RK3588 全套硬件资料
├── 01_Common Document
│ ├── RK3588 Hardware Design
GUIde-V1.0.pdf
│ ├── RK3588 Methods for Processing Unu
SED Pins_V1.0_20211228.xlsx
│ ├── RK3588
power Consumption Test Report V1.0_20211230_CN .xlsx
│ ├── RK3588_Package_PinLength_V1.0_20211228_EN.xlsx
│ ├── RK3588_PinOut_V1.0_20211228.xlsx
│ ├── RK
EMMCsupportList Ver1.63_20220112.pdf
│ ├── Rockchip RK3588
datasheet V1.1-20220124.pdf
│ ├── Rockchip
RK806 Datasheet V1.0 -20211020.pdf
│ ├── Rockchip_RK3588_
EVB_User_Guide_V1.0_CN.pdf
│ ├── Rockchip_RK3588_EVB_User_Guide_V10_EN_0126.pdf
│ └── Rockchip RK860 Datasheet V1.2-20211011.pdf
├── 02_DDR Template
│ ├── 01_H1R6_V10_20211229
│ │ ├── RK3588_Template_LP4XD200
P232SD8_41R0X41R0_2133MHz_H1R6_V10_20211229.DSN
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R6_V10_20211229.brd
PCB
核心板设计重点说明.doc
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R6_V10_20211229阻抗叠层.xls
Allegro.jrl
│ ├── 02_H1R0_V10_20211230
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230.DSN
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230.brd
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230.pcb
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230核心板设计重点说明.doc
│ │ └── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230阻抗叠层.xls
│ └── RK3588 DDR Template List.xlsx
├── 03_
product Line Branch_
AIoT
│ ├── 01_Product Document
│ ├── 02_Key
device SPECifications
│ │ ├── 315b_y31m_ddp_qdp_embedded_
LPDDR5.pdf
│ │ ├── AP6275P draft datasheet_V0.5_20200306.pdf
ES8388 DS.pdf
ESD73034D - Rev1.1.pdf
│ │ ├── IT6516BFN Datasheet v0.91.pdf
│ │ ├── LP4X_32Gb_A_200F_10x15_K4UBE3D4AA-MGCL_Rev1.1.pdf
│ │ ├── MP8759GD-Z.pdf
│ │ ├── Molex
HDMI2.1 2086581061.pdf
│ │ ├── Molex TYPEC 2012670005.pdf
PI6C557-03B.pdf
PI6C557-05B.pdf
RTL8111H(S)-CG_Datasheet_1.92.pdf
RTL8211FS(I)(-VS)-CG_DataSheet_1.8.pdf
SGM2019 REV.C.1_20160429.pdf
│ │ ├── SPI NOR_GD25LQ255E-Rev1.0.pdf
SY6280 Rev0.3.pdf
│ │ ├── TFM201610ALC-TCA.pdf
│ │ └── TMS322512ALM.pdf
│ ├── 03_Reference Design
│ │ ├── 01_RK3588_AIoT_REF_SCH
│ │ │ ├── RK3588_AIOT_REF_SCH_V10_20211228-162.DSN
│ │ │ ├── RK3588_AIOT_REF_SCH_V10_20211228.DSN
│ │ │ └── RK3588_AIOT_REF_SCH_V10_20211228.pdf
│ │ └── 02_PCB_Library
│ │ ├── RK3588_RK3588S_RK806_RK860_pkg_allegro.zip
│ │ └── RK3588_RK3588S_RK806_RK860_pkg_
PADS.zip
│ └── RK3588_AIOT_Hardware Document
release Note and File List_V10_20211228_CN.xlsx
├── 04_Product Line Branch_N
VR
│ ├── 02_Key Device Specifications
│ │ ├── AN_SY6280.pdf
│ │ ├── AN_
SY8113B.pdf
ES8311 DS.pdf
│ │ ├── ETA3409-1uH.pdf
│ │ ├── FUSB302B.pdf
│ │ ├── IT6161_Datasheet_V0.88.pdf
│ │ ├── IT6516BFNCX Datasheet v0.91.pdf
│ │ ├── IT6563_FN_Datasheet_v0.92.pdf
│ │ ├── MP8759_r1.1.pdf
│ │ ├── PDS-16011
JMB575 Datasheet (Rev. 1.2).pdf
│ │ ├── PI6C557-05B.pdf
PT5108-V3.01.pdf
│ │ ├── RTC IC
HYM8563 Spec.pdf
│ │ ├── RTL8211F(D)(I)-CG_DataSheet_1.2.pdf
│ │ ├── SIT-SIT3232E.pdf
SIT3485E-datasheet-V1.1.pdf
SY8089.pdf
│ ├── 04_Demo Reference Design
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228-162.DSN
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228.DSN
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228.pdf
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228_Modify_Notes_CN.pdf
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228_final_lint.brd
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228_final_lint阻抗叠层.xls
│ │ ├── allegro.jrl
│ │ └── allegro.jrl,1
│ └── RK3588_NVR_Hardware Document Release Note and File List_V10_20211228_CN.xlsx
15 directories, 73 files
