1. 产品描述: 石英晶体谐振器
2. 标称频率: 26.000000MHz
3. 振荡模式: 基频
4. 切割方式: AT cut
5. 测试仪器: S&A 250B(Measured FL)
6. 电性能及参数:
[1]Operation Conditions:
Item Symbol MIN. TYP. MAX. Unit Condition
Operating Temperature Range Topt -20 70 ℃
Storage Temperature Range Tstg -40 85 ℃
Load Capacitance CL 9 pF
Drive Level DL 0.1 300 uW
[2]Frequency Stability:
Tolerance dF/Fo -10 10 ppm Refer to Center Frequency@25±3℃
Stability Over Temperature dF/F25 -30 30 ppm
Refer to Operating Temperature
@-20±70℃
Aging dF/F25 -3 3 ppm Per Year
dF/Fo:Frequency Deviation Refer to Center Frequency
dF/F25:Frequency Deviation Refer to 25℃ Frequency
[3]Electrical Performance:
Equivalent Series Resistance ESR 40 Ω @Series
Shunt Capacitance C0 5 pF
Insulation Resistance IR 500 MΩ @DC 100 Volt
7. 印字
26.0 :Nominal Frequency
9:Crystal CL
8: Year Code,eg .2017
A:Month Code
1 2 3 4 5 6 7 8 9 10 11 12
A B C D E F G H J K L M
