[DESCRIPTION]
Test enviroment:Test withsimulator CMW500 for AGPS LPP case
Result:Simulator reported thatPICS does not match reported capability for locationCoordinateTypes (pc_UEB_AGNSS)
[ANALYSIS]
We need to check fail reason throughSimulator log
Firstly: check simulator log in below folder,we could know that issue
failed withcapability IE"locationCoordinateTypes"
7_3_1_1\E03(5) Default 28-10-16
175846@supportinfo@server@tc_session\ttcn_tli.log
12796 17:59:34,236 INFO - 45806.457750 tliSetVerdict:
./Common/Common/CommonDefs.ttcn(354): <EUTRA_POS_PTC> FAIL
./POS/EUTRA/EUTRA_Positioning_Functions.ttcn:1840: PICS does not match
Search key word "locationCoordinateTypes", we could get below UE reported
EllipsoidPoint capbility as below.
+-locationCoordinateTypes [Record]
| +-ellipsoidPoint=false [BOOLEAN]
| +-ellipsoidPointWithUncertaintyCircle=false [BOOLEAN]
| +-ellipsoidPointWithUncertaintyEllipse=false [BOOLEAN]
| +-polygon=false [BOOLEAN]
| +-ellipsoidPointWithAltitude=false [BOOLEAN]
| +-ellipsoidPointWithAltitudeAndUncertaintyEllipsoid=true [BOOLEAN]
| +-ellipsoidArc=false [BOOLEAN]
Secondly: Let’s OpenPICX in simulator log with UltraEdit tools.
175846@supportinfo@server@tc_session\TTCNParameter.tsp
Search Key word "elli" and “poly” we can know that PICX parameters in
simulator as following.
<pc_GNSS_EllipArc value='TRUE'/>
<pc_GNSS_EllipPoint value='TRUE'/>
<pc_GNSS_EllipPointAlt value='TRUE'/>
<pc_GNSS_EllipPointAltUncertEllip value='TRUE'/>
<pc_GNSS_EllipPointUncertCircle value='TRUE'/>
<pc_GNSS_EllipPointUncertEllip value='TRUE'/>
<px_EllipsoidPointWithAltitude undefined='false'
value='0000000000000000'/>
<pc_GNSS_Polygon value='TRUE'/>
We can also get PICX details inLTE_v1 excelitems as below.
37571_A.4.3-8/1 Ellipsoid Point Support yes yes
37571_A.4.3-8/7 Ellipsoid Arc Support yes yes
37571_A.4.3-8/2 Ellipsoid Point With Uncertainty Circle Support yes
37571_A.4.3-8/3 Ellipsoid Point With Uncertainty Ellipse Support yes
37571_A.4.3-8/5 Ellipsoid Point With Altitude Support yes yes
37571_A.4.3-8/6 Ellipsoid Point With Altitude And Uncertainty Ellipsoid Support yes 。
37571_A.4.3-8/4 Polygon Support yes
