产品 | EG12 | EG120K-EA | EG18 | EG512R-EA |
产品图片 | | | | |
封装特征 尺寸(mm) | LGA 37.0*39.5*2.8 | LGA 37.0*39.5*2.8 | LGA 37.0*39.5*2.8 | LGA 38.0*42.0*2.65 |
4G | LTE Cat 12 | LTE Cat 12 LFE-FDD: B1/B3/B5/B7/B8/B20/B28/ | LTE Cat 18 | LTE Cat 12 |
| LTE-FDD: B1/B3/B5/B7/B8/B20/B28 | B32 (Optional) | LTE-FDD: B1/B3/B5/B7/B8/B20/B28 | LTE-FDD: B1/B3/B5/B7/B8/B20/B28/B32 |
EA (EMEA/澳大利亚/巴西) | LTE-FDD: B1/B3/B5/B7/B8/B20/B28
LTE-TDD: B38/B40/B41
Up to 3 × CA: Intra-band and Inter-band
WCDMA: B1/B3/B5/B8 | LTE-FDD: B1/B3/B5/B7/B8/B20/B28/
B32(Optional)
LTE-TDD: B38/B40/B41/B42(Optional) /
B43(Optional)
WCDMA: B1/B3/B5/B8 | LTE-FDD: B1/B3/B5/B7/B8/B20/B28/B32
LTE-TDD: B38/B41/B42/B43
NA (北美) | LTE-FDD: B2/B4/B5/B7/B12/B13/B14/B25/
B26/B29/B30/B66/B71
LTE-TDD: B41
WCDMA Bands: B2/B4/B5 | / | LTE-FDD: B2/B4/B5/B7/B12/B13/B14/B171/
B25/B26/B29/B30/B66/B71
LTE-TDD: B41
Up to 5 × CA: Intra-band and Inter-band
重量(g) | 9 | 9.1 | 9 | 8.7 |
正常工作温度 | -30°C-+75°C | -30°C-+75°C | -30°C-+75°C | -30°C-+75°C |
扩展工作温度 | -40°C-+85°C | -40°C-+85°C | -40°C-+85°C | -40°C-+85°C |
Control via AT Commands | 3GPPTS27.007 and Quectel Enhanced AT Commands | 3GPPTS27.007 and Quectel Enhanced AT Commands | 3GPPTS27.007 and Quectel Enhanced AT Commands | 3GPPTS27.007 and Quectel Enhanced AT Commands |
LTE | LTE-FDD: Max. 600Mbps (DL)/ Max. 150Mbps
(UL)
LTE-TDD: Max. 430Mbps (DL)/ Max. 90Mbps
(UL) | LTE-FDD: Max. 600Mbps (DL)/ Max. 150Mbps
(UL)
(UL) | LTE-FDD: Max. 1.2Gbps (DL)/ Max. 150Mbps
(UL)
LTE-TDD: Max. 573Mbps (DL)/ Max. 90Mbps
(UL) | LTE-FDD: Max. 600Mbps (DL)/ Max. 75Mbps
(UL)
LTE-TDD: Max. 310Mbps (DL)/ Max. 90Mbps
(UL) |
UMTS | DC-HSDPA: Max. 42Mbps (DL)/ HSUPA: Max.
11.2Mbps (UL)
WCDMA: Max. 384Kbps (DL)/ Max. 384Kbps
(UL) | DC-HSDPA: Max. 42Mbps (DL)/ HSUPA: Max.
11.2Mbps (UL)
11.2Mbps (UL)
(UL) | WCDMA: Max. 42Mbps (DL)/ Max. 5.76Mbps
(UL) |
SMS | • | • | • | • |
网络协议 | TCP/ UDP/ FTP/ HTTP/ HTTPS / PING/ SMS | QMI/MBIM/NITZ/HTTP/HTTPS/FTP/LwM2M*/PING* | TCP/ UDP/ FTP/ HTTP/ HTTPS / PING/ SMS | TCP/ UDP/ FTP/ HTTP/ HTTPS / PING/ SMS |
USB | 2.0/3.0,高速接口,支持从模式 | 2.0/ 3.0,高速接口 ,支持主模式和从模式 | 2.0/3.0,高速接口,支持从模式 | 2.0/3.0,支持从模式 |
PCM | • | X 1 | • | • |
I2C | X 1 | X 1 | X 1 | X 1 |
(U)SIM | X 2,1.8V/3.0V | L8W3.0V | X 2,1.8V/ 3.0V | X 2,1.8V/3.0V |
eSIM | / | 可选 | / | X 1/built-in eSIM (optional) |
GPIO | X 2 | X3 | X 2 | • |
UART | X3 | X 2 | X3 | * |
ADC | X 2 | • | X 2 | X 2 |
SPI | X1 (可选) | X 1 | X1(可选) | • |
SDCard | • | • | • | * |
RESET_N | 模组重置 | 模组重置 | 模组重置 | • |
PCIe | 可选 | 可选 | 可选 | PCIe Gen2 x 1 Lane |
RGMII | / | / | / | • |
天线 | 主天线、MIM0X2、分集天线和GNSS天线 | 主天线、分集天线和GNSS天线 | 主天线、MIM0X2、分集天线和GNSS天线 | 主天线、分集天线和GNSS天线 |
MIMO eCall | 2 X 2,4 X 2,4 X 4,DL • | 2 X 2,4 X 2,4x4DL Emergency Service* | 2 X 2,4 X 2,4 X 4 DL • | 2 X 2,4 X 2,4 X 4 DL / |
数字音频 volte DTMF | • 可选 Dual-tone Multi-frequency | • 可选 Dual-tone Multi-frequency | • 可选 Dual-tone Multi-frequency | • 可选 Dual-tone Multi-frequency |
Dfota | Delta firmware over the Air | Delta Firmware over the Air | Delta Firmware over the Air | Delta Firmware over the Air |
GNSS | GPS/ GLONASS/ BeiDou/ Galileo/ QZSS | GPS/ GLONASS/ BeiDou/ Galileo/ QZSS | GPS/ GLONASS/ BeiDou/ Galileo/ QZSS | GPS/ GLONASS/ BeiDou/ Galileo |
供电电压 | 3.3~4.3 V, 3.8 V Typ. | 3.3~4.3 V, 3.8V Typ. | 3.3~4.3 V, 3.8 V Typ. | 3.3~4.3 V, 3.8 V Typ. |
耗流 | 20μA @Power off /
1.83mA @Sleep, Typ.
9.41mA @Idle | TBD @Power off /
TBD @LTE Sleep(PF=128)
TBD@LTE Sleep(PF=64)
TBD@Idle | 20μA @Power off /
1.81mA @Sleep, Typ.
9.38mA @Idle | 待定@关机
待定@休眠,典型值
待定@空闲 |
USB串口驱动 | Windows 7/8/8.1/10,Linux 2.6/3.x/4.x/5.x,Android 4.x/5.x/6.x/7.x/8.x/9.x | Windows 7/8/8.1/10, WinCE 5.0/6.0/7.0*, Linux 2.6/3.x/4.1~4.14, Android 4.x/5.x/6.x/7.x/8.x | Windows 7/8/8.1/10,Linux 2.6/3.x/4.x/5.x,Android 4.x/5.x/6.x/7.x/8.x/9.x | Windows 7/8/8.1/10,Linux 2.6~5.4,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 |
GNSS驱动 | / | / | / | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 |
RIL驱动 | Android 4.x/5.x/6.x/7.x/8.x/9.x | Android 4.x/5.x/6.x/7.x/8.x | Android 4.x/5.x/6.x/7.x/8.x/9.x | Android 4.x/5.x/6.x/7.x/8.x/9.x/10 |
NDIS驱动 | Windows 7/8/8.1/10 | Windows 7/8/8.1/10 | Windows 7/8/8.1/10 | Windows 7/8/8.1/10 |
MBIM驱动 | / | Windows 10; Linux 3.18-5.4 | / | Windows 7/8/8.1/10, Linux 3.18-5.4 |
Gobinet 驱动 | Linux2.6/3.x/4.x/5.x | Linux2.6/3.x/4.x/5.x | Linux2.6/3.x/4.x/5.x | Linux 2.6 〜5.4 |
QMI_WWAN 驱动 | Linux 3.x (3.4 or later)/4.x/5.x | Linux 3.x (3.4 or later)/4.x/5.x | Linux 3.x (3.4 or later)/4.x/5.x | Linux 3.4 〜5.4 |
PCIe驱动 | / | / | / | Windows 10, Linux 2.6~5.4,Android 4.x/5.x/6.x/7.x/8.x/9.x/10 |
认证 | CE/ RCM | TBD | CE/ RCM/ FCC/ IC/GCF/ PTCRB/AT&T*/ Verizon*/Telstra/ USCC* | CE/ RCM |
应用领域 | 工业级路由器、家庭网关、机顶盒、工业级PDA、加固型工业平板电脑和数字标牌等 |
