192.168.0.120 obtained, lease time 7200
- deleting routers
- adding dns 192.168.0.1
- [ 24.763992] cif_isp10_mipi_isr WARN: CIF_MIPI_ERR_DPHY: 0x101
- [ 24.769743] cif_isp10_mipi_isr WARN: CIF_MIPI_SYNC_FIFO_OVFLW: 0x101
- [ 24.776090] cif_isp10_mipi_isr(6510) ERR: mipi_mis icr err: 0x1
- [ 24.782018] cif_isp10_mipi_isr WARN: CIF_MIPI_SYNC_FIFO_OVFLW: 0x1
- [ 24.958705] cif_isp10_mipi_isr WARN: CIF_MIPI_SYNC_FIFO_OVFLW: 0x1
- [ 26.727481] cif_isp10_mipi_isr WARN: CIF_MIPI_SYNC_FIFO_OVFLW: 0x1
- [ 26.733662] cif_isp10_mipi_isr(6510) ERR: mipi_mis icr err: 0x1
- [ 26.739593] cif_isp10_mipi_isr WARN: CIF_MIPI_SYNC_FIFO_OVFLW: 0x1
- [ 27.189721] cif_isp10_mipi_isr WARN: CIF_MIPI_SYNC_FIFO_OVFLW: 0x1
- [ 27.195900] cif_isp10_mipi_isr(6510) ERR: mipi_mis icr err: 0x1
- [ 27.201831] cif_isp10_mipi_isr WARN: CIF_MIPI_SYNC_FIFO_OVFLW: 0x1
- [ 27.208004] cif_isp10_mipi_isr(6510) ERR: mipi_mis icr err: 0x1
- [ 27.213932] cif_isp10_mipi_isr WARN: CIF_MIPI_SYNC_FIFO_OVFLW: 0x1
复制代码
我知道答案
回答被采纳将会获得 5 RD币 已有0人回答
