发表于 2020-9-25 19:35:03
显示全部楼层
|阅读模式
来自 广东省深圳市南山区
System startupUncompress Ok!U-Boot 2016.11 (Mar 19 2019 - 15:04:36 +0800)hi3516dv300Relocation Offset is: 0f6db000Relocating to 8fedb000, new gd at 8fe3aef0, sp at 8fe3aed0MMC: EMMC/MMC/SD controller initialization.scan edges:3 p2f:3 f2p:6mix set temp-phase 0scan elemnts: startp:89 endp:77Tuning SampleClock. mix set phase:[01/07] ele:[08/15] CACHE: Misaligned operation at range [8ff658e8, 8ff660e8]CACHE: Misaligned operation at range [8ff658e8, 8ff660e8]mmc fail to send stop cmdMMC/SD Card: MID: 0x90 Read Block: 512 Bytes Write Block: 512 Bytes Chip Size: 15032M Bytes (High Capacity) Name: "HAG2e" Chip Type: MMC Version: 0.0 Speed: 100000000Hz Bus Width: 4bithimci: 0 (eMMC)mmc fail to send stop cmd*** Warning - read failed, using default environmentIn: serialOut: serialErr: serialNet: eth0Warning: eth0 (eth0) using random MAC address - 96:5f:f9:4c:09:5eHit any key to stop autoboot: 0 MMC read: dev # 0, block # 2048, count 24576 ... mmc fail to send stop cmd0 blocks read: ERROR## Booting kernel from Legacy Image at 80000000 ... Image Name: Linux-4.9.37 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2475928 Bytes = 2.4 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ... OKStarting kernel ...Booting Linux on physical CPU 0x0Linux version 4.9.37 (root@johnny-virtual-machine) (gcc version 6.3.0 (HC&C V1R3C00SPC200B005_20190606) ) #11 SMP Wed Apr 15 20:25:45 CST 2020CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387dCPU: div instructions available: patching division codeCPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cacheOF: fdt:Machine model: HiSilicon HI3516DV300 DEMO Boardcmz zone is not set!cma: Reserved 16 MiB at 0x9f000000Memory policy: Data cache writeallocpercpu: Embedded 13 pages/cpu @debc9000 s21708 r8192 d23348 u53248Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048PID hash table entries: 2048 (order: 1, 8192 bytes)Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)Memory: 494536K/524288K available (5120K kernel code, 158K rwdata, 1212K rodata, 1024K init, 273K bss, 13368K reserved, 16384K cma-reserved, 0K highmem)Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xe0800000 - 0xff800000 ( 496 MB) lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc0600000 (6112 kB) .init : 0xc0800000 - 0xc0900000 (1024 kB) .data : 0xc0900000 - 0xc0927900 ( 159 kB) .bss : 0xc0929000 - 0xc096d638 ( 274 kB)SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1Hierarchical RCU implementation. Build-time adjustment of leaf fanout to 32.NR_IRQS:16 nr_irqs:16 16Gic dist init...arm_arch_timer: Architected cp15 timer(s) running at 50.00MHz (phys).clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb8812736b, max_idle_ns: 440795202655 nssched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 4398046511100nsSwitching to timer-based delay loop, resolution 20nsclocksource: hisp804: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 nsConsole: colour dummy device 80x30Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=500000)pid_max: default: 32768 minimum: 301Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)CPU: Testing write buffer coherency: okCPU0: thread -1, cpu 0, socket 0, mpidr 80000000Setting up static identity map for 0x80100000 - 0x80100058CPU1: thread -1, cpu 1, socket 0, mpidr 80000001Brought up 2 CPUSSMP: Total of 2 processors activated (200.00 BogoMIPS).CPU: All CPU(s) started in SVC mode.devtmpfs: initializedVFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 nsfutex hash table entries: 512 (order: 3, 32768 bytes)pinctrl core: initialized pinctrl subsystemNET: Registered protocol family 16DMA: preallocated 256 KiB pool for atomic coherent allocationsSerial: AMBA PL011 UART driver120a0000.uart: ttyAMA0 at MMIO 0x120a0000 (irq = 21, base_baud = 0) is a PL011 rev2console [ttyAMA0] enableduart-pl011 120a1000.uart: aliased and non-aliased serial devices found in Device tree. Serial port enumeration may be unpredictable.120a1000.uart: ttyAMA1 at MMIO 0x120a1000 (irq = 22, base_baud = 0) is a PL011 rev2uart-pl011 120a2000.uart: aliased and non-aliased serial devices found in device tree. Serial port enumeration may be unpredictable.120a2000.uart: ttyAMA2 at MMIO 0x120a2000 (irq = 23, base_baud = 0) is a PL011 rev2uart-pl011 120a3000.uart: aliased and non-aliased serial devices found in device tree. Serial port enumeration may be unpredictable.120a3000.uart: ttyAMA3 at MMIO 0x120a3000 (irq = 24, base_baud = 0) is a PL011 rev2uart-pl011 120a4000.uart: aliased and non-aliased serial devices found in device tree. Serial port enumeration may be unpredictable.120a4000.uart: ttyAMA4 at MMIO 0x120a4000 (irq = 25, base_baud = 0) is a PL011 rev2SCSI subsystem initializedssp-pl022 120c0000.spi: ARM PL022 driver, device ID: 0x00800022ssp-pl022 120c0000.spi: mapped registers from 0x120c0000 to e0844000ssp-pl022 120c1000.spi: ARM PL022 driver, device ID: 0x00800022ssp-pl022 120c1000.spi: mapped registers from 0x120c1000 to e0848000ssp-pl022 120c2000.spi: ARM PL022 driver, device ID: 0x00800022ssp-pl022 120c2000.spi: mapped registers from 0x120c2000 to e084a000usbcore: registered new interface driver usbfsusbcore: registered new interface driver hubusbcore: registered new device driver usbLinux video capture interface: v2.00clocksource: Switched to clocksource hisp804NET: Registered protocol family 2TCP established hash table entries: 4096 (order: 2, 16384 bytes)TCP bind hash table entries: 4096 (order: 3, 32768 bytes)TCP: Hash tables configured (established 4096 bind 4096)UDP hash table entries: 256 (order: 1, 8192 bytes)UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)NET: Registered protocol family 1RPC: Registered named UNIX socket transport module.RPC: Registered udp transport module.RPC: Registered tcp transport module.RPC: Registered tcp NFSv4.1 backchannel transport module.workingset: timestamp_bits=30 max_order=17 bucket_order=0squashfs: version 4.0 (2009/01/31) Phillip LougherNFS: Registering the id_resolver key typeKey type id_resolver registeredKey type id_legacy registeredfuse init (API version 7.26)Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)io scheduler noop registeredio scheduler deadline registeredio scheduler cfq registered (default)pl061_gpio 120d0000.gpio_chip: PL061 GPIO chip @0x120d0000 registeredpl061_gpio 120d1000.gpio_chip: PL061 GPIO chip @0x120d1000 registeredpl061_gpio 120d2000.gpio_chip: PL061 GPIO chip @0x120d2000 registeredpl061_gpio 120d3000.gpio_chip: PL061 GPIO chip @0x120d3000 registeredpl061_gpio 120d4000.gpio_chip: PL061 GPIO chip @0x120d4000 registeredpl061_gpio 120d5000.gpio_chip: PL061 GPIO chip @0x120d5000 registeredpl061_gpio 120d6000.gpio_chip: PL061 GPIO chip @0x120d6000 registeredpl061_gpio 120d7000.gpio_chip: PL061 GPIO chip @0x120d7000 registeredpl061_gpio 120d8000.gpio_chip: PL061 GPIO chip @0x120d8000 registeredpl061_gpio 120d9000.gpio_chip: PL061 GPIO chip @0x120d9000 registeredpl061_gpio 120da000.gpio_chip: PL061 GPIO chip @0x120da000 registeredpl061_gpio 120db000.gpio_chip: PL061 GPIO chip @0x120db000 registeredbrd: module loadedlibphy: hisi_femac_mii_bus: probedlibphy: Fixed MDIO Bus: probedGeneric PHY 10011100.mdio:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=10011100.mdio:00, irq=-1)phy_id=0x001cc816, phy_mode=rmiihisi-femac 10010000.ethernet: using random MAC address 2e:8a:b8:4f:3f:41usbcore: registered new interface driver r8152xhci-hcd 100e0000.xhci_0: xHCI Host Controllerxhci-hcd 100e0000.xhci_0: new USB bus registered, assigned bus number 1xhci-hcd 100e0000.xhci_0: hcc params 0x0220fe6c hci version 0x110 quirks 0x20010010xhci-hcd 100e0000.xhci_0: irq 32, io mem 0x100e0000hub 1-0:1.0: USB hub foundhub 1-0:1.0: 1 port detectedxhci-hcd 100e0000.xhci_0: xHCI Host Controllerxhci-hcd 100e0000.xhci_0: new USB bus registered, assigned bus number 2usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.hub 2-0:1.0: USB hub foundhub 2-0:1.0: hub can't support USB3.0usbcore: registered new interface driver usb-storagemousedev: PS/2 mouse device common for all miceusbcore: registered new interface driver xpadhibvt_rtc 12080000.rtc: rtc core: registered 12080000.rtc as rtc0hibvt_rtc 12080000.rtc: RTC driver for hibvt enabledi2c /dev entries driverhibvt-i2c 120b0000.i2c: hibvt-i2c0@100000hz registeredhibvt-i2c 120b1000.i2c: hibvt-i2c1@100000hz registeredhibvt-i2c 120B2000.i2c: hibvt-i2c2@100000hz registeredhibvt-i2c 120b3000.i2c: hibvt-i2c3@100000hz registeredhibvt-i2c 120b4000.i2c: hibvt-i2c4@100000hz registeredhibvt-i2c 120b5000.i2c: hibvt-i2c5@100000hz registeredhibvt-i2c 120b6000.i2c: hibvt-i2c6@100000hz registeredhibvt-i2c 120b7000.i2c: hibvt-i2c7@100000hz registeredusbcore: registered new interface driver uvcvideoUSB Video Class driver (1.1.1)himci: mmc host probeusb 1-1: new high-speed USB device number 2 using xhci-hcdhimci: mmc host probeusbcore: registered new interface driver usbhidusbhid: USB HID core driverNET: Registered protocol family 17Key type dns_resolver registeredRegistering SWP/SWPB emulation handlerhibvt_rtc 12080000.rtc: setting system clock to 2020-09-25 18:49:57 UTC (1601059797)clk: Not disabling unused clocksWaiting for root device /dev/mmcblk0p3...mmc0: new HS200 MMC card at address 0001mmcblk0: mmc0:0001 HAG2e 14.7 GiB mmcblk0: p1(boot) p2(kernel) p3(rootfs) p4(user)himci_cmd_done:745: The status of the card is abnormal, cmd->resp[0]: c5c00002himci_cmd_done:745: The status of the card is abnormal, cmd->resp[0]: c4800002himci_cmd_done:745: The status of the card is abnormal, cmd->resp[0]: c4800002mmcblk0: error -22 sending status command, retryinghimci_wait_cmd:245: Other CMD is running,please operate cmd again!mmcblk0: response CRC error sending SET_BLOCK_COUNT command, card status 0x900List of all partitions:0100 65536 ram0 (driver?)0101 65536 ram1 (driver?)0102 65536 ram2 (driver?)0103 65536 ram3 (driver?)0104 65536 ram4 (driver?)0105 65536 ram5 (driver?)0106 65536 ram6 (driver?)0107 65536 ram7 (driver?)0108 65536 ram8 (driver?)0109 65536 ram9 (driver?)010a 65536 ram10 (driver?)010b 65536 ram11 (driver?)010c 65536 ram12 (driver?)010d 65536 ram13 (driver?)010e 65536 ram14 (driver?)010f 65536 ram15 (driver?)b300 15392768 mmcblk0 driver: mmcblk b301 1024 mmcblk0p1 b302 12288 mmcblk0p2 b303 32768 mmcblk0p3 b304 15346688 mmcblk0p4 b318 4096 mmcblk0rpmb (driver?)b310 4096 mmcblk0boot1 (driver?)b308 4096 mmcblk0boot0 (driver?)No filesystem could mount root, tried: ext4Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3)CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.9.37 #11Hardware name: Generic DT based system[<c010fb80>] (unwind_backtrace) from [<c010ba18>] (show_stack+0x10/0x14)[<c010ba18>] (show_stack) from [<c033dce0>] (dump_stack+0x84/0x98)[<c033dce0>] (dump_stack) from [<c0196e54>] (panic+0xf0/0x25c)[<c0196e54>] (panic) from [<c08012b8>] (mount_block_root+0x234/0x294)[<c08012b8>] (mount_block_root) from [<c080155c>] (mount_root+0x134/0x150)[<c080155c>] (mount_root) from [<c08016e8>] (prepare_namespace+0x170/0x1b8)[<c08016e8>] (prepare_namespace) from [<c0800e5c>] (kernel_init_freeable+0x1d0/0x1e0)[<c0800e5c>] (kernel_init_freeable) from [<c05a0ddc>] (kernel_init+0x8/0x114)[<c05a0ddc>] (kernel_init) from [<c0107938>] (ret_from_fork+0x14/0x3c)CPU0: stoppingCPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.9.37 #11Hardware name: Generic DT based system[<c010fb80>] (unwind_backtrace) from [<c010ba18>] (show_stack+0x10/0x14)[<c010ba18>] (show_stack) from [<c033dce0>] (dump_stack+0x84/0x98)[<c033dce0>] (dump_stack) from [<c010de90>] (handle_IPI+0x174/0x190)[<c010de90>] (handle_IPI) from [<c01014e0>] (gic_handle_irq+0x88/0x8c)[<c01014e0>] (gic_handle_irq) from [<c010c5cc>] (__irq_svc+0x6c/0x90)Exception stack(0xc0901f60 to 0xc0901fa8)1f60: 00000000 0000081a debcb2e8 c01155e0 c0900000 c0902fe4 00000001 c090304c1f80: c090c524 c082d8c8 defffac0 00000000 00000000 c0901fb0 c0108a00 c0108a041fa0: 60000013 ffffffff[<c010c5cc>] (__irq_svc) from [<c0108a04>] (arch_cpu_idle+0x38/0x3c)[<c0108a04>] (arch_cpu_idle) from [<c015458c>] (cpu_startup_entry+0xbc/0x130)[<c015458c>] (cpu_startup_entry) from [<c0800c64>] (start_kernel+0x358/0x380)[<c0800c64>] (start_kernel) from [<8000807c>] (0x8000807c)---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3)
有没有人教导一下!!
我知道答案
回答被采纳将会获得 5 RD币 已有0人回答
