Soc | 类型 | 机型 | Android | 一键编译 | kernel编译 | uboot 编译 |
RK3566 | 平板 | 样机 | build/envsetup.sh;lunch rk3566_rgo-userdebug | ./build.sh - AUCKu | make ARCH=arm64 rockchip_defconfig android-11.config;make ARCH=arm64 rk3566-RK817-tablet.img -j24 | ./make.sh rk3566 |
RK3568 | 开发板 | EVB1- DDR4-V10 | build/envsetup.sh;lunch rk3568_r-userdebug | ./build.sh - AUCKu | make ARCH=arm64 rockchip_defconfig rk356x_evb.config android-11.config;make ARCH=arm64 rk3568-evb1-ddr4-v10.img -j24 | ./make.sh rk3568 |
RK3568 | 开发板 | EVB2- LPDDR4X- V10 | build/envsetup.sh;lunch rk3568_r-userdebug | ./build.sh - AUCKu | make ARCH=arm64 rockchip_defconfig rk356x_evb.config android-11.config;make ARCH=arm64 rk3568-evb2-lp4x-v10.img -j24 | ./make.sh rk3568 |
RK3568 | 开发板 | EVB4- LPDDR3- V10 | build/envsetup.sh;lunch rk3568_r-userdebug | ./build.sh - AUCKu | make ARCH=arm64 rockchip_defconfig rk356x_evb.config android-11.config;make ARCH=arm64 rk3568-evb4-lp3-v10.img -j24 | ./make.sh rk3568 |
RK3568 | 开发板 | EVB5- DDR4-V10 | build/envsetup.sh;lunch rk3568_r-userdebug | ./build.sh - AUCKu | make ARCH=arm64 rockchip_defconfig rk356x_evb.config android-11.config;make ARCH=arm64 rk3568-evb5-ddr4-v10.img -j24 | ./make.sh rk3568 |
RK3568 | 开发板 | EVB6- DDR3-V10 | build/envsetup.sh;lunch rk3568_r-userdebug | ./build.sh - AUCKu | make ARCH=arm64 rockchip_defconfig rk356x_evb.config android-11.config;make ARCH=arm64 rk3568-evb 6-d d r3-v 10. i mg -j24 | ./make.sh rk3568 |
RK3568 | 开发板 | EVB7- DDR4-V10 | build/envsetup.sh;lunch rk3568_r-userdebug | ./build.sh - AUCKu | make ARCH=arm64 rockchip_defconfig rk356x_evb.config android-11.config;make ARCH=arm64 rk3568-evb7-ddr4-v10.img -j24 | ./make.sh rk3568 |
RK3566 | 开发板 | EVB1- DDR4-V10 | build/envsetup.sh;lunch rk3566_r-userdebug | ./build.sh -AUCKu -d rk3566-evb2-lp4x-v10 | make ARCH=arm64 rockchip_defconfig rk356x_evb.config android-11.config;make ARCH=arm64 rk3566-evb1-ddr4-v10.img -j24 | ./make.sh rk3566 |
RK3566 | 开发板 | EVB2- LP4X-V10 | build/envsetup.sh;lunch rk3566_r-userdebug | ./build.sh -AUCKu -d rk3566-evb2-lp4x-v10 | make ARCH=arm64 rockchip_defconfig rk356x_evb.config android-11.config;make ARCH=arm64 rk3566-evb2-lp4x-v10.img -j24 | ./make.sh rk3566 |
