rc 开关是arduino的开发包适合给单片机增加433射频遥控功能,atmega328p 需要用D2口接收,发射不用特定
这里发我的解码代码:
Simple example for receiving
#include <EEPROM.h>
#include <RCSwitch.h>
#include <string.h>
//for hw-262
int RCLK = 4;
int SCLK = 7;
int DIO = 8;
unsigned char CHAR_MAP[] = { 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x8C, 0xBF, 0xC6, 0xA1, 0x86, 0xFF, 0xbf };
char CHAR_INDEX_MAP[] = { '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E', 'F', '-' };
char LEDbuf[10];
#define LED1 13
#define LED4 10
#define EEPROM_START_ADDRESS 0 // Start Address in EEPROM
#define EEPROM_SIZE 1024 // EEPROM size
#define LED_BUILTIN 3
typedef struct _eeprom_storage
unsigned int a;
unsigned long b[29];
} EEPROM_storage;
RCSwitch mySwitch = RCSwitch();
int c=0;
int cr=20;
int sREC = LOW;
int val; //全局变量
int inByte=0;
unsigned int x = 0; //全局变量
unsigned long rcVal[29]={3319553,3319555,3319558,3319557,3319561,3319556,3319554,3319559,3319571,3319560,3319573,3319562,3319563,3319564,3319565,3319566,3319568,3319572,3319569,3319570};
const int buttonPin = A1; // the number of the pushbutton pin
EEPROM_storage e2_memory;
int buttonState = 0; // variable for reading the pushbutton status
void setup() {
pinMode(buttonPin, INPUT_PULLUP);
pinMode(LED1, OUTPUT);
digitalWrite(LED1, HIGH);
pinMode(LED4, OUTPUT);
digitalWrite(LED4, HIGH);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
pinMode(DIO, OUTPUT);
pinMode(RCLK, OUTPUT);
pinMode(SCLK, OUTPUT);
Serial.begin(9600);
//delay(5000);
print_b0("433");
//print_t3(0);
read();
mySwitch.enableReceive(0);
//3319553 start
//3319555 stop
void loop() {
if (Serial.available() > 0) {
inByte = Serial.parseInt();
print_t0(inByte);
buttonState = digitalRead(buttonPin);
if(buttonState == LOW){
x++;
if(x==1){
print_b0("REC");
digitalWrite(LED1, LOW);
delay(500);
sREC=HIGH;
c=0;
cr=0;
if(x==2)
print_b0("SAVE");
delay(500);
cr=c;
save();
read();
c=0;
sREC=LOW;
delay(100);
if(sREC==HIGH)
if (mySwitch.available()) {
print_t1( mySwitch.getReceivedValue());
rcVal[c]=mySwitch.getReceivedValue();
c++;
print_t3(c);
mySwitch.resetAvailable();
flash();
}else{
test();
void EEPROM_write_block(unsigned char *memory_block, unsigned int start_address, unsigned int block_size)
unsigned char Count = 0;
for (Count=0; Count<block_size; Count++)
EEPROM.write(start_address + Count, memory_block[Count]);
void EEPROM_read_block(unsigned char *memory_block, unsigned int start_address, unsigned int block_size)
memory_block[Count]= EEPROM.read(start_address + Count);
//Serial.println((unsigned int)(memory_block[Count])); delay(400);
void EEPROM_clear_all(unsigned int eeprom_size)
unsigned int Count = 0;
unsigned char data = 0;
for (Count=0; Count<eeprom_size; Count++)
EEPROM.write(Count, data);
// Write an uint value to EEPROM
void EEPROM_write_short(unsigned int Address, unsigned int Data)
unsigned int DataL = Data&0x00FF;
unsigned int DataH = Data>>8;
EEPROM.write(Address, DataL);
EEPROM.write(Address+1, DataH);
// Read an uint value from EEPROM
unsigned int EEPROM_read_short(unsigned int Address)
unsigned int DataL = EEPROM.read(Address);
unsigned int DataH = EEPROM.read(Address+1);
return((DataH<<8) + DataL);
void print_t0(int s){
Serial.write("t0.txt=\"");
//Serial.print("Received ");
Serial.print(s);
Serial.write(" \"");
Serial.write(0XFF); //结束符
Serial.write(0XFF);
Serial.write(0XFF);
void print_t1(unsigned long s){
Serial.write("t1.txt=\"");
Serial.print(s,HEX);
Serial.write(0XFF);
Serial.write(0XFF);
//ledshow(s.String);
void print_t3(long s){
Serial.write("t3.txt=\"");
Serial.print(s);
Serial.write(0XFF); //Count
Serial.write(0XFF);
Serial.write(0XFF);
void print_b0(String s){
Serial.write("b0.txt=\"");
Serial.print(s);
Serial.write(0XFF); //REC
Serial.write(0XFF);
Serial.write(0XFF);
void save(){
e2_memory.a=cr;
for(int i=0;i<=cr;i++)
e2_memory.b=rcVal;
EEPROM_write_block((unsigned char*)&e2_memory, EEPROM_START_ADDRESS, sizeof(EEPROM_storage));
void read(){
EEPROM_read_block((unsigned char*)&e2_memory, EEPROM_START_ADDRESS, sizeof(EEPROM_storage));
if(e2_memory.a>100)e2_memory.a=29;
cr=e2_memory.a;
for (int i=0;i<cr;i++){
// Serial.println(e2_memory.b);
rcVal=e2_memory.b;
void test(){
ledshow(LEDbuf);
//String stringOne = String(mySwitch.getReceivedValue(), HEX);
sprintf(LEDbuf, "%d", mySwitch.getReceivedValue());
// ledshow(buf);
flash();
if(rcVal[c]==mySwitch.getReceivedValue()){
print_b0("OK");
flash();
c++;
}else{
print_b0("BAD");
if(c>=cr)
c=0;
print_b0("PASS");
flash_pass();
print_t3(c);
void flash(){
digitalWrite(LED_BUILTIN, LOW); // turn the LED on (HIGH is the voltage level)
delay(10); // wait for a second
digitalWrite(LED_BUILTIN, HIGH); // turn the LED off by making the voltage LOW
digitalWrite(LED4, LOW); // turn the LED on (HIGH is the voltage level)
digitalWrite(LED4, HIGH); // turn the LED off by making the voltage LOW
void flash_pass(){
delay(100); // wait for a second
void ledout(unsigned char chr)
unsigned char i;
for (i = 8; i >= 1; i--)
if (chr & 0x80) digitalWrite(DIO, 1); else digitalWrite(DIO, 0);
chr <<= 1;
digitalWrite(SCLK, 0);
digitalWrite(SCLK, 1);
void ledshow(const char* str)
int len = strlen(str);
int hasDot = 0;
for (int i = len - 1, m = 0; i >= 0; i--) {
char chr = str;
if (chr == '.') {
hasDot = 1;
continue;
int n = 0;
for (; n < 17; n++) {
if (chr == CHAR_INDEX_MAP[n])
break;
if (n != 17) {
unsigned char chr1 = CHAR_MAP[n];
if (hasDot)
chr1 &= 0x7f; // 所有字符的最高位(左数第一位)都是1,代表小数点为暗
// 因此只要将最高位改为0小数点就可以点亮啦
ledout(chr1); // 显示字符
ledout((int)ceil(pow(2, m))); // 位置
digitalWrite(RCLK, 0);
digitalWrite(RCLK, 1);
m++;
hasDot = 0;
