| PIN TO PIN | | |
制程 | 22nm | 22nm | 28nm | 40nm |
封装 | FCCSP420L 14mm*14mm*1.1mm | FCCSP420L 14mm*14mm*1.1mm | BGA359 14mm*14mm*1mm 0.65mm pitch | 0.65mm pitch |
CPU | Dual-Cortex A35, up to 1.6GHz | Dual-Cortex A35, up to 1.6GHz | Single-core A7, up to 1.0GHz | Quad-Core A7, up to 1.2GHz |
GPU | N/A | N/A | N/A | Mali400MP2 400MHz |
DSP | N/A | N/A | CEVA XM4 DSP 400MHz | N/A |
CPU RAM | one channel DDR controller up to 4G Byte, DDR4-2133Mbps, DDR3/3L-1600Mbps, LPDDR3-1600Mbps, LPDDR2-1066Mbps | one channel DDR controller up to 4G Byte, DDR4-2133Mbps, DDR3/3L-1600Mbps, LPDDR3-1600Mbps, LPDDR2-1066Mbps | one channel 16bit DDR controller up to 512M Byte, DDR3/3L-1066Mbps | one channel DDR controller up to 2G Byte, DDR3/3L-1066Mbps, LPDDR2-800Mbps |
NPU | Up to 3.0TOPS | Up to 3.0TOPS | N/A | N/A |
Memory | Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 | Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 |
| NAND,
Video Decode | H.264/AVC Base/Main/High@level4.2 | H.264/AVC Base/Main/High@level4.2 | 1440p@30fps/ 1080p@60fps H.264 | H.265 video decode,1080P multi video decode |
Video Encode | H.264 video encoder at BP/MP/HP@level4.1 | H.264 video encoder at BP/MP/HP@level4.1 | 1080P video encoding for H.264 | 1080P video encoding for H.264 and VP8,MVC |
Codec | N/A | N/A | Embed | Embed |
Audio Format | MP3、WMA、OGG、APE、FLAC、 AAC etc | MP3、WMA、OGG、APE、FLAC、AAC etc | MP3、WMA、OGG、APE、FLAC、AAC etc | MP3、WMA、OGG、APE、FLAC、AAC etc |
SDIO Interface | SDIO3.0 | SDIO3.0 | SDIO3.0 | SDIO3.0 |
SD/MMC Interface | SD3.0/MMC4.51 | SD3.0/MMC4.51 | SD3.0/MMC4.51 | SD2.0/MMC4.5 |
| YES | YES | YES | YES |
PCIe | PCIe2.1 | N/A | N/A | N/A |
LCD Interface | up to 1920*1080, MIPI,RGB | up to 1920*1080, MIPI,RGB | up to 1280*720, MIPI,RGB | up to 1920*1080, MIPI,LVDS,RGB |
HDMI OUT | N/A | N/A | HDMI1.4 | HDMI1.4 |
CVBS OUT/IN | N/A | N/A | CVBS Out, and CVBS In | CVBS Out |
Camera | one 2M ISP, MIPI-CSI and DVP interface | one 2M ISP, MIPI-CSI and DVP interface | one 8M ISP, MIPI-CSI and DVP interface | DVP interface up to 5M without embedding ISP |
TYPE C Interface | N/A | N/A | N/A | N/A |
USB3.0 | Up to 5Gbps, | N/A | N/A | N/A |
USB2.0 | USB OTG2.0 x 1 USB Host2.0 x 1 | USB OTG2.0 x 1 USB Host2.0 x 1 | USB OTG2.0 x 1 USB Host2.0 x 1 | USB OTG2.0 x 1 USB Host2.0 x 1 |
MAC | 10/100/1000M Ethernet Controller | 10/100/1000M Ethernet Controller | 10/100M Ethernet Controller | 10/100/1000M Ethernet Controller |
PHY | N/A | N/A | N/A | N/A |
I2S/PCM Interface | 8 CH I2S x 1 and 2 CH I2S x 1 | 8 CH I2S x 1 and 2 CH I2S x 1 | 8 CH I2S x 1 and 2 CH I2S x 2 | 2 CH I2S x 1 |
PDM/TDM Interface | 8 CH PDM x 1 | 8 CH PDM x 1 | N/A | N/A |
SPDIF | N/A | N/A | N/A | YES |
SPI | SPI x 3 | SPI x 3 | SPI x 1 | SPI x 1 |
UART | UART x 8 | UART x 8 | UART x 3 | UART x 3 |
I2C | I2C x 6 | I2C x 6 | I2C x 4 | I2C x 4 |
PWM | PWM x 11 | PWM x 11 | PWM x 8 | PWM x 3 |
双屏异显 | N/A | N/A | N/A | N/A |
工作温度 | RK1808 :0℃~80℃ RK1808K:-40℃~85℃ | 0℃~80℃ | RV1108A :0℃~80℃ RV1108K1:-40℃~85℃ | 0℃~80℃ |
配套使用的PMIC | | RK809-2 | | RK805-3 RK816B-1 |
