瑞昱RTD2660 datasheet
1. Features
General
l Embedded 3 DDC with DDC1/2B/CI
l Zoom scaling up and down
l Embedded one MCU with SPI flash controller.
l It contains 8 ADCs in D-connector,LED
backlight,and key pad application
l It supports infrared remote function
l Require only one crystal to generate all timing.
l Programmable internal low-voltage-reset (LVR)
l High resolution 6 channels PWM output, and
wide range selectable PWM frequency.
l Support input format up to
1920(WUXGA)/1440-pixel width(option)
Analog RGB Input Interface
l 2 Analog input supported with internal switch
l Integrated 8-bit triple-channel 210/165MHz
ADC/PLL(option)
l Embedded programmable Schmitt trigger of
HSYNC
l Support Sync-On-Green (SOG) and various
kinds of composite sync modes
l On-chip high-performance hybrid PLLs
l High resolution true 64 phase ADC PLL
l Y/Pb/Pr support up to HDTV 1080p resolution
Embedded Video Decoder
l High performance AV 2D Comb-filter
l Support Composite, S Video, Component input
l Support VBI with Closed caption/ V chip slicer
Video Input Interface
l Support 8-bit video (ITU 656) format input
Embedded MCU
l Industrial standard 8051 core with serial flash up
to 256K bytes
l Low speed ADC for various application
l Infrared function supported
l I2C Master or Slave hardware supported
Auto Detection /Auto Calibration
l Input format detection
l Compatibility with standard VESA mode and
support user-defined mode
l Smart engine for Phase/Image position/Color
calibration
Scaling
l Fully programmable zoom ratios
l Independent horizontal/vertical scaling
l Advanced zoom algorithm provides high image
quality
l Sharpness/Smooth filter enhancement
l Support non-linear scaling from 4:3 to 16:9 or
RTD 2660 datasheet回复下载附件
