36.1.8. MCI_AudioStreamingPlay
Primitive
INT32 MCI_AudioStreamingPlay(INT32 * pBuffer, UINT32 len,
MCI_AUDIO_BUFFER_PLAY_CALLBACK_T callback,
MCI_AUDIO_BUFFER_PLAY_DATA_CALLBACK_T data_callback);
Description
Play audio data continuously with callback. Player starts play audio data stored in ‘pBuffer’, and
‘data_callback’ will be called to fetch new data when run out of it. Supported audio format includes mp3, AMR-nb,pcm.
Notice: 1>. There must be one valid audio frame in ‘pBuffer’, otherwise player will failed to start.
For PCM format, one wav header should be included in audio data.
For AMR-NB format, amr file header "#!AMR\n" should be in audio data.
For MP3 format, some mp3 file may contain big “ID3” header, please guarantee there is valid
mp3 frame followed by “ID3” header. It’s recommended to skip “ID3” header firstly, and then
start to send valid mp3 frame with this API.
2>. Memory of ‘pBuffer’ used as working buffer of player internally, do not free or overwrite this
buffer during playback.
< pBuffer>: buffer which is used for bufferring audio data.
<len>: valid audio data size in ‘pBuffer’.
<callback>: callback for player status.
MCI_ERR_END_OF_FILE: means playback reaches end of file.
MCI_ERR_ERROR: means error happened during playback.
Notice: Don’t stop player in the callback, it will lead to dead lock.
<data_callback>: callback registed for feeding more audio data.
<return value>: MCI_ERR_NO means success
