环境配置
#安装交叉编译器:
sudo mkdir /usr/local/
arm
sudo cp gcc-linaro-7.5.0-2019.12-i686_aarch64-
linux-gnu.tar /usr/local/arm/ -f
sudo tar -vxf gcc-linaro-7.5.0-2019.12-i686_aarch64-linux-gnu.tar
sudo vi /
ETC/
profile
#复制这行到文本最后一行:export PATH=$PATH:/usr/local/arm/gcc-linaro-7.5.0-2019.12-i686_aarch64-linux-gnu/bin
MAKE RK3588_defconfig ARCH=arm CROSS_COMPILE=aarch64-linux-gnu-
make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu-
问题:error while lo
ADIng shared libraries: libz.so.1
解决方法:
sudo apt-get update
sudo apt-get install lib32z1
