已绑定手机 已实名认证
MT6572参考设计功能列表
Page | Function | Sheet
Number
| | | 03_MT6572T_NAND-EMMC_LPDDR2_RF9810_ NO-GPS | 04_MT6572E_NAND_L PDDR1_ RF7182_NO- GPS | 05_MT6572T_EMMC_LPDDR2 _SKY77590_GPS_W18-T40 | 06_MT6572W_NAND- EMMC_LPDDR2_SKY77590_G PS_NFC | 07_MT6572W_NAND_LPD DR1_S KY77590_G PS_NFC | 08 MT6572W_NAND_L PDDR1_RF3235_GPS | Main | RF band | 04 | TD 34/39 +EDGE QB | TD 34/39/40 + EDGE QB | TD 34/39 +EDGE QB | EDGE QB | A. TD 34/39/40 + EDGE QB B. WCDMA 1/8 +EDGE QB | WCDMA Bl/2/5 + EDGE QB | WCDMA B1/8 +EDGE QB | WCDMA B1/8+ EDGE I RX QB | RF PA | 04 | RF9810 | SKY77590 | RF9810 | RF7182 | SKY77590 | SKY77590 | SKY77590 | WCDMA PA | 04 | N/A | N/A | N/A | N/A | N/A | RF7241, RF7242, RF7245 | | RF7241, RF7248 | Connectivity | 05 | WiFi, BT, FM, GPS | WiFi, BT, FM, GPS | WiFi, BT, FM, (no GPS) | WiFi, BT, FM, (no GPS) | WiFi, BT, FM, GPS | WiFi, BT, FM, GPS | WiFi, BT, FM, GPS | WiFi, BT, FM, GPS | Memory | 06 | NAND+LPDDR1 | eMMC+LPDDR2 | eMMC/NAND+LPDDR2 | NAND+LPDDR1 | eMMC+LPDDR2 | eMMC/NAND+LPDDR2 | NAND+LPDDR1 | NAND+LPDDR1 | LCD | 12 | MIPI, DSI-2 | MIPI, DSI-3 | MIPI, DSI-2 | MIPI, DSI-2 | MIPI, DSI-3 | MIPI, DSI-2 | MIPI, DSI-2 | MIPI, DSI-2 | LCD BL driver | 12 | embedded parallel, LEDx8 | ext. boost IC, LEDxlO | embedded parallel, LEDx8 | embedded parallel, LEDx8 | ext. boost IC, LEDxlO | ext. boost IC, LEDxlO | embedded parallel, LEDx8 | embedded parallel, LEDx8 | Cap touch | 12 | Yes, (COB) | Yes, (COB) | Yes, (COB) | Yes, (COB) | Yes, (COB) | Yes, (COB) | Yes, (COB) | Yes, (COB) | Camera | 13 | MIPI, CSI-2 | MIPI, CSI-2 | MIPI, CSI-2 | MIPI, CSI-2 | MIPI, CSI-2 | MIPI, CSI-2 | MIPI, CSI-2 | MIPI, CSI-2 | Sub camera | 13 | Parallel 8-bit | MIPI, CSI-2 | Parallel 8-bit | Parallel 8-bit | MIPI, CSI-2 | Parallel 8-bit | Parallel 8-bit | Parallel 8-bit | T-card | 18 | Yes, with hot-plug | Yes, with hot-plug | Yes, with hot-plug | Yes, with hot-plug | Yes, with hot-plug | Yes, with hot-plug | Yes, with hot-plug | Yes, with hot-plug | SIM | 19 | dual SIM | dual SIM | dual SIM | dual SIM | dual SIM | dual SIM | dual SIM | dual SIM | | 20 | PWRKEY, Vol-up, Voldown | PWRKEY, Vol-up, Voldown | PWRKEY, Vol-up, Vol-down | PWRKEY, Vol-up, Voldown | PWRKEY, Vol-up, Vol-down | PWRKEY, Vol-up, Vol-down | PWRKEY, Vol-up, Vol-down | PWRKEY, Vol-up, Voldown | G-sensor | 21 | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Light sensor | 21 | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Proximity sensor | 21 | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Optional | Flash LED driver | 91 | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Magnetic sensor | 92 | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Gyro sensor | 92 | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | CMMB | 93 | Yes | Yes | Yes | Yes | Yes | N/A | N/A | N/A | TD band 40 | 94 | NO | Yes | NO | NO | Yes | N/A | N/A | N/A | ATV | 95 | N/A | N/A | N/A | N/A | N/A | Yes | Yes | Yes | 2nd MIC | 96 | N/A | N/A | N/A | N/A | N/A | Yes | Yes | Yes | NFC | 97 | N/A | N/A | N/A | N/A | N/A | MT6605 | MT6605 | N/A |
文件下载请回复
