已绑定手机 已实名认证 一牛网现金打赏上线了! 解问题 赚现金,知识收益,等你来!具体详情请点击: 一牛网现金打赏说明
L之前的版本,都可以通过adb shell dumpsys alarm命令来debug通过AlarmManagerSerivce设置到系统的所有alarm信息。
但是,在L版本上默认adb shell dumpsys alarm命令是无效的。
[SOLUTION]
如果
2. 将注释掉的while循环的code全部重新打开:
/*while (opti < args.length) {
String opt = args[opti];
if (opt == null || opt.length() <= 0 || opt.charAt(0) != '-') {
break;
opti++;
if ("-h".equals(opt)) {
pw.println("alarm manager dump options:");
pw.println(" log [on/off]");
pw.println(" Example:");
pw.println(" $adb shell dumpsys alarm log on");
pw.println(" $adb shell dumpsys alarm log off");
return;
} else {
pw.println("Unknown argument: " + opt + "; use -h for help");
if (opti < args.length) {
String cmd = args[opti];
opti++;
if ("log".equals(cmd)) {
configLogTag(pw, args, opti);
return;
synchronized (mLock) {
pw.println("Current Alarm Manager state:");
final long nowRTC = System.currentTimeMillis();
final long nowELAPSED = SystemClock.elapsedRealtime();
SimpleDateFormat sdf = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss");
pw.print("nowRTC="); pw.print(nowRTC);
pw.print("="); pw.print(sdf.format(new Date(nowRTC)));
pw.print(" nowELAPSED="); TimeUtils.formatDuration(nowELAPSED, pw);
pw.println();
if (!mInteractive) {
pw.print("Time since non-interactive: ");
TimeUtils.formatDuration(nowELAPSED - mNonInteractiveStartTime, pw);
pw.println();
pw.print("Max wakeup delay: ");
TimeUtils.formatDuration(currentNonWakeupFuzzLocked(nowELAPSED), pw);
pw.println();
pw.print("Time since last dispatch: ");
TimeUtils.formatDuration(nowELAPSED - mLastAlarmDeliveryTime, pw);
pw.println();
pw.print("Next non-wakeup delivery time: ");
TimeUtils.formatDuration(nowELAPSED - mNextNonWakeupDeliveryTime, pw);
pw.println();
long nextWakeupRTC = mNextWakeup + (nowRTC - nowELAPSED);
long nextNonWakeupRTC = mNextNonWakeup + (nowRTC - nowELAPSED);
pw.print("Next non-wakeup alarm: ");
TimeUtils.formatDuration(mNextNonWakeup, nowELAPSED, pw);
pw.print(" = "); pw.println(sdf.format(new Date(nextNonWakeupRTC)));
pw.print("Next wakeup: "); TimeUtils.formatDuration(mNextWakeup, nowELAPSED, pw);
pw.print(" = "); pw.println(sdf.format(new Date(nextWakeupRTC)));
pw.print("Num time change events: "); pw.println(mNumTimeChanged);
if (mAlarmBatches.size() > 0) {
pw.println();
pw.print("Pending alarm batches: ");
pw.println(mAlarmBatches.size());
for (Batch b : mAlarmBatches) {
pw.print(b); pw.println(':');
dumpAlarmList(pw, b.alarms, " ", nowELAPSED, nowRTC, sdf);
pw.println();
pw.print("Past-due non-wakeup alarms: ");
if (mPendingNonWakeupAlarms.size() > 0) {
pw.println(mPendingNonWakeupAlarms.size());
dumpAlarmList(pw, mPendingNonWakeupAlarms, " ", nowELAPSED, nowRTC, sdf);
} else {
pw.println("(none)");
pw.print(" Number of delayed alarms: "); pw.print(mNumDelayedAlarms);
pw.print(", total delay time: "); TimeUtils.formatDuration(mTotalDelayTime, pw);
pw.println();
pw.print(" Max delay time: "); TimeUtils.formatDuration(mMaxDelayTime, pw);
pw.print(", max non-interactive time: ");
TimeUtils.formatDuration(mNonInteractiveTime, pw);
pw.println();
pw.println();
pw.print(" Broadcast ref count: "); pw.println(mBroadcastRefCount);
pw.println();
if (mLog.dump(pw, " Recent problems", " ")) {
pw.println();
final FilterStats[] topFilters = new FilterStats[10];
final Comparator<FilterStats> comparator = new Comparator<FilterStats>() {
@Override
public int compare(FilterStats lhs, FilterStats rhs) {
if (lhs.aggregateTime < rhs.aggregateTime) {
return 1;
} else if (lhs.aggregateTime > rhs.aggregateTime) {
return -1;
return 0;
int len = 0;
for (int iu=0; iu<mBroadcastStats.size(); iu++) {
ArrayMap<String, BroadcastStats> uidStats = mBroadcastStats.valueAt(iu);
for (int ip=0; ip<uidStats.size(); ip++) {
BroadcastStats bs = uidStats.valueAt(ip);
for (int is=0; is<bs.filterStats.size(); is++) {
FilterStats fs = bs.filterStats.valueAt(is);
int pos = len > 0
? Arrays.binarySearch(topFilters, 0, len, fs, comparator) : 0;
if (pos < 0) {
pos = -pos - 1;
if (pos < topFilters.length) {
int copylen = topFilters.length - pos - 1;
if (copylen > 0) {
System.arraycopy(topFilters, pos, topFilters, pos+1, copylen);
topFilters[pos] = fs;
if (len < topFilters.length) {
len++;
if (len > 0) {
pw.println(" Top Alarms:");
for (int i=0; i<len; i++) {
FilterStats fs = topFilters;
pw.print(" ");
if (fs.nesting > 0) pw.print("*ACTIVE* ");
TimeUtils.formatDuration(fs.aggregateTime, pw);
pw.print(" running, "); pw.print(fs.numWakeup);
pw.print(" wakeups, "); pw.print(fs.count);
pw.print(" alarms: "); UserHandle.formatUid(pw, fs.mBroadcastStats.mUid);
pw.print(":"); pw.print(fs.mBroadcastStats.mPackageName);
pw.println();
pw.print(" "); pw.print(fs.mTag);
pw.println();
pw.println(" ");
pw.println(" Alarm Stats:");
final ArrayList<FilterStats> tmpFilters = new ArrayList<FilterStats>();
pw.print(" ");
if (bs.nesting > 0) pw.print("*ACTIVE* ");
UserHandle.formatUid(pw, bs.mUid);
pw.print(":");
pw.print(bs.mPackageName);
pw.print(" "); TimeUtils.formatDuration(bs.aggregateTime, pw);
pw.print(" running, "); pw.print(bs.numWakeup);
pw.println(" wakeups:");
tmpFilters.clear();
tmpFilters.add(bs.filterStats.valueAt(is));
Collections.sort(tmpFilters, comparator);
for (int i=0; i<tmpFilters.size(); i++) {
FilterStats fs = tmpFilters.get(i);
pw.print(" ");
pw.print(" "); pw.print(fs.numWakeup);
pw.print(" wakes " ); pw.print(fs.count);
pw.print(fs.mTag);
pw.println();
if (WAKEUP_STATS) {
pw.println();
pw.println(" Recent Wakeup History:");
long last = -1;
for (WakeupEvent event : mRecentWakeups) {
pw.print(" "); pw.print(sdf.format(new Date(event.when)));
pw.print('|');
if (last < 0) {
pw.print('0');
} else {
pw.print(event.when - last);
last = event.when;
pw.print('|'); pw.print(event.uid);
pw.print('|'); pw.print(event.action);
pw.println();
pw.println();
3.把dumpPoweroffAlarm的部分删掉
//***************delete***********************/
// /M:add for PowerOffAlarm feature ,@{
if (mPoweroffAlarms.size() > 0) {
final long now = System.currentTimeMillis();
pw.println(" ");
pw.print(" power off alarms dump (now=");
pw.print(sdf.format(new Date(now))); pw.println("):");
dumpAlarmList(pw, mPoweroffAlarms, " ", "PoweroffAlarms", now);
