mt6735开机过程中,到GPU是不能起动了,日志如下,请哪位高手哥帮忙分析一下。
[ 19.022228]<2>.(2)[447:dex2oat][CCCI1-DUMP]000: 00000000 00000000 30305F49 00000013
[ 19.101599]<3>.(3)[21:kworker/3:0][MALI] MTK_kbase_set_bottom_gpu_freq_fp() ui32FreqLevel=0, g_custom_gpu_boost_id=1 (GED boost)[ 19.268776][MALI] mtk_kbase_set_bottom_gpu_freq_fp() ui32FreqLevel=0, g_custom_gpu_boost_id=1 (GED boost)[ 19.345955]<1>.(1)[138:mmcqd/0][BLOCK_TAG] mmcqd:138 Workload=17%, duty 86498222, period 500959600, req_cnt=180
[ 19.347235]<1>.(1)[138:mmcqd/0][BLOCK_TAG] mmcqd:138 Write Diversity=17541 sectors offset, req_cnt=9, break_cnt=0, tract_cnt=0, bit_cnt=0
[ 19.348774]<1>.(1)[138:mmcqd/0][BLOCK_TAG] mmcqd:138 Read Diversity=121315 sectors offset, req_cnt=171, break_cnt=0, tract_cnt=0, bit_cnt=0
[ 19.350405]<1>.(1)[138:mmcqd/0][BLOCK_TAG] mmcqd:138 Write Throughput=9830 kB/s, size: 49152 bytes, time:5 ms
[ 19.351641]<1>.(1)[138:mmcqd/0][BLOCK_TAG] mmcqd:138 Read Throughput=38128 kB/s, size: 3088384 bytes, time:81 ms
[ 19.352934]<1>.(1)[138:mmcqd/0][BLOCK_TAG] mmcqd metarw WR:0 NWR:0 HR:0 WDR:0 HDR:0 WW:0 NWW:0 HW:0
[ 19.354068]<1>.(1)[138:mmcqd/0][BLOCK_TAG] mmcqd pid:138 {00447:00000:00000000:00256:01048576}{00228:00003:00012288:00150:00614400}{00468:00000:00000000:00318:01302528}{00290:00000:00000000:00030:00122880}
[ 19.356357]<1>.(1)[138:mmcqd/0][BLOCK_TAG] vmstat (FP:113604)(FD:776)(ND:1532)(WB:8)(NW:748)
[ 19.430433]<1>.(1)[280:SFWatchDog]monitor_hang_open
[ 19.431082]<1>.(1)[280:SFWatchDog]AEE_MONITOR_SET[status]: 0x1[ 19.431820]<1>.(1)[280:SFWatchDog]monitor_hang_release
[ 19.432532]<1>.(1)[280:SFWatchDog]monitor_hang_open
[ 19.433172]powerkey_kickowerkey ioctl:4,4
[ 19.433694]<1>.(1)[280:SFWatchDog]monitor_hang_release
[ 19.438754][MALI] mtk_kbase_set_bottom_gpu_freq_fp() ui32FreqLevel=0, g_custom_gpu_boost_id=1
我知道答案
回答被采纳将会获得 5 RD币 已有0人回答
