高通AR9342 5.8GHz大功率无线户外CPE产品参数,防雷防静电推荐图:
产品参数:
CPU | AR9342 | 以太网络 | IEEE802.3u MDI / MDIX 10/100 | 无线通讯 | IEEE802.11a/n | 储存 | 64Mbyte | 闪存 | 8Mbyte | POE电源 | DC12V-24V(Can support 30-50 meters cable power supply) | CPU频率 | 533MHz | Gain | 13dBi (Directional dual polarized antenna) | 水平波束宽度 | 600 | 垂直波束宽度 | 250 | 以太网接口 | 10/100Mbps | 复位按钮 | The device to restore factory settings | 系统升级 | Through the Web site upgrade; | 吞吐量 | >=120Mbps Net Throughput(Up and down) | 接口 | 1X10/100Base‐T interface, RJ‐45 with POE LED:Power/ WLAN/ LAN/ RSSIx4 | 电源 | DC12V~24V | 数据速率 | 11a: 54M, 48M, 36M, 24M, 18M, 12M, 9M, 6Mbps;HT20:7.2M,14.4M,21.7M,28.9M,43.3M,57.8M,65M,72.2M,14.4M,28.9M,43.3M,57.8M,86.7M,115.6M,130M,144.4M HT40:15M,30M,45M,60M,90M,120M,135M,150M,30M,60M,90M,120M,180M,240M,270M,300M | 传输方式 | DSSS | 调制 | OFDM/BPSK/QPSK/CCK/DQPSK/DBPSK | 频率范围 | 5180 MHz ~ 5825 MHz (channel 36~ channel165) | 耗电量 | ≦ 8W | 射频功率@ 25℃(±2dB) | 802.11a | 6-24Mbps | 21 ± 2dBm | | 36-48Mbps | 21 ± 2dBm | | 54Mbps | 20± 2dBm | 802.11n | HT20 | MCS 0-3 | 19 ± 2dBm | | | MCS 4 | 19 ± 2dBm | | | MCS 5 | 19 ± 2dBm | | | MCS 6 | 18 ± 2dBm | | | MCS 7 | 16 ± 2dBm | | HT40 | MCS 0-3 | 19 ± 2dBm | | | MCS 4 | 19± 2dBm | | | MCS 5 | 19± 2dBm | | | MCS 6 | 18 ± 2dBm | | | MCS 7 | 16 ± 2dBm | 接收灵敏度 | | 6Mbps≦-90dBm
54Mbps≦-72dBm | HT 20,MCS 0≦-86dBm,MCS 7≦-68dBm;HT 40,MCS 0≦-83dBm,MCS 7≦-65dBm |
