查看: 2249|回复: 0
[展讯资料] 展讯SC7702_Feature_List_Draft_
发表于 2020-3-6 13:55:36 | 显示全部楼层 |阅读模式 来自 广东省深圳市
分类
Feature
Sub-Item
Description
Feature Owner
feature filter
test
Common
SIMs
Single
Protocol stack support Tri sim. Customers can Customize card number
Y
DualProtocol stack support Tri sim. Customers can Customize card number
Y
STK
The concrete specification please see PICS
Y
AT
Full
The concrete specification please see PICS. Do not support AT and MMI parallel execute
Y
GPRS
GPRS setting and connect
Y
SNTP
简单网络时间协议,用来自动更新时间
Need GPRS support
Y
HD Voice
AMR_WB
Y
SIM Card Hot-Plug
Platform support.Need specific SIM card slot
Y
G-Sensor
using this Feature.The screen can be 360 degrees rotation from arbitrary angles
Y
TF Card Hot-Plug
Platform support.Need specific TF card slot
N
TF update
Force update
mode
When Phone can not poweron and boot is ok. Type keypad command to update
N
Automatic update modeWhen poweron.Type #*8378#9# in idle and entry FTM mode. select automatic item to use it
N
SIM Lock
According to MNO Demand
Y
Animation MainMenu
动态菜单
Achieve dynamic add Icon like Smartphone
Y
Dual Battery
Support Two Battery(Two Battery Icon). Need Special HW Support
Y
PDA UI
Support two style
Y
Switch style
Y
Keypad
Touch
Resistance & capacitance
Y
Compact keypadMenukey& Nagetive & back softkey
Y
26 KeyQWERTY, Platform Support
Y
9 KeyStandard KeyPad,PlatForm Support
Y
4 KeyMenu & Home & Back & Power Key
Y
1 KeyPDA UI Support
Y
resolution
QVGA(240X320)
Y
QVGA(320x240)
Y
WQVGA(240x400)
Y
HVGA(320X480)
Y
游客,如果您要查看本帖隐藏内容请回复
一牛展讯技术QQ群:959055615
展讯方案及技术咨询电话:18928412535(微信同号)加号请备注
开发板/核心板https://bbs.16rd.com/mall_list-2.html
