外围设备的介绍和电机设备选择:400V系列
适用电机 | | 断路器选择*2 | 输入侧电磁接触器*3 | 连接断路器 | 有工频运行 | 连接电抗器 | 无 | 有 | 无 | 有 | 0.75 | | 30AF 5A | 30AF 5A | 30AF 5A | S-N10 | S-N10 | 1.5 | FR-F740-1.5K-CH | 30AF 10A | 30AF 10A | 30AF 10A | S-N10 | S-N10 | 2.2 | FR-F740-2. 2K-CH | 30AF 10A | 30AF 10A | 30AF 15A | S-N10 | S-N10 | 3.7 | FR-F740-3. 7K-CH | 30AF 20A | 30AF 15A | 30AF 20A | S-N10 | S-N10 | 5.5 | FR-F740-5. 5K-CH | 30AF 30A | 30AF 20A | 30AF 30A | S-N20 | S-N11/N12 | 7.5 | FR-F740-7. 5K-CH | 30AF 30A | 30AF 30A | 30AF 30A | S-N20 | S-N20 | 11 | FR-F740-11K-CH | 50AF 50A | 50AF 40A | 50AF 50A | S-N20 | S-N20 | 15 | FR-F740-15K-CH | 100AF 60A | 50AF 50A | 100AF 60A | S-N25 | S-N20 | 18.5 | FR-F740-18.5K-CH | 100AF 75A | 100AF 60A | 100AF 75A | S-N25 | S-N25 | 22 | FR-F740-22K-CH | 100AF 100A | 100AF 75A | 100AF 100A | S-N35 | S-N25 | 30 | FR-F740-30K-CH | 225AF 125A | 225AF 100A | 225AF 125A | S-N50 | S-N50 | 37 | FR-F740-37K-CH | 225AF 150A | 225AF 125A | 225AF 150A | S-N65 | S-N50 | 45 | FR-F740-45K-CH | 225AF 175A | 225AF 150A | 225AF 175A | S-N80 | S-N65 | 55 | FR-F740-55K-CH | 225AF 200A | 225AF 175A | 225AF 200A | S-N80 | S-N80 | 75 | FR-F740-S75K-CH |
| 225AF 225A | 225AF 225A |
| S-N95 | 90 | FR-F740-S90K-CH |
| 225AF 225A | 400AF 300A |
| S-N150 | 110 | FR-F740-S110K-CH |
| 225AF 225A | 400AF 350A |
| S-N180 | 132 | FR-F740-S132K-CH |
| 400AF 400A | 400AF 400A |
| S-N180 | 160 | FR-F740-S160K-CH |
| 400AF 400A | 600AF 500A |
| S-N300 | 185 | FR-F740-S185K-CH |
| S-N300 | 220 | FR-F740-S220K-CH |
| 600AF 500A | 600AF 600A |
| S-N400 | 250 | FR-F740-S250K-CH | — | 600AF 600A | 600AF 600A | — | S-N600 | 280 | FR-F740-S280K-CH | — | 600AF 600A | 800AF 800A | — | S-N600 | 315 | FR-F740-S315K-CH | — | 800AF 700A | 800AF 800A | — | S-N600 | 355 | FR-F740-S355K-CH | — | 800AF 800A | 800AF 800A | — | S-N600 | 400 | FR-F740-S400K-CH | — | 1000AF 900A | 1000AF 1000A | — | S-N800 | 450 | FR-F740-S450K-CH | — | 1000AF 1000A | 1000AF 1000A | — | 1000A 额定产品 | 500 | FR-F740-S500K-CH | — | 1200AF 1200A | 1200AF 1200A | — | 1000A 额定产品 | 560 | FR-F740-S560K-CH | — | 1600AF 1500A | 1600AF 1600A | — | 1200A 额定产品 | 630 | FR-F740-S630K-CH | — | 2000AF 2000A | 2000AF 2000A | — | 1400A 额定产品 | 1、使用电源电压为AC400V,50Hz,4级的三菱标准电机时选定。
2、MCCB的型号根据变频器电源的容量选定。MCCB是指在每1台变频器中请设置1台MCCB。在美国和加拿大使用时,请选定UL,UCL认定的熔丝。(参照第117页)
3、电磁器的电气耐久性为50万次。使用电机驱动中的紧急停止时为25次。电机驱动中作为紧急停止使用的情况下以及工频运行情况下的电机侧的电磁接触器,其电机的额定电压请在AC-3级额定使用电流中选定。
4、如果变频器1次侧的断路器跳闸,可能是配线异常(短路)、变频器内部部件损坏等原因引起的。确定断路器跳闸的原因,并消除原因后再接通断路器。
端子接线图
端子接线图
主回路端子规格:
端子记号 | 端子名称 | 端子功能说明 | R/L1, S/L2, T/L3 | 交流电源输入 | 连接工频电源。 当使用高功率因数变流器(FR-HC, MT-HC)及共直流母线变流器 (FR-CV)时不要连接任何东西。 | U, V, W | 变频器输出 | 接三相鼠笼电机。 | R1/L11, S1/L21 | 控制回路用电源 | 与交流电源端子R/L1, S/L2连接。在保持故障显示或故障输出时及使 用高功率因数变流器(FR-HC, MT-HC)和共直流母线变流器(FR-CV) 时把端子R/L1-R1/L11, S/L2-S1/L21间的短路片拆下,从外部接通此 端子的电源。 请不要在主回路电源(R/L1, S/L2, T/L3)接通的状态下把控制回路 用电源(R1/L11, S1/L21)断开。否则有可能损坏变频器。请使回路 可以同时断开主回路用电源(R/L1, S/L2, T/L3)。 18. 5K以下:60VA, 22K以上:80VA | P/+. N/- | 连接制动单元 | 连接制动单元(FR-BU, BU, MT-BU5),共直流母线变流器(FR-CV) 电源再生转换器(MT-RC)及高功率因素变流器(FR-HC, MT-HC)。 | P/+. P1 | 连接改善功率因数直流 电抗器 | 取下端子P/+-P1之间的短路片,连接直流电抗器(FR-HEL) o (S75K以上中则按标准附带直流电抗器。) | PR, PX | 拆除端子PR、PX或是所连接的短路片后请不要使用 | | 接地 | 变频器外壳接地用。必须接大地。 |
维护和检查时的注意事项
变频器是以半导体元件为中心而构成的静止机器。为了防止由于温度,潮湿,灰尘,污垢和振动等等使用环境的影响,和使用元件的老化,寿命等其它原因,必须进行日常检查。
断开电源后不久,平波电容上仍然剩余有高压电,当进行检查时,断开电源,过10分钟后用万用表等确认变频器主电路P/+和N/-间电压在直流30V以下后进行。
日常检查
检查如下:
1) 电机运行是否异常
2) 安装环境是否合适
3) 冷却系统是否异常
4) 是否有异常振动声音
5) 是否出现过热和变色
在运行中用万用表测量变频器的输入电压
文件下载请回复
