RK860是一款高效2.4MHz同步降压DC/DC稳压器IC,能够提供高达6A的输出电流。它可以在2.7V至5.5V的宽输入电压范围内工作。并且,它集成了一个主开关和一个同步开关,具有极低的RDS(ON),以最大限度地减少传导损耗。输出电压可通过
I2C接口在0.7125V至1.5V之间以12.5mV/步或0.5V至1.5V以6.25mV/步进行编程。RK860采用节省空间的薄型WLCSP1.65mm*2.05mm-20包。
●输入电压范围:2.7V-5.5V
●2.4MHz的开关频率最大限度地减少了外部元件
●VIN=3.8V、Temp=25℃时的典型静态电流为70uA
●内部开关(PFET/NFET)的低RDs(ON):24mohm/16ohm @ VIN=3.8V
●可编程输出电压:0.7125V to 1.5V with 12.5mV/step or 0.5V to 1.5V with 6.25mV/step
●6A连续输出电流能力
●可接0.24uH电感和22uF*2陶瓷电容
●Hic-cup模式保护硬短路条件
●集成内部保护:逐周期OCP和VIN-
OVP/UVLO/DIE-TSD
●符合 RoHS 和无卤素
●紧凑封装:WLCSP 1.65*2.05-20
典型应用图
绝对最大额定值
Parameter | Value | Units |
Voltage range on pins VIN: | 6.0 | V |
Voltage range on other pins | VIN+0.6 | V |
Continuous power disSIPation, PD @TA=25℃,WCSP4*5-20 | 0.5 | w |
Junction temperature range, Tj | -40-150 | °C |
Lead Temperature(soldering 10 sec),TSOLDER | 260 | °C |
Storage temperature range, Ts | -65-150 | °C |
ESD Susceptibility |
ESD HBM | 2000 | V |
ESD CDM | 1000 | V |
推荐工作环境
Parameter | Symbol | value | Units |
Supply Input Voltage | VIN | 2.7-5.5 | V |
Output Voltage | VOUT | 0.5-1.5 | V |
Inductor | L | 0.22-0.47 | uH |
Input Capacitor | CIN | >10 | uF |
Output Capacitor | COUT | 44-88 | uF |
Junction temperature range | Tj | -40-125 | °C |
Ambient temperature range | Ta | -40-85 | °C |
