Features
Single-Supply Operation from +1.4V ~ +5.5V
Rail-to-Rail Input / Output
Gain-Bandwidth product: 15KHz (Typ.)
Low Input Bias Current: 1pA (Typ.)
Low Offset Voltage: 2.5mV (Max.)
Quiescent Current: 600nA per AmplIFier (Typ.)
Operating Temperature: -40°C ~ +125°C
Embedded RF Anti-EMI Filter
Small Package:GS6041 Available in SOT23-5 and SC70-5 PackagesGS6042 Available in SOP-8, MSOP-8 and DFN-8PackagesGS6043 Available in SOP-8 and MSOP-8 PackagesGS6044 Available in SOP-14 and TSSOP-14 Packages
General Description
The GS6041 family has a high gain-bandwidth product of 15KHz, a slew rate of 4.5V/ms, and a quiescent current of600nA/amplifier at 5V. The GS6041 family is designed to provide optimal performance in low voltage and low noise systems.They provide rail-to-rail output swing into heavy loads. The input common mode voltage range includes ground, and themaximum input offset voltage is 2.5mV for GS6041 family. They are specified over the extended industrial temperature range(-40℃ to +125℃). The operating range is from 1.4V to 5.5V. The GS6041 single is available in Green SC70-5 and SOT23-5packages. The GS6042 Dual is available in Green SOP-8, MSOP-8 and DFN-8 packages. The GS6044 Quad is available inGreen SOP-14 and TSSOP-14 packages.
Applications
ASIC Input or Output Amplifier
Sensor Interface
Medical Communication
Smoke detectors
audio Output
Piezoelectric Transducer Amplifier
Medical Instrumentation
Portable Systems
