展讯SC6531硬件资料
The SC2631H is a complete CMOS high-power, high-efficiency transmit module for lowcost quad-band TX (GSM850/EGSM900/DCS1800/PCS1900)/dual-band RX GSM/GPRS
mobile handsets. Power amplifier, Power controller circuit and switch circuit have been integrated in a single CMOS chip. Internal TX/RX 50Ω matching, DC blocking on TX/Ant
and harmonic filtering circuits are integrated, and this eliminates the extra need of external components, simplifies layout and reduces board space as well. The advanced front-end
module architecture has been designed specifically to use standard CMOS technology to implement high output power at high efficiency over all the operating conditions. No
external compensation for temperature, frequency or Battery is another advantage to meet RF performance over various conditions. The module is packaged in a small LGA format
(7.0mm x6.0mm x0.75mm).
product Features
High Output Power
• 34.0dBm at GSM850/EGSM900
• 31.0dBm at DCS1800/PCS1900
High Power Added Efficiency
• GSM850 42% PAE
• EGSM900 42% PAE
• DCS1800 30% PAE
• PCS1900 30% PAE
Integrated Control and Protection
Applications
• VBATT Operating range 3.0V to 4.5V
• Complete power control solution
• Advanced CMOS process
• LGA 7.0mm x6.0mm x 0.75mm
• Quad-band cellular handsets
• Multimode Mobile Handset Applications
• GPRS Class 12 Compliant
• Portable Battery-Powered Equipment
一牛展讯技术QQ群:959055615
展讯方案及技术咨询电话:18928412535(微信同号)加号请备注
开发板/核心板:https://bbs.16rd.com/mall_list-2.html
