产品 | RM500Q-GL | RM502Q-GL | RM500Q-AE | RM502Q-AE | RM500Q-CN |
产品图片 | | | | | |
封装特征 | M.2 | M.2 | M.2 | M.2 | M.2 |
尺寸(mm) | 52.0 X 30.0 X 23 | 52.0 X 30.0 X 2.3 | 52.0 X 30.0 X 2.3 | 52.0 X 30.0 X 23 | 52.0 X 30.0 X 23 |
5G | Sub-6 GHz | Sub-6 GHz | Sub-6 GHz | Sub-6 GHz | Sub-6 GHz |
频段(MHz) | 5G NR: n1/n2/n3/n5/n7/n8/n12/n20/n25/n28/n38/n40/n41/n48*/n66/n71/n77/n78/n79 LTE- FDD: B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B17/B18/B19/B20/B25/B26/B28/B29/B30/B32/B66/B71 LTE- TDD: B34/B38/39/B40/B41/B42/B43/B48; LAA: B46 WCDMA: B1/B2/B3/B4/B5/B6/B8/B19 | 5G NR: n1/n2/n3/n5/n7/n8/n12/n20/n25/n28/n38/n40/n41/n48/n66/n71/n77/n78 LTE-FDD:B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B17/B18/B19/B20/B25/B26/B28/B29/B30/B32/B66/B71 LTE-TDD:B34/B38/39/B40/B41/B42/B43/B48; LAA: B46 WCDMA: B1/B2/B3/B4/B5/B6/B8/B19 | 5G NR: n1/n2/n3/n5/n7/n8/n12/n20/n25/n28/n38/n40/n41/n48*/n66/n71/n77/n78/n79 LTE-FDD: B1/B2/B3/B4/B5/B7/B8/B12(B17)/B13/B14/B18/B19/B20/B25/B26/B28/B29/B30/B32/B66/B71 LTE-TDD: B34/B38/39/B40/B41/B42/B43/B48 LAA: B46 (only support 2 × 2 MIMO) WCDMA: B1/B2/B3/B4/B5/B6/B8/B19 | 5G NR: n1/n2/n3/n5/n7/n8/n12/n20/n25/n28/n38/n40/n41/n48*/n66/n71/n77/n78/n79 LTE-FDD: B1/B2/B3/B4/B5/B7/B8/B12(B17)/B13/B14/B18/B19/B20/B25/B26/B28/B29/B30/B32/B66/B71 LTE-TDD:B34/B38/39/B40/B41/B42/B43/B48; LAA: B46 (only support 2 × 2 MIMO) WCDMA: B1/B2/B3/B4/B5/B6/B8/B19 | 5G NR: n1/n28/n41/n78/n79 LTE-FDD: B1/B3/B5/B8 LTE-TDD: B34/B38/B39/B40/B41 WCDMA: B1/B8 |
区域 | 全球(美国除外) | 全球(美国、中国、日本除外) | 全球(中国除外) | 全球(中国除外) | 中国 |
重量(g) | 9 | 9 | 8.7 | 8.7 | 8.9 |
正常工作温度 | -30° C ~ +70° C | -30° C ~ +70° C | -30° C ~ +70° C | -30° C ~ +70° C | -30° C ~ +70° C |
扩展工作温度 | -40° C ~ +85° C | -40° C ~ +85° C | -40° C ~ +85° C | -40° C ~ +85° C | -40° C ~ +85° C |
Control via AT Commands | 3GPP TS27.007 and Quectel Enhanced AT Commands | 3GPPTS27.007and Quectel Enhanced AT Commands | 3GPP TS27.007 and Quectel Enhanced AT Commands | 3GPP TS27.007 and Quectel Enhanced AT Commands | 3GPP TS27.007 and Quectel Enhanced AT Commands |
5G | 5G SA Sub-6: Max. 2.1Gbps (DL)/ Max. 900Mbps (UL) 5G NSA Sub-6: Max. 25Gbps (DL)/ Max. 600/650Mbps (UL)2 | 5G SA Sub-6: Max. 4.2Gbps (DL)/ Max. 900Mbps (UL) 5GNSA Sub-6: Max. 5.0Gbps (DL)/ Max.600/650Mbps(UL)2 | 5G SA Sub-6: Max. 2.1Gbps (DL)/ Max. 450Mbps (UL) 5G NSA Sub-6: Max. 2.5Gbps (DL)/ Max. 600/650Mbps (UL)2 | 5G SA Sub-6: Max. 4.2Gbps (DL)/ Max. 450Mbps (UL) 5G NSASub-6: Max. 5.0Gbps (DL)/ Max. 600/650Mbps (UL)2 | 5G SA Sub-6: Max. 2.1Gbps (DL)/ Max. 900Mbps (UL) 5G NSA Sub-6: Max. 25Gbps (DL)/ Max. 525/550Mbps(UL)3 |
LTE | LTE-FDD: Max. lGbps(DL)/Max. 200Mbps (UL) | LTE-FDD: Max. 2Gbps (DL)/Max. 200Mbps (UL) | LTE-FDD: Max. lGbps (DL)/Max. 200Mbps (UL) | LTE-FDD: Max. 2Gbps (DL)/Max. 200Mbps (UL) | LTE-FDD: Max. lGbps(DL)/Max. 200Mbps (UL) |
| WCDMA: Max. 42Mbps (DL)/ Max. 5.76Mbps (UL) | WCDMA: Max. 42Mbps (DL)/ Max. 5.76Mbps (UL) | WCDMA: Max. 42Mbps (DL)/ Max. 5.76Mbps (UL) | WCDMA: Max. 42Mbps (DL)/ Max. 5.76Mbps (UL) | WCDMA: Max. 42Mbps (DL)/ Max. 5.76Mbps (UL) |
SMS | • | • | • | • | • |
网络协议 | TCP/UDP/ FTP/HTTP/HTTPS /PING/SMS | TCP/UDP/FTP/HTTP/HTTPS /PING/SMS | TCP/UDP/FTP/HTTP/HTTPS /PING/SMS | TCP/UDP/FTP/HTTP/HTTPS /PING/SMS | TCP/UDP/FTP/HTTP/HTTPS /PING/SMS |
(U)SIM | X 2,1.8V3.0V | X 2,1.8W 3.0V | X 1,1.8V3.0V | X l,1.8\y3.0V | X 2.1-8W3.0V |
USB | 2.0/3.0/3.1 | 2.0/3.0/3.1 | 2.0/3.0/3.1 | 2.0/3.0/3.1 | 2.0/3.0/3.1 |
PCIe | PCIe Gen3 x 1 Lane | PCIe Gen3 x 1 Lane | PCIe Gen3 x 1 Lane | PCIe Gen3 x 1 Lane | PCIe Gen3 x 1 Lane |
PCM | X 1 | X 1 | X 1 | X 1 | X 1 |
GPIO | • | • | • | • | • |
RESET_N | • | • | • | • | • |
| | 蜂窝天线:X 4, GNSS: X 1 | 蜂窝天线:X4.GNSS: X 1 | 蜂窝天线:X4,GNSS: X 1 | 蜂窝天线:X4, GNSS: X 2 |
MIMO | DL:4 X4.UL2 X 2 | DL:4 X 4.UL2 X2 | DL:4X4,UL:2X2(OnlyN41) | DL4 X 4,UL:2 X 2(OnlyN41) | DL:4 X4.UL2 X 2 |
数字音频 | • | • | • | • | • |
VoLTE | 可选 | 可选 | 可选 | 可选 | 可选 |
| Dual-tone Multi-frequency | Dual-tone Multi-frequency | Dual-tone Multi-frequency | Dual-tone Multi-frequency | Dual-tone Multi-frequency |
| | Delta Firmware over the Air | Delta Firmware over the Air | Delta A rm wa re over th e Ai r | Delta Firmware over the Air |
GNSS | GPS/ GLONASS/ BeiDou/ Galileo | GPS/ GLONASS/ BeiDou/ Galileo | GPS/ GLONASS/ BeiDou/ Galileo | GPS/ GLONASS/ BeiDou/ Galileo | GPS/ GLONASS/ BeiDou/ Galileo |
(U)SIM卡插入检测 | • | • | • | • | • |
供电电压 | 3.135~4.4V 典型值 3.7V | 3.135~4.4V 典型值 3.7V | 3.135-4.4V 典型值3.7V | 3.135-4.4V 典型值3.7V | 3.135-4.4V 典型值3.7V |
耗流 | 70μA@关机 5mA@休眠,典型值 39mA, USB 2.0@空闲 64mA, USB 3.0@空闲 | 72μA@关机 6mA@休眠,典型值 42mA, USB 2.0@空闲 65mA, USB 3.0@空闲 | 80μA@关机 4.2mA@休眠,典型值 39mA, USB 2.0(a)空闲 54.5mA, USB 3.0@空闲 | 80μA@关机 4.2mA@休眠,典型值 39mA, USB 2.0@空闲 54.5mA, USB 3.0@空闲 | 78μA@关机 4.78mA@休眠,典型值 28mA,USB 2.0@空闲 47.9mA, USB 3.0®空闲 |
USB串口驱动 | Windows 7/8/8.1/10,Linux 2.6~5.8, Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Windows 7/8/8.1/10,Linux 2.6~5.8,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Windows 7/8/8.1/10,Unux 2.6~5.8,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Windows 7/8/8.1/10,Unux 2.6-5.8,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Windows 7/8/8.1/10,Linux 2.6~5.8,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 |
GNSS驱动 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 |
RIL驱动 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 |
NDIS驱动 | Windows 7/8/8.1/10 | Windows 7/8/8.1/10 | Windows 7/8/8.1/10 | Windows 7/8/8.1/10 | Windows 7/8/8.1/10 |
MBIM驱动 | Windows 10, Linux 3.18~5.8 | Windows 10, Linux 3.18~5.8 | Windows 10, Linux 3.18~5.8 | Windows 10, Unux 3.18~5.8 | Windows 10, Linux 3.18~5.8 |
Gobinet 驱动 | Linux 2.6~5.8 | Linux 2.6~5.8 | Linux 2.6~5.8 | Linux 26~5.8 | Linux 2.6~5.8 |
QMLWWAN 驱动 | Linux 3.4~5.8 | Linux 3.4~5.8 | Unux 3.4~5.8 | Unux 3.4~5.8 | Linux 3.4~5.8 |
PCIe驱动 | Windows 10, Linux 3.10~5.8,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Windows 10, Linux 3.10~5.8,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Windows 10, Linux 3.10~5.8,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Windows 10, Linux 3.10~5.8,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 | Windows10,Linux3.10~5.8,Android4.x/5.x/6.x/7.x/8.x/9.x/10 |
认证 | CE/RCM/CCC/S RRC/NAL/KC/GCF/KT/LGU+ | CE/RCM/FCC/IC/GCF/PTCRB | CE/RCM/FCC/IC/GCF/PTCRB/T-mobile*/AT&T*/Verizon*/Telstra*/JATE/TELEC/NCC* | CE/RCM/FCC/IC/GCF/PTCRB/T-mobile/AT&T/Verizon*/Telstra/JATE/TELEC | CCC/SRRC/NAL |
应用领域 | 工业级 路由器、家庭网关、机顶盒、工业级PDA、加固型工业平板电脑和数字标牌等 |
