Feature | Description |
WLAN Standard | IEEE 802.11b/g/n/ax WiFi compliant |
Frequency Range | 2.400 GHz ~ 2.497 GHz (2.4 GHz ISM Band) |
Number of Channels | 2.4GHz : Ch1 ~Ch14 |
Modulation | 802.11b: DQPSK, DBPSK, CCK 802.11 g/n : OFDM /64-QAM,16-QAM, QPSK, BPSK 802.11 ax : OFDMA /1024-QAM,256-QAM, 64-QAM, 16-QAM, QPSK, BPSK |
Output power | 802.11b/ 1Mbps : 17dBm ±2dB@ EVM < -10dB 802.11b/11Mbps: 17dBm±2dB@ EVM<-15dB |
802.11g/6Mbps : 17dBm ± 2 dB @ EVM < -5dB 802.11g/54Mbps : 14dBm±2dB@ EVM < -28dB |
802.11 n /MCS0 : 17dBm ± 2 dB @ EVM < -5dB 802.11n/MCS7 : 14dBm ± 2 dB @ EVM < -30dB |
802.11 ax /HE0(20/40M) : 17dBm ± 2 dB @ EVM < -5dB 802.11 ax /HE11(20/40M) : 13dBm ± 2 dB @ EVM < -32dB |
Receive Sensitivity (11b,20MHz) @8% PER | 1 Mbps PER @ -93 dBm, typical |
- 2Mbps PER @ -90 dBm, typical |
-5.5Mbps PER @ -88 dBm, typical |
-11Mbps PER @ -86 dBm, typical |
Receive Sensitivity (11g,20MHz) @10% PER | - 6Mbps PER @ -91 dBm, typical |
- 9Mbps PER @ -89 dBm, typical |
-12Mbps PER @ -86 dBm, typical |
-18Mbps PER @ -83 dBm, typical |
-24Mbps PER @ -80 dBm, typical |
-36Mbps PER @ -77 dBm, typical |
-48Mbps PER @ -74 dBm, typical |
-54Mbps PER @ -72 dBm, typical |
Receive Sensitivity (11 n,20MHz) @10% PER | MCS=0,PER @ -90 dBm, typical |
MCS=1,PER @ -87 dBm, typical |
MCS=2,PER @ -84 dBm, typical |
MCS=3,PER @ -81 dBm, typical |
MCS=4,PER @ -78 dBm, typical |
