代码路径:Frameworks/base/services/devicepolicy/java/com/Android/server/devicepolicy/DevicePolicyManagerService.java
流程:每次开机时,loadsettingsLocked()方法会读取data/system/device_policies.xml文件手动激活时,saveSettingsLocked()方法会写入对应的信息到data/system/device_policies.xml文件
具体方法:先手动激活,然后pull出该文件,根据里面的多出的信息,在loadSettingsLocked()方法读取xml之前写入xml文件即可。
//写入标签名out.startTag(null, "policies");//写入标签属性和值dout.attribute(null, "flags", "31");//关闭标签out.endTag(null, "policies");
====================================================== /*zhanghao add begin*/
private void setSettingsLocked(int userHandle) {
JournaledFile journal = makeJournaledFile(userHandle);
FileOutputStream stream = null;
try {
stream = new FileOutputStream(journal.chooseForWrite(), false);
XmlSerializer out = new FastXmlSerializer();
out.setOutput(stream, StandardCharsets.UTF_8.name());
out.startDocument(null, true);
out.attribute(null, ATTR_SETUP_COMPLETE,
Boolean.toString(true));
//com.xueleyun.xlyLauncher
out.startTag(null, "admin");
out.attribute(null, "name", "com.xueleyun.xlylauncher/com.xueleyun.xlylauncher.deviceAdminReceiver");
out.startTag(null, "disable-bt-contacts-sharing");
out.attribute(null, "value", "true");
out.endTag(null, "disable-bt-contacts-sharing");
out.endTag(null, "admin");
out.endDocument();
stream.flush();
FileUtils.sync(stream);
stream.close();
journal.commit();
sendChangedNotification(userHandle);
} catch (IOException e) {
try {
if (stream != null) {
stream.close();
} catch (IOException ex) {
// Ignore
journal.rollback();
/*huanghh add end*/
private void loadSettingsLocked(DevicePolicyData policy, int userHandle) {
String tempString = SystemProperties.get("persist.sys.firstboot", "");
boolean isFirstBoot = (tempString != null && "".equals(tempString)) ? true : false;
if (isFirstBoot) {
SystemProperties.set("persist.sys.firstboot", "false");
setSettingsLocked(userHandle);
/*zhanghao end*/
