AC 220V to 3.3V5V 4 components power solution交流端不用电感220V直降3.3V5V电源芯片方案 product description.
产品描述.
AH8651 is a compact off-line linear regulator with no inductor design.
AH8651是一款紧凑型无电感设计的离线式线性稳压器。
By adjusting SEL pin, the AH8651 can obtain three output voltages of 5V/3.3V/2.7V.
通过调整SEL管脚阻值,AH8651 可获得5V/3.3V/2.7V三档输出电压。
AH8651 is a simple and reliable offline power solution for obtaining bias power.
AH8651是一种简单可靠的获得偏置供电的离线式电源解决方案。
AH8651 integrates 650V power MOSFET, start control circuit,
AH8651集成了650V功率MOSFET,启动控制电路,
VDD voltage control AC signal synchronization detection circuit,regulator
VDD电压控制电路,AC交流信号同步检测电路,低压差稳压器等。
The chip uses intelligent control of AC energy
该芯片通过智能控制交流能量输入以减小系统损耗,
Improve system efficiency while effectively
提高系统效率,同时有效降低系统待机。
AH8651 integrates a complete beltAH8651集成有完备的带
Protection function of
自恢复功能的保护功能:
VDD undervoltage
VDD欠压保护,
VDD overvoltage
VDD过压保护,
Output overload
输出过载保护,
Output undervoltage
输出欠压保护,
Lightning surge
雷击浪涌保护
And built-in over-temper
和内置过温保护等。
main feature主要特点High precision output voltage: 2%
精度高输出电压: 2%
Adjustable output: 5V/3.3V/2.7V
输出可调: 5V/3.3V/2.7V
Optimize the control method
优化控制方式,提升效率
Wide input voltage range: 80~305VAC
宽输入电压范围: 80~305VAC
No power inductor
无需功率电感
No need to input high
无需输入高压电容
Few parts, low cost
器件少,成本低
Quick dynamic
快速动态响应
Output short circuit
输出短路保护
Output undervoltage
输出欠压保护
Output overload
输出过载保护
Built-in overheat
内置过热保护
Package type SOP-8
封装类型SOP-8
typical application
典型应用●Small appliances
●小家电电源
●Wall switch and dimmer
●墙壁开关和调光器
