PHY6202 Bluetooth Low Energy (BLE) System on Chip
Key Features
• ARM® Cortex™-M0 32-bit processor
• Memory
512/256KB in-system flash memory
128KB ROM
138KB SRAM, all programmable
retention in sleep mode
8-channel DMA
• 33/19 general purpose I/O pins
All pins can be configured as serial
interface and programmable IO
MUX function mapping
All pins can be configured for wakeup
18 pins for triggering interrupt
3 quadrature decoder(QDEC
6-channel PWM
4-channel I2S
2-channel PDM
2-channel I2C
2-channel SPI
1-channel UART
JTAG
• 8-channel 12bit ADC with analog PGA
• 4-channel32bit timer, one watchdog timer
• Real timer counter (RTC)
• Power, clock, reset controlle
• Flexible power managemen
Supply voltage range 1.8V to 3.6V
Embedded buck DC-DC
Embedded LDOs Battery monitor: Supports low
battery detection
2μA @ Sleep Mode with 32KHz RTC
0.7μA @ OFF Mode(IO wake up only)
• 2.4 GHz transceiver
Compliant to Bluetooth 5.0, ETSI EN
300 328 and EN 300 440 Class 2
(Europe), FCC CFR47 Part 15 (US)
and ARIB STD-T66 (Japan)
Sensitivity:
-97dBm@BLE 1Mbps data rate
-103dBm@BLE 125Kbps data rate
TX Power -20 to +10dBm in 3dB steps
Receiver: 8mA @sensitivity level
Transmitter: 8mA @0dBm TX power
Single-pin antenna: no RF matching or
RX/TX switching required
RSSI (1dB resolution)
• RC oscillator hardware calibrations
32KHz RC oscillator automatic calibration
32MHz RC oscillator automatic
calibration
• AES-128 encryption hardware
AES-ECB
AES-CCM
• Link layer hardware
Automatic packet assembly
Automatic packet detection and
validation
Auto Re-transmit
Auto ACK
Hardware Address Matching
Random number generator
• Operating temperature: -40 ℃~125℃
• RoHS Package: QFN48/ QFN32
• Applications: Wearables, Beacons, appliances,
home and building, health and medical, sports
and fitness, industrial and manufacturing, retail
and payment, security, data transmission,
remote control, PC/mobile/TV peripherals,
internet of things (Io
文件过大
