发表于 2021-11-26 17:29:28
显示全部楼层
|阅读模式
来自 广东省深圳市南山区
D/A Converters
CS43130 2 130 -108 384 伪差分 1.8 1.8 1.5-40.2 1.7 40 QFN;
42 WLCSP
CS43131 2 130 -115 384 伪差分 1.8 1.8 6.25-40.2 2 40 QFN;
42 WLCSP
CS4334 2 96 -88 2-100 单端 5 1.2 8 SOIC
CS4344 2 105 -90 2-200 单端 3.3 或者 5 0.65*VA Vpp 10 TSSOP
CS4345 2 105 -90 2-200 单端 3.3 或者 5 0.65*VA Vpp 10 TSSOP
CS4348 2 105 -90 2-200 单端 3.3 或者 5 0.65*VA Vpp 10 TSSOP
CS4385A 8 114 -100 4-216 差动 5 2.5 1.8-5.0 2.3-2.5 48 LQFP
CS4398 2 120 -107 30-216 差动 5 3.3-5 1.8-5.0 2.3 28 TSSOP
CS4399 2 130 -108 32-384 差动 1.8 1.8 3-5.25(电池电源) 1.73 40 QFN;
42 WLCSP
Interfaces & Sample Rate Converters
CS8406 8-192 1 — 3.3-5 3.3-5 28 SOIC;
28 TSSOP
CS8416 32-192 8 — — 3.3 3.3 3.3 28 SOIC;
28 TSSOP;
28 QFN
CS8421 7.2-211 — — 2.5 3.3-5 20 TSSOP;
20 QFN
CS8422 6-211 4 — 3.3 1.8-5 32 QFN
WM8804 32-192 1 1 — — 2.7-3.6 20 SSOP
WM8805 32-192 1 8 — — 2.7-3.6 28 SSOP
CS8415A 8-96 1 7 — — 5 3.3-5 3.3-5 28 SOIC;
28 TSSOP
A/D Converters
CS5340 2 101 -94 192 Single-ended 3.3-5 3.3-5 1.8-5 90-220 I²S or Left-Justified audio interface, H/W control interface, Pin compatible with CS5341 and CS5342 16 TSSOP
CS5341 2 105 -98 192 Single-ended 3.3-5 3.3-5 1.8-5 90-220 Supports both I²S and Left-Justified serial audio formats, H/W control interface, Pin compatible with CS5340 16 TSSOP
CS5342 2 105 -98 192 Single-ended 3.3-5 3.3-5 2.5-5 90-220 384*Fs MCLK, H/W control interface 16 TSSOP
CS5343 2 98 -92 96 Single-ended 3.3-5 3.3-5 3.3-5 36-85 Supports I²S Audio Format 10 TSSOP
CS5344 2 98 -92 96 Single-ended 3.3-5 3.3-5 3.3-5 36-85 CS5344 Supports Left-Justified Audio Format 10 TSSOP
CS5361 2 114 -105 192 Differential 5 3.3-5 2.5-5 135-243 Pin compatible with CS5381, I²S or Left-Justified audio interface, H/W control interface 24 SOIC;
24 TSSOP |
