查看: 1155|回复: 2
Hi3516CV500/Hi3516DV300R001 Compatibility Test Report,Hi3516系列开发板...
发表于 2019-10-31 20:51:54 | 显示全部楼层 |阅读模式 来自 广东省深圳市
海思平台hi3516CV500/Hi3516DV300R001 Compatibility Test Report,Hi3516芯片系列开发板/核心板方案定制开发
Interface
Class Level
UHS Level
Capacity
Asset Number
Work Mode
Card Work
Clock
HotPlug
Restart Negotiation
File
Compare
Write Speed (MB/s)
Read Speed (MB/s)
Three Threads
Write And Read
Test Result
Remarks
SD Card
Class 10
U3
128GB
HSC35092
SDR104
100MHZ
OK
OK
OK
37.5
37.1
OK
PASS
SD Card
Class 10
128GB
HSC15009
SDR50
100MHZ
OK
OK
OK
11.3
35.4
OK
PASS
SD Card
Class 10
U3
64GB
HSC15732
SDR104
100MHZ
OK
OK
OK
37.7
37.3
OK
PASS
SD Card
Class 4
64GB
HSC15785
SDR50
100MHZ
OK
OK
OK
6.4
35.7
OK
PASS
SD Card
Class 10
32GB
HSC15830
SDR50
100MHZ
OK
OK
OK
23.4
35.4
OK
PASS
micro SD Card
Class 10
U1
256GB
HSC36402
SDR104
100MHZ
OK
OK
OK
28.5
37.2
OK
PASS
micro SD Card
Class 10
128GB
HSC35359
SDR104
100MHZ
OK
OK
OK
16.4
36.6
OK
PASS
micro SD Card
Class 10
U3
64GB
HSC15619
SDR104
100MHZ
OK
OK
OK
37.5
37.5
OK
PASS
micro SD Card
Class 10
64GB
HSC15762
SDR104
100MHZ
OK
OK
OK
25.8
35.4
OK
PASS
micro SD Card
Class 10
U3
32GB
HSC36258
SDR104
100MHZ
OK
OK
OK
38.2
38.0
OK
PASS
micro SD Card
Class 10
U3
32GB
HSC35577
SDR104
100MHZ
OK
OK
OK
36.1
35.3
OK
PASS
micro SD Card
Class 10
U1
32GB
HSC36263
SDR104
100MHZ
OK
OK
OK
14.1
36.8
OK
PASS
micro SD Card
Class 4
8GB
HSC15739
SDR50
100MHZ
OK
OK
OK
4.3
34.5
OK
PASS
SD Card
Class 10
U1
128GB
HSC15010
SDR104
100MHZ
OK
OK
OK
33.4
35.9
OK
PASS
SD Card
Class 4
32GB
HSC15767
SDR50
50MHZ
OK
OK
OK
4.6
18.6
OK
PASS
Brand Name
Model Name
eMMC Level
Capacity
Voltage
Work Mode
Card Work
Clock
Uboot Startup
Reset
Longtime Reset
Reboot
Board Startup
Write Speed (MB/s)
Read Speed (MB/s)
Test Result
Remarks
Samsung
KLMAG1JENB-B041
MMC v5.1
16GB
1.8v
HS200
100MHZ
OK
OK
OK
OK
OK
42.239.3
PASS
Samsung
KLMBG2JENB-B041
MMC v5.1
32GB
1.8v
HS200
100MHZ
OK
OK
OK
OK
OK
42.539.4
PASS
Samsung
KLM8G1GETF-B041
MMC v5.1
8GB
1.8v
HS200
100MHZ
OK
OK
OK
OK
OK
42.838.9
PASS
Samsung
KLMAG1JETD-B041
MMC v5.1
64GB
1.8v
HS200
100MHZ
OK
OK
OK
OK
OK
42.439.6
PASS
Samsung
KLMBG2JETD-B041
MMC v5.1
32GB
1.8v
HS200
100MHZ
OK
OK
OK
OK
OK
42.739.4
PASS
Samsung
KLMCG2KCTA-B041
MMC v5.1
64GB
1.8v
HS200
100MHZ
OK
OK
OK
OK
OK
42.339.4
PASS
Samsung
KLM4G1FETE-B041
MMC v5.1
4GB
1.8v
HS200
100MHZ
OK
OK
OK
OK
OK
23.2
39.3
PASS
Samsung
KLMDG4UCTA-B041
MMC v5.1
128GB
1.8v
HS200
100MHZ
OK
OK
OK
OK
OK
42.739.5
PASS
游客,如果您要查看本帖隐藏内容请回复
海思方案及技术咨询电话:18928412535(微信同号)加号请备注(海思定制)
Hi3516DV300核心板/开发板https://bbs.16rd.com/shop_product-1-391.html
Hi3516DV100+4G核心板开发板https://bbs.16rd.com/shop_product-1-377.html
Hi3516AV100核心板开发板https://bbs.16rd.com/shop_product-1-378.html
Hi3516DV100+红外+可见光开发板https://bbs.16rd.com/shop_product-1-376.html
Hi3516EV100+4G+audio RTMP开发板https://bbs.16rd.com/shop_product-1-375.html
Hi3516EV100+4G+IT6801开发板https://bbs.16rd.com/shop_product-1-374.html
Hi3516EV100+sensor开发板https://bbs.16rd.com/shop_product-1-373.html
Hi3516EV100核心板+扩展版:https://bbs.16rd.com/shop_product-1-372.html
海思hi3519V101开发板https://bbs.16rd.com/shop_product-1-367.html
已实名认证
一牛网现金打赏上线了!解问题 赚现金,知识收益,等你来!具体详情请点击:一牛网现金打赏说明
发表于 2019-11-1 11:26:29 | 显示全部楼层 来自 广东省深圳市
参考一下,谢谢分享
发表于 2020-11-25 13:49:54 | 显示全部楼层 来自 上海市
学习学习学习学习学习学习学习学习学习学习学习
