已绑定手机 已实名认证
各型号规格及应用场景,选型用的表格
1、智能电视方案
芯片型号 | RK3566 | RK3399 | RK3288 | PIN TO PIN | rk3368 | RK3228H | RK3328 | 制程 | 22nm | 28nm | 28nm | 28nm | 28nm | 28nm | 封装 | FCCSP565L 15.5mm*14.4mm*0.9mm
0.65mm&0.4mm pitch | FCBGA828 21mm*21mm*1.5mm
0.65mm pitch | BGA636 19mm*19mm*1.6mm
0.65mm pitch | TFBGA395L 14mm*14mm*1.2mm
0.65mm pitch | BGA453 19mm*19mm*1.4mm
0.8mm pitch | CPU | 64bit Quad-Core A55,
up to 1.8GHz | Quad-Core A53,
up to 1.4GHz
Dual-Core A72,
up to 1.8GHz | Quad-Core A17,
up to 1.6/1.8GHz | 64-bit Quad-Core A53,
up to 1.5GHz | 64-bit Quad-Core A53,
up to 1.5GHz | 64bit Octa-core A53,up to 1.5GHz | GPU | Mali-G52-2EE
800MHz | Mali-T860MP4
600MHz | Mali-T760MP4
500M/600M | Mali-450 MP2
500MHz | Mali-450 MP2
500MHz | G6110 GPU
600MHz | CPU RAM | one channel DDR controller up to 8G Byte,
DDR3/3L-800Mbps,
DDR4-1056Mbps,
LPDDR3-800Mbps,
LPDDR4-1056Mbps
LPDDR4X-1056Mbps | dual channels DDR controller up to 4G Byte,
DDR3/3L-2133Mbps,
LPDDR3-2133Mbps,
LPDDR4-2133Mbps, | dual channels DDR controller up to 8G Byte,
DDR3/3L-1333Mbps,
LPDDR3/2-1066Mbps | one channel DDR controller up to 4G Byte,
DDR3/3L-1866Mbps,
LPDDR3-1866Mbps,
DDR4-2133Mbps | one channel DDR controller up to 4G Byte,
DDR3/3L-1866Mbps,
LPDDR3-1866Mbps,
DDR3/3L-1600Mbps,
LPDDR3-1333Mbps,
LPDDR2-1066Mbps | NPU | Up to 0.8TOPS | N/A | N/A | N/A | N/A | N/A | NPU RAM | N/A | N/A | N/A | N/A | N/A | N/A | Memory | NAND,
eMMC5.1
HS200 mode | eMMC5.1
HS400 mode | NAND,
Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 | eMMC5.1 | eMMC5.1 | NAND,
Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 | Video Decode | 4K@60fps H.264&H.265&VP9 Profile0/2 video decode,1080P multi video decode | 4K H.264 and 10bits 60fps H.265 video decode,1080P multi video decode | 4K H.264 and 10bits 60fps H.265 video decode,1080P multi video decode | 4K H.264/H.265/VP9 10bits 60fps video decode,1080P multi video decode | 4K H.264/H.265/VP9 10bits 60fps video decode,1080P multi video decode | 4K H.265/H.264 video decoder,1080P multi video decode |
2、视觉AI方案
芯片型号 | RK3399PRO | RK3568 | RK3566 | PIN TO PIN | RK1608 | PIN TO PIN | RK1808 | RK1806 | RV1108G | RV1108A | RV1107 | 制程 | 28nm | 22nm | 22nm | 22nm | 22nm | 28nm | 28nm | 28nm | 28nm | 封装 | FCBGA1372 27mm*27mm*2.2mm
0.65mm pitch | FCBGA636L 19mm*19mm*1.68mm
0.65mm pitch | FCCSP565L 15.5mm*14.4mm*0.9mm
0.65mm&0.4mm pitch | FCCSP420L 14mm*14mm*1.1mm
0.7mm pitch | FCCSP420L 14mm*14mm*1.1mm
0.7mm pitch | BGA217 10mm*8mm*1.1mm
0.4mm pitch
| BGA359 14mm*14mm*1mm
0.65mm pitch | BGA359 14mm*14mm*1mm
0.65mm pitch | CPU | Quad-Core A53,
up to 1.4GHz
Dual-Core A72,
up to 1.8GHz | 64bit Quad-Core A55,
up to 2GHz | 64bit Quad-Core A55,
up to 1.8GHz | Dual-Cortex A35,
up to 1.6GHz | Dual-Cortex A35,
up to 1.6GHz | Dual-core DSP,
up to 600MHz | Single-core A7,
up to 1.0GHz | Single-core A7,
up to 1.0GHz | GPU | Mali-T860MP4
600MHz | Mali-G52-2EE
800MHz | Mali-G52-2EE
800MHz | N/A | N/A | N/A | N/A | N/A | N/A | DSP | N/A | N/A | N/A | N/A | N/A | N/A | CEVA XM4 DSP
400MHz | CEVA XM4 DSP
400MHz | CPU RAM | dual channels DDR controller up to 4G Byte,
DDR3/3L-2133Mbps,
LPDDR3-2133Mbps,
LPDDR4-2133Mbps, | one channel DDR controller up to 8G Byte,
DDR3/3L-2133Mbps,
DDR4-3200Mbps,
LPDDR3-2133Mbps,
LPDDR4-3200Mbps
LPDDR4X-3200Mbps | one channel DDR controller up to 8G Byte,
DDR3/3L-800Mbps,
DDR4-1056Mbps,
LPDDR3-800Mbps,
LPDDR4-1056Mbps
LPDDR4X-1056Mbps | one channel DDR controller up to 4G Byte,
DDR4-2133Mbps,
DDR3/3L-1600Mbps,
LPDDR3-1600Mbps,
LPDDR2-1066Mbps | one channel DDR controller up to 4G Byte,
DDR4-2133Mbps,
DDR3/3L-1600Mbps,
LPDDR3-1600Mbps,
LPDDR2-1066Mbps | Embed,
RK1608A 1G bit,
RK1608B 2G bit,
LPDDR2-1066Mbps | Embed 128MB,
DDR3/3L-1600Mbps | one channel 16bit DDR controller up to 512M Byte,
DDR3/3L-1066Mbps | one channel 16bit DDR controller up to 512M Byte,
DDR3/3L-1066Mbps | NPU | Up to 3.0TOPS | Up to 0.8TOPS | Up to 0.8TOPS | Up to 3.0TOPS | Up to 1.2TOPS | N/A | N/A | N/A | N/A | NPU RAM | one channel DDR controller up to 2G Byte,
DDR3/3L-1600Mbps,
LPDDR3-1600Mbps,
LPDDR2-1066Mbps | N/A | N/A | N/A | N/A | N/A | N/A | N/A | N/A | Memory | eMMC5.1
HS400 mode | NAND,
eMMC5.1
HS200 mode | NAND,
eMMC5.1
HS200 mode | Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 | Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 | N/A | NAND,
Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 | NAND,
