制程 | 22nm | 28nm | 28nm | 28nm |
封装 | FCCSP565L 15.5mm*14.4mm*0.9mm 0.65mm&0.4mm pitch | TFBGA418L 14mm*14mm*1.2mm 0.65mm pitch | BGA636 19mm*19mm*1.6mm 0.65mm pitch | BGA453 19mm*19mm*1.4mm 0.8mm pitch |
CPU | 64bit Quad-Core A55, up to 1.8GHz | 64-bit Quad-Core A35, up to 1.5GHz | Quad-Core A17, up to 1.6/1.8GHz | 64bit Octa-core A53,up to 1.5GHz |
GPU | Mali-G52-2EE 800MHz | Mali-G31MP2 520MHz | Mali-T760MP4 500M/600M | G6110 GPU 600MHz |
CPU RAM | one channel DDR controller up to 8G Byte, DDR3/3L-800Mbps, DDR4-1056Mbps, LPDDR3-800Mbps, LPDDR4-1056Mbps LPDDR4X-1056Mbps | one channel DDR controller up to 4G Byte, DDR3/3L-1600Mbps, LPDDR3-1600Mbps, LPDDR2-1066Mbps, DDR4-1600Mbps | dual channels DDR controller up to 8G Byte, DDR3/3L-1333Mbps, LPDDR3/2-1066Mbps | one channel DDR controller up to 4G Byte, DDR3/3L-1600Mbps, LPDDR3-1333Mbps, LPDDR2-1066Mbps |
NPU | Up to 0.8TOPS | N/A | N/A | N/A |
NPU RAM | N/A | N/A | N/A | N/A |
Memory | eMMC5.1 HS200 mode | NAND, Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 | NAND, Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 | NAND, Compatible with eMMC specification 4.41, 4.51, 5.0 and 5.1 |
Video Decode | 4K@60fps H.264&H.265&VP9 Profile0/2 video decode,1080P multi video decode | H.264/H.265 1080p@60fps video decode | 4K H.264 and 10bits 60fps H.265 video decode,1080P multi video decode | 4K H.265/H.264 video decoder,1080P multi video decode |
Video Encode | 1080p@100fps video encoding for H.264 and H.265 | 1080p@30fps video encoding for H.264 | 1080P video encoding for H.264 and VP8,MVC | 1080P video encoding for H.264 and VP8,MVC |
Codec | N/A | N/A | N/A | N/A |
Audio Format | MP3、WMA、OGG、APE、FLAC、 AAC etc | MP3、WMA、OGG、APE、FLAC、AAC etc | MP3、WMA、OGG、APE、FLAC、AAC etc | MP3、WMA、OGG、APE、FLAC、AAC etc |
SDIO Interface | SDIO3.0 | SDIO3.0 | SDIO3.0 | SDIO3.0 |
SD/MMC Interface | SD3.0/MMC4.51 | SD3.0/MMC4.51 | SD3.0/MMC4.5 | SD3.0/MMC4.5 |
| N/A | YES | N/A | YES |
PCIe | PCIe2.1, Compatible with PCI Express Base Specification Revision 3.0 | N/A | N/A | N/A |
| Up to 6.0Gbps, SATA3.0 x 2。 Compatible with Serial ATA3.3 and AHCI Revision 1.3.1 | N/A | N/A | N/A |
LCD Interface | up to 2560*1660, MIPI,LVDS,eDP1.3,Eink | up to 1920*1080, MIPI,RGB, 1 Channel LVDS, | up to 3840*2160, MIPI,eDP1.1, 2 Channels LVDS,RGB | up to 1920*1080, MIPI,eDP1.1, 1 Channel LVDS,RGB |
HDMI OUT | HDMI2.0 | N/A | HDMI2.0 | HDMI2.0 |
CVBS OUT/IN | N/A | N/A | N/A | N/A |
Camera | one 8M@30fps ISP,可分时复用满足双摄; MIPI-CSI 4lane,可拆分成2x2lane两组独立使用;and DVP interface | one 8M ISP, MIPI-CSI and DVP interface | one 13M ISP, MIPI-CSI and DVP interface | one 8M ISP, MIPI-CSI and DVP interface |
TYPE C Interface | N/A | N/A | N/A | N/A |
USB3.0 | Up to 5Gbps, USB HOST3.0 x 1 | N/A | N/A | N/A |
USB2.0 | USB Host2.0 x 3 | USB OTG2.0 x 1 USB Host2.0 x 1 | USB OTG2.0 x 1 USB Host2.0 x 2 | USB OTG2.0 x 1 USB Host2.0 x 1 |
MAC | 10/100/1000M Ethernet Controller | 10/100M Ethernet Controller | 10/100/1000M Ethernet Controller | 10/100/1000M Ethernet Controller |
PHY | N/A | N/A | N/A | N/A |
I2S/PCM Interface | 8 CH I2S x 2 and 2 CH I2S x 2 | 8 CH I2S x 1 and 2 CH I2S x 2 | 8 channels I2S0 | 8 channels I2S0 |
PDM/TDM Interface | 8 CH PDM x 1 and 8 CH TDM x 1 | 8 CH PDM x 1 and 8 CH TDM x 1 | N/A | N/A |
SPDIF | YES | N/A | YES | YES |
SPI | SPI x 4 | SPI x 2 | SPI x 3 | SPI x 3 |
UART | UART x 10 | UART x 6 | UART x 5 | UART x 5 |
I2C | I2C x 6 | I2C x 4 | I2C x 6 | I2C x 6 |
PWM | PWM x 16 | PWM x 8 | PWM x 4 | PWM x 4 |
双屏异显 | N/A | YES up to 1280x720 and 1280x720 | YES up to 3840x2160 and 2560 X1600 | N/A |
工作温度 | 0℃~80℃ | PX30 :0℃~80℃ PX30K:-20℃~85℃ | RK3288 :0℃~80℃ RK3288W:0℃~80℃ RK3399K:-20℃~85℃ | 0℃~80℃ |
配套使用的PMIC | | RK809-1 | | RK808-B/RK818-1 |
