product Features
IEEE 802.11 Key Feature
 Lead Free design which is compliant with ROHS requirements.
 TX and RX low-density parity check (LDPC) support for improved range and power efficiency.
 Dual-stream spatial multiplexing up to 1200 Mbps data rate.
 20, 40, 80 MHz channels with optional SGI (1024 QAM modulation)
 Real simultaneous dual-band
 Client MU-MIMO
 Supports standard SDIO v3.0, compatible with SDIO v2.0 HOST interfaces.
Bluetooth Key Feature
 BT host digital interface:
- HCI UART (up to 4 Mbps)
- PCM for audio data
 Complies with Bluetooth Core Specification Version 5.0 with provisions for supporting future specifications. With Bluetooth Class 1 or Class2 transmitter operation.
 Supports extended synchronous connections (eSCO), for enhanced voice quality by allowing for retransmission of dropped packets.
 Adaptive frequency hopping (AFH) for reducing radio frequency interference.
A simplified block diagram of the module is depicted in the figure above.
- 2.48 MB
10 RD币 购买记录
- 下载权限:
- 实习工程师
