基本概念及Neclus内核定时器初始化
expires:指定定时器到期的时间,这个时间被表示成自系统启动以来的时钟滴答计数(也即时钟节拍数)。当一个定时器的expires值小于或等于jiffies变量时,我们就说这个定时器已经超时或到期了。在初始化一个定时器后,通常把它的expires域设置成当前expires变量的当前值加上某个时间间隔值(以时钟滴答次数计。
typedef struct timertable
{ /* store the timer_id. MSB(Most Significant Bit) is align_timer_mask */
U16 timer_id[SIMULTANEOUS_TIMER_NUM];
/* store the event_id that returns from evshed_set_event() */
eventid event_id[SIMULTANEOUS_TIMER_NUM];
/* store the timer_expiry_func */
oslTimerFuncPtr callback_func[SIMULTANEOUS_TIMER_NUM];
/* point to the next TIMERTABLE data */
struct timertable *next;
} TIMERTABLE;
typedef lcd_dll_node *eventid;
struct lcd_dll_node {
void *data;
lcd_dll_node *prev;
lcd_dll_node *next;
(1)timer_id:定时器id最多同时12个。
(2)双向链表元素event_id:用来将多个定时器调度动作连接成一条双向循环队列。
(3)函数指针callback_func:指向一个可执行函数。当定时器到期时,内核就执行function所指定的函数,产生expires 消息。
//L4 init the timer
void L4InitTimer(void)
/* Local Variables */
TIMERTABLE *p;
TIMERTABLE *pp;
/* Code Body */
/* Try to free TIMERTABLE list exclude g_timer_table */
p = g_timer_table.next;
pp = NULL;
do
if (p != NULL)
pp = p->next;
OslMfree(p);
p = pp;
} while (p != NULL);
/* reset g_timer_talbe */
memset(&g_timer_table, 0, sizeof(TIMERTABLE));
g_timer_table_size = SIMULTANEOUS_TIMER_NUM;
g_timer_table_used = 0;
/* Initiate the clock time callback function. */
get_clocktime_callback_func = NULL;
set_clocktime_callback_func = NULL;
/* Initate the no alignment stack timer */
stack_init_timer (&base_timer1, "MMI_Base_Timer1", MOD_MMI);
/* Create a no alignment timer schedule */
event_scheduler1_ptr = new_evshed(&base_timer1,
L4StartBaSETimer, L4StopBaseTimer,
0 , kal_evshed_get_mem, kal_evshed_free_mem, 0);
/* Initate the alignment stack timer */
stack_init_timer (&base_timer2, "MMI_Base_Timer2", MOD_MMI);
/* Create an alignment timer schedule */
event_scheduler2_ptr = new_evshed(&base_timer2,
L4StartBaseTimer, L4StopBaseTimer,
0, kal_evshed_get_mem, kal_evshed_free_mem, 255);
typedef struct stack_timer_struct_t {
module_type dest_mod_id;
kal_timerid kal_timer_id;
kal_uint16 timer_indx;
stack_timer_status_type timer_status;
kal_uint8 invalid_time_out_count;
} stack_timer_struct;
实际上,这个初始化函数仅仅将TIMERTABLE链表初始化为空。初始化g_timer_table_size及g_timer_table_used参数。设置定时器调度函数指针。
由于定时器通常被连接在一个双向循环队列中等待执行(此时我们说定时器处于pending状态)。因此函数evshed_events_pending就可以用list成员是否为空来判断一个定时器是否处于pending状态。
kal_bool evshed_events_pending(event_scheduler *es);
二、Linux动态内核定时器机制的原理
Linux是怎样为其内核定时器机制提供动态扩展能力的呢?其关键就在于“定时器向量”的概念。所谓“定时器向量”就是指这样一条双向循环定时器队列(对列中的每一个元素都是一个timer_list结构):对列中的所有定时器都在同一个时刻到期,也即对列中的每一个timer_list结构都具有相同的expires值。显然,可以用一个timer_list结构类型的指针来表示一个定时器向量。
显然,定时器expires成员的值与jiffies变量的差值决定了一个定时器将在多长时间后到期。在32位系统中,这个时间差值的最大值应该是0xffffffff。因此如果是基于“定时器向量”基本定义,内核将至少要维护0xffffffff个timer_list结构类型的指针,这显然是不现实的。
另一方面,从内核本身这个角度看,它所关心的定时器显然不是那些已经过期而被执行过的定时器(这些定时器完全可以被丢弃),也不是那些要经过很长时间才会到期的定时器,而是那些当前已经到期或者马上就要到期的定时器(注意!时间间隔是以滴答次数为计数单位的)。
基于上述考虑,并假定一个定时器要经过interval个时钟滴答后才到期(interval=expires-jiffies),则Linux采用了下列思想来实现其动态内核定时器机制:对于那些0≤interval≤255的定时器,Linux严格按照定时器向量的基本语义来组织这些定时器,也即Linux内核最关心那些在接下来的255个时钟节拍内就要到期的定时器,因此将它们按照各自不同的expires值组织成256个定时器向量。而对于那些256≤interval≤0xffffffff的定时器,由于他们离到期还有一段时间,因此内核并不关心他们,而是将它们以一种扩展的定时器向量语义(或称为“松散的定时器向量语义”)进行组织。所谓“松散的定时器向量语义”就是指:各定时器的expires值可以互不相同的一个定时器队列。
