1.一般的描述
LT8641UX HDMI2.0 4:1开关的开关特性HDMI2.0/1.4规范,最大6 gbps高速数据率、自适应均衡RX输入和pre-emphasized TX输出支持长电缆应用程序,没有晶体和1.2 v电源保存BOM成本、内部灵活的PCB TX巷交换路由。
LT8641UX HDMI2.0开关自动检测线损,自适应优化均衡设置。CDR消除了输入数据的抖动,使其适合长电缆和级联应用。它支持RX终端电阻校准,进一步提高信号完整性。
LT8641UX支持符合HDMI2.0/1.4规范的DDC/SCDC。DDC与HPD交换机的集成进一步降低了系统制造成本,简化了系统板上的布线。
2. 特性
•4个输入,1个输出HDMI2.0链路
•兼容HDMI 1.4/2.0
•支持高达6.0Gbps的数据速率
•TX/RX侧odt和管理电路
•集成HPD开关、DDC开关、+5V电源指示灯开关,大大降低成本,简化制造工艺
•源/Sink连接检测,灵活的系统管理
支持I2C控制
•单路3.3V电源
•允许5v电压的DDC接口
抖动清洗锁相环更好的性能
•直流/交流耦合信号输入/输出
•不需要外部晶体
•自适应均衡
•TX Lane交换灵活的PCB路由
3.应用程序
•高级电视(HDTV)前面板缓冲器
•独立切换器
•多输入显示
•投影仪
•A / V接收器
1.General Description
The Lontium LT8641UX HDMI2.0 Switch features a 4:1 switch compliant to HDMI2.0/1.4 specification, max 6Gbps high speed data rate, adaptive equalization RX input and pre-emphasized TX output to support long cable application, no XTAL and 1.2V power supply on board to save BOM cost, internal TX lane swap for flexible PCB routing .
LT8641UX HDMI2.0 Switch automatically detect the cable loss, and adaptively optimize the equalization setting. The CDR cleans the input data jitter, make it suitable for long cable and cascade application. It support RX termination resistor calibration to further improve signal integrity.
LT8641UX support DDC/SCDC compliant to HDMI2.0/1.4 specification. The integrated DDC and HPD switches further lower the cost of system manufacture, and simplify the routing on the system board.
2. Features
• 4 inputs, 1output HDMI2.0 links
• HDMI 1.4/2.0 compliant
• Supports data rates up to 6.0Gbps
• TX/RX side ODTs and management circuitry
• Integrated HPD switch, DDC switch, and +5V Power indicator switch, greatly lowering the cost and simplifying the manufacturing process
• Source/Sink connection detection for flexible system management
• I2C control supported
• Single 3.3V power supply
• 5V-tolerant DDC interfaces
• Jitter cleaning PLL for better performance
• DC/AC coupled signal input/output
• No external crystal is needed
• Adaptive equalization
• TX Lane swap for flexible PCB routing
3. APPLICATIONS
• Front panel buffer for advanced television (HDTV) sets
• Standalone switcher
• Multiple input displays
• Projector
• A/V receivers
九黎科技是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!
