The FP6277 is a current mode boost DC DC converter with PWM/PSM control. Its PWM circuitry
with built-in 30mΩ high side switch and 30mΩ low side switch make this regulator highly power efficient.
The internal compensation network also minimizes external component counts to only 6. An internal
0.6V voltage is connected to error amplifier the non-inverting input as precision reference voltage.
Built-in soft-start function can reduce the inrush current.
Features特点:
Current mode with PWM/PSM control
Input voltage range: 2.4V~4.5V
Adjustable Output up to 5.3V
Shutdown current: <1uA
Oscillator frequency: 500KHz
Reference voltage: 0.6V +/-2%
Disconnect load during shutdown
Cycle-by-cycle current limit
Low RDS(on): 30mΩ for both high and low side
Protection: OTP, OCP, SCP
Internal compensation
Internal soft-start: 7ms
Package: SOP-8L(EP)
Applications应用:
Chargers
Handheld Devices
Portable products
Power Bank
