Feature list | Description |
Charge current Regulation | ICC level: 0.5A~3A, 0.1A/step |
VBAT = 3.8V, AG > 1000mA(TC = 30°C to 65°C), Accuracy ±5% |
Charge Voltage Regulation | CV level: 3.9V~4.71V, 10mV/step |
VOREG_CHG = 4.2V, 4.35V, 4.36V, or VOREG_CHG = 4.38V, Tc = 0°C to 70°C, Accuracy: ±0.5% |
Average Input Current Regulation (AICR) | AICR level: 0.1A/0.15A~3.25A, 50mA/step |
Synchronous 1.5Mz/0.75MHz Fixed-Frequency PWM | 1.5MHz(default) 0.75MHz/lMHz/1.5MHz selectable |
Controller with up to 95% Duty Cycle |
Thermal Regulation and Protection | 120 °C(default) 60 °C/80 °C/100 °C/120 °C selectable |
Over-Temperature Protection | Thermal shutdown threshold temperature = 150°C, Hysteresis=40°C |
CHRDETB | VBUS OVP High Threshold: 10.5V (default) VBUSOVP Range= 6.0V~14.5V. Hysteresis=150mV. |
VBUS UVLO High Threshold: 3.7V (default) VBUS UVLO Range= 2.6V~3.7V. Hysteresis=150mV. |
USB OTG | OTG output: 5.05V (default) OTG output voltage range: 4.425V~5.825V, 50mV/step. |
OTG OC: 1.3A (default) OTG OC: 0.5A/0.7A/1.1A/1.3A/1.8A/2.1A/2.4A |
USB B.C. v.1.2 Detection | USB B.C. vl.2 charging port compliance |
CHG_VIN Over-Voltage Protection Threshold | 6.5V (default) VCHG VIN rising, I2C programmable 5.5V/6.5V/11V/14.5V) |
Integrated ADCs for System Monitoring | ADC Channel: VBUS DIV5/VBUS DIV2/VBAT/VSYS/IBUS/IBAT/TEMP JC/USB ID/TS USB |
Low Battery Protection for Boost Operation | 2.8V falling (default) 2.8V/2.9V~3.8V, O.lV/step. |
Charging Watchdog (reset to default) | Watchdog time-out protection to stop charging |
Charging Safety timer |
IRQ (interrupt function) | IRQ pin support INT to AP |
MTK PumpExpress Charging | Support MTK PumpExpress+1.1 and 2.0 by HW auto-control. |
USB PD power role Support | Dual-role PD compatible |
Attach/Detach detection as host, device or DRP |
Current capability definition and detection | Source mode: Voltage: 5V ±5% Current: 2A (max) |
Sink mode: Voltage: 5V~14V ±5% Current: 3A (max) |
Cable recognition | Get e-marked cable capabilities |
ALTErnate mode support | The USB Power Delivery Structured VDMs are defined to extend the functionality a device exposes. |
VCONN input Over-Voltage Protection | 6V |
Supporting VCONN with programmable OCP | 400mA (default) VCONN level: 200mA~800mA, lOOmA/step |
Dead battery support | CC always is RD mode when dead battery |
BMC BIST mode supported | BMC Built in Self-Test |
Supported PD 3.0 | Support Universal Serial Bus Power Delivery SPECification 3.0 |
1. 根据电池电压等级改变充电状态
2. 包括 VBAT 过放电时的涓流充电
3. MT6360具有IR补偿(从充电器到电池连接器的电阻补偿)和恒压模式终止
