Main features:
support mobile
EC20 / ec200t-
LTE module 2g 3g 4G dial-up Internet
access;
>Support dual network port 1wan + 1lan or 2lan mode, can be selected throughthe page, support WAN port connection to the external network;
>Support
wifi sta mode, can choose to use STA to connect the superior routeto connect to the external network;
>The
system supports serial data transparent transmission mode by default,and supports server type TCP /
MQTT board side as client side;
>Support
RS232 / RS485 working mode,
optional;
>Support RS485 working mode to select transmission direction automati
cally;
>It supports wide
power input dc9-36v, and ultra-low energy consumption
ISOnly 2W;
>Board level built-in multi-level anti surge protection circuit, isolationcircuit;
>Industrial grade stable
SIM card holder;
>The system supports RS232 / RS485 data transparent transmission mode bydefault, and supports server type TCP / mqtt, and the board side is clientside;
>It can provide IO pin using block diagram, users can program and writeRS232 / RS485 data, and develop transmission protocol or
firmware by th
emselves;
BOJINGnet工业级4G TLE
dtu RS232/RS485 TO LTE的其他特性有:
移远EC20 /EC200T-LTE
模块2G3G 4G拨号上网 三网通移动/
联通/
电信;
>双网口1WAN+1LAN或2LAN模式可以通过页面选择,支持WAN口连接外网;
> WiFi STA模式,可以选择用STA连接上级路由连接外网;
>WiFi热点模式 2.4G b/g/n 150Mbps速率,可一键开关WiFi热点适合各种应用场合
> RS232/RS485工作模式可选择;
> RS485工作模式自动选择传输方向;
>工业级专用稳固SIM卡卡托;
>系统默认支持RS232/RS485数据透传模式,支持服务器类型TCP/MQTT板端为Client端;
用户可自行编程读写RS232/RS485数据,自行开发传输协议;
Industrial 4G router RS485/232通信串口服务器 工业物联网解决方案选型
