LoadPull measurement
Outline & Overview
Intro
Load Pull Test Setup and Devices Tested
Small-Signal Comparisons: VNA vs. Load Pull
VNA vs. Load Pull Compression at 50Ω
Fundamental TOI Tuning for Po, PAE, and TOI
Harmonic Load Pull (HLP) TOI tuning results
Introduction
Harmonic Load Pull improves PAE.
Linearity effects are now investigated.
Accuracy of a load pull system needs verification.
Delta-Gt method for Load, Source, & Harmonic Tuners.
Compare small-signal ANA measurements.
Power sweep ANA vs. 50Ω Load Pull compression.
CAE linear and non-linear model comparisons.
Load Pull results quantify Non-Linear model sims.
Maury Microwave ATS Bench Setup
The Triplexer S-Parameters are created by measuring each signal path.
Tuners are characterized at 2.45GHz, 4.9GHz and 7.35 GHz.
S-Parameter blocks <S> accounted for the DUT Probes.
Short Low Loss cables connect Cascade Probes.
