0.引言························································5
1.适用范围····················································5
2.术语和定义··················································5
2.1认证技术负责人············································5
2.2认证产品一致性(产品一致性)·······························5
2.3例行检验··················································6
2.4确认检验···················································6
2.5关键件定期确认检验········································6
2.6功能检查···················································6
3.工厂质量保证能力要求········································6
3.1职责和资源·················································7
3.2文件和记录·················································8
3.3采购和关键件控制···········································8
3.4生产过程控制···············································9
3.5例行检验和/或确认检验···························10
3.6检验试验仪器设备····································10
3.7不合格品的控制···········································12
3.8内部质量审核·············································12
3.9认证产品的变更及一致性控制·······························12
3.10产品防护与交付··········································13
3.11CCC证书和标志···········································13
1.适用范围
本实施规则规定了工厂质量保证能力的基本要求,同时也是认证机构实施工厂检查的依据之一。
2.术语和定义
2.1认证技术负责人
属于生产者和/或生产企业内部人员,掌握认证依据标准要求,依据产品认证实施规则/细则规定的职责范围,对认证产品变更进行确认批准并承担相应责任的人。
2.2认证产品一致性(产品一致性)
生产的认证产品与型式试验样品保持一致,产品一致性的具体要求由产品认证实施规则/细则规定。
关键件的质量控制
适当的控制方式可包括:
(a)获得CCC证书或可为最终产品强制性认证承认的自愿性产品认证结果,工厂应确保其证书状态的有效。
(b)没有获得相关证书的关键件,其定期确认检验应符合产品认证实施规则/细则的要求。
(c)工厂自身制定控制方案,其控制效果不低于3.3.2.2(a)或(b)的要求。
检验试验仪器设备基本要求:
工厂应配备足够的检验试验仪器设备,确保在采购、生产制造、最终检验试验等环节中使用的仪器设备能力满足认证产品批量生产时的检验试验要求。检验试验人员应能正确使用仪器设备,掌握检验试验要求并有效实施。
不合格品的控制
1.对于采购、生产制造、检验等环节中发现的不合格品,工厂应采取标识、隔离、处置等措施,避免不合格品的非预期使用或交付。返工或返修后的产品应重新检验。
2.对于国家级和省级监督抽查、产品召回、顾客投诉及抱怨等来自外部的认证产品不合格信息,工厂应分析不合格产生的原因,并采取适当的纠正措施。工厂应保存认证产品的不合格信息、原因分析、处置及纠正措施等记录。
3.工厂获知其认证产品存在重大质量问题时(如国家级和省级监督抽查不合格等),应及时通知认证机构。
CCC证书和标志
工厂对CCC证书和标志的管理及使用应符合《强制性产品认证管理规定》、《强制性产品认证标志管理办法》等规定。对于统一印制的标准规格CCC标志或采用印刷、模压等方式加施的CCC标志,工厂应保存使用记录。对于下列产品,不得加施CCC标志或放行:
(a)未获认证的强制性产品认证目录内产品;
(b)获证后的变更需经认证机构确认,但未经确认的产品;
(c)超过认证有效期的产品;
(d)已暂停、撤销、注销的证书所列产品;
(e)不合格产品。
文件下载请回复
