1、创建一个空的java项目
2、创建data Ability
如下步骤所示,创建完成后会生成相应的文件,同时会帮您修改好配置文件。
配置文件(这部分自动生成,与你的目录结果、建议不要修改):
"permissions": [
"com.example.rdb.DataAbilityShellProvider.PROVIDER"
"name": "com.example.rdb.Database.fristRDB",
"icon": "$media:icon",
"description": "$string:fristrdb_description",
"type": "data",
"visible": false,
"uri": "dataability://com.example.rdb.Database.fristRDB"
3、编写创建数据库代码
编写的fristRDB.java文件:
package com.example.rdb.Database;
import ohos.aafwk.ability.Ability;
import ohos.aafwk.ability.DataAbilityHelper;
import ohos.aafwk.content.Intent;
import ohos.data.DatabaseHelper;
import ohos.data.dataability.DataAbilityUtils;
import ohos.data.rdb.*;
import ohos.data.resultset.ResultSet;
import ohos.data.dataability.DataAbilityPredicates;
import ohos.hiviewdfx.HiLog;
import ohos.hiviewdfx.HiLogLabel;
import ohos.utils.net.Uri;
import ohos.utils.PacMap;
import java.io.FileDescriptor;
public class fristRDB extends Ability {
// 数据库参数
private static final String DB_NAME = "persondataability.db"; //数据库名称
private static final String DB_TAB_NAME = "person"; //表名称
private static final String DB_COLUMN_PERSON_ID = "id"; //列 id
private static final String DB_COLUMN_NAME = "name"; //列 name
private static final String DB_COLUMN_GENDER = "gender"; //列 gender
private static final String DB_COLUMN_AGE = "age"; //列 age
private static final int DB_VERSION = 1; //版本
private static final HiLogLabel LABEL_LOG = new HiLogLabel(3, 0xD001100, "Demo");
private StoreConfig config = StoreConfig.newDefaultConfig(DB_NAME); //通过指定数据库名称使用默认配置创建数据库配置。
private RdbStore rdbStore; //提供管理关系数据库 (RDB) 的方法。
// RdbOpenCallback 管理数据库创建、升级和降级。
private RdbOpenCallback rdbOpenCallback = new RdbOpenCallback() {
@Override
public void onCreate(RdbStore store) { // 数据库创建时被回调,开发者可以在该方法中初始化表结构,并添加一些应用使用到的初始化数据。
store.executeSql("create table if not exists "
+ DB_TAB_NAME + " ("
+ DB_COLUMN_PERSON_ID + " integer primary key, "
+ DB_COLUMN_NAME + " text not null, "
+ DB_COLUMN_GENDER + " text not null, "
+ DB_COLUMN_AGE + " integer)");
@Override
public void onUpgrade(RdbStore store, int oldVersion, int newVersion) {
@Override
public void onStart(Intent intent) {
super.onStart(intent);
HiLog.info(LABEL_LOG, "fristRDB onStart");
DatabaseHelper databaseHelper = new DatabaseHelper(this);
// 根据配置创建或打开数据库。
rdbStore = databaseHelper.getRdbStore(config, DB_VERSION, rdbOpenCallback, null);
* 数据查询
* @param uri
* @param columns
* @param predicates
* @return
@Override
public ResultSet query(Uri uri, String[] columns, DataAbilityPredicates predicates) {
// 拼装查询语句
RdbPredicates rdbPredicates = DataAbilityUtils.createRdbPredicates(predicates, DB_TAB_NAME);
// 查询表中数据 根据 查询语句 + 查找的列
ResultSet resultSet = rdbStore.query(rdbPredicates, columns);
if (resultSet == null) {
HiLog.info(LABEL_LOG, "resultSet is null");
return resultSet;
* 数据添加
* @param uri 插入的目标路径
* @param value 插入的数据值
* @return
@Override
public int insert(Uri uri, ValuesBucket value) {
HiLog.info(LABEL_LOG, "fristRDB insert");
String path = uri.getLastPath();
// 判断数据添加的表名称
if (!"person".equals(path)) {
HiLog.info(LABEL_LOG, "DataAbility insert path is not matched");
return -1;
//用于整理存储添加的数据
ValuesBucket values = new ValuesBucket();
values.putInteger(DB_COLUMN_PERSON_ID, value.getInteger(DB_COLUMN_PERSON_ID));
values.putString(DB_COLUMN_NAME, value.getString(DB_COLUMN_NAME));
values.putString(DB_COLUMN_GENDER, value.getString(DB_COLUMN_GENDER));
values.putInteger(DB_COLUMN_AGE, value.getInteger(DB_COLUMN_AGE));
int index = (int) rdbStore.insert(DB_TAB_NAME, values);
// 当表格数据插入成功时,可执行DataAbilityHelper.creator(this, uri).notifyChange(uri),通知该表格数据的订阅者
DataAbilityHelper.creator(this, uri).notifyChange(uri);
return index;
* 数据删除
* @param uri 删除的目标路径
* @param predicates 删除条件
* @return
@Override
public int delete(Uri uri, DataAbilityPredicates predicates) {
// 解析出要删除的数据
int index = rdbStore.delete(rdbPredicates);
HiLog.info(LABEL_LOG, "delete: " + index);
// 通知观察者数据已经修改
return index;
* 数据修改
* @param uri
* @param value
* @param predicates
* @return
@Override
public int update(Uri uri, ValuesBucket value, DataAbilityPredicates predicates) {
// 解析出要修改的数据
int index = rdbStore.update(value, rdbPredicates);
HiLog.info(LABEL_LOG, "update: " + index);
// 通知观察者数据已经修改
return index;
@Override
public FileDescriptor openFile(Uri uri, String mode) {
return null;
@Override
public String[] getFileTypes(Uri uri, String mimeTypeFilter) {
return new String[0];
@Override
public PacMap call(String method, String arg, PacMap extras) {
return null;
@Override
public String getType(Uri uri) {
return null;
public void myInsert(){
values.putInteger("id", 1);
values.putString("name", "zhangsan");
values.putInteger("age", 18);
long id = rdbStore.insert("person", values);
